I purchased an ebiblePDA software CD last week and when i tried installing in my laptop, some error is coming in between.
The error showing is ' This application has failed to start because RAPI.dll was not found. Re- installing the application may fix the problem'. I tried re-installing and the same error is showing again and again.
Kindly advise to solve the problem.
Make sure that the procedure of the software you're trying to uninstall is not running, right-click the taskbar and select the "Start Task Manager" option, go to the "Processes" tab and look for the process of the software (To make sure it's the right one, look in the last column to see the Description of the process). Right-click the process and select the "End Process Tree" option and then try uninstalling it. If it doesn't work or the process doesn't show up, try a third-party software to uninstall the software, such as CCleaner, and try it from there. If the problem persists,try restoring your machine to a date previous to the installation of the software. If you cannot do this or there's no restoration point, try by permanently eliminating the folder where the software is installed on. It might still show up in the installed software, but you've already eliminated it from the computer.
Unplug Web Camera. Remove its software. restart your system. Install the software. Restart the system. Now attached the camera, it will work properly INSHALLAH. THANKS FOR ASKING QUESTION.
No, it is not a hardware error, it is purely software, i would recommend, trying to turn off your network\wireless adapter by switch, and then turning it on after a min or so.
with recovery or win cd in drive restart pc and do a format
when prompted hit enter to start with cd
then choose option for new installation then when asked to delete selected partition choose option to delete
then just read and follow instructions
please you download printer new software and install it .Some times cab file is missing in cd.
If you are not success please send me your email address
i shall help you
if you have see your printer online lamp is orange color so problem your printer
Your motherboard may be failing. Sometimes when motherboards or ram fail they have a problem with dropping parts of files. However it would not hurt to get a new copy of xp pro and try that first.
Using the Windows installation cd. Boot the system with the CD in the drive. When given the option select the repair option. This should correct the issue. Hope this helps & please remember to rate my answer. Thanks.
hi i am a certified Canon repair tech for this printer. if you follow the link below this will take you to Canons support site where you can download the software for your printer. hope this helps
