Question about RCA Televison & Video
I hooked up the converter box following all directions and when I do the channel scan nothing happens. It tells me there is no signal, but if I hook my cable wire directly to the tv I have signal
  • 520 Answers
The converter box should be used with an antenna.
Posted on Jul 18, 2008
I have a digital tuner converter box and only get 20 channels but I want more how can I get more
Check the Internet for a list of the local air channels and compare it with the stations you receive. Then get a good outdoor antenna, mount it at the highest unobstructed possible point and hook it to the digital tuner box. Check for signal strength while turning the antenna in different directions. Choose the direction with the strongest signal and re-scan for channels. Good luck.
Jan 02, 2018 | Televison & Video
Hooking sayyo tv to directv
Not sure if I understand what is happening here but if set on channel 4 the connection for the direct TV would have to be to the coax fitting on the rear of the set.
For the audio/video inputs on the rear or side it would have to be the same ones coming out of the direct TV box to one of the same but inputs on the rear--Audio/video are one connection and coax for channel four is a different one.
Dec 22, 2012 | Televison & Video
New tv. won't work
Press the input button and select where you have the satellite plugged in.
Aug 12, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Digital converter box won't work on toshiba md13p3 model
You can go online to the digital tv website and check your area for signal strength. All you do is punch in your area code and it will tell you if your able to get any channels. In your set up screen you can run a channel scan. Most of the time you need a good digital antennea which is something they don't tell you. I purchased one for about fifty dollars and it still don't work all that great I got a very weak signal.........So Good Luck and I hope this information was helpful to you Thank You For Using Fixya.Com! Have A Great Day! : )
Jun 17, 2009 | Toshiba MD13P3 13 in. TV/DVD Combo
How do I scan the channels on a Panasonic 1080i HDTV? This is for the conveter box hooked up to the DVD/VCR to the Panasonic 1080i HDTV'
The cable to the antenna and another cable from the TV needed to be hooked up and THEN follow the directions that came along with the converter box.
Channel 3/4 and scan., be sure the antenna is strong enough.
There was no need to touch the DVD/VCR box.
Jun 12, 2009 | Panasonic PT-53WX53 53" Rear Projection...
We have an older tv with an indoor vhf/uhf antenna. We have hooked up the converter box according to directions and even watched a video showing how to hook it up. However, with the tc on channel 3 and...
Sounds like a connection problem, if coaxial connection was made and box is turned on, then something should show up on channel 3. If rca composite connection was made something should show up on video 1 or 2. Make sure box's power button is pushed to 'ON'.
Mar 24, 2009 | Insignia Digital-to-Analog Converter for...
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
No channels downloaded
The antenna must be hooked up to the converter box. The better the antenna, the better your reception will be.
Not everyone in the country will be in range of digital signals. Digital signals have a shorter range than analog signals do right now. It is possible (but unlikely) that you are not currently in range of any digital signals.
So make sure you are set up like this - Antenna--converter box--Television. Then scan for channels. You should still pick up any analog signals while the box is hooked up, you will just view them the same way you do now, by changing the TV station rather than the converter box station.
Dec 06, 2008 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
