Question about Lowrance LMS-337CDF GPS Receiver
Lowrance 337 GPS says "Not Responding"
After a few different people told me to check different things (check for losw wires, check power supply to GPS antenna) the common theme was that my GPS unit or my antenna were "toast." However, then this guy that appeared to really know his stuff told me that what I need to do is download Lowrance GPS updates to my computer, and then, as long as I have a compatible compartment on my PC, transfer those updates from my PC to my Vancouver Islans mapping card/chip. He told me that this has been a common problem lately because WAAS satellites have been re-positioned, and my GPS can no longer find them. Does this make any sense to you. I have a very big fishing trip coming up soon, and would love to have this issue resolved. Thanks!
  • retaob Nov 25, 2008
    my problem occured when my cell phone was right next to the antennae/receiver on my lowrance 337 unit. the phone rang, and the gps lost signal and I can't get it back. the sonar and screen are still working fine. any ideas?
  • Anonymous Apr 13, 2009
    my lms-337cdf screen light work right..but my gps/fish finder is blank
hydetech
  • 113 Answers
SOURCE: False fish readings
False fish readings are commonly caused by electrical interference such as alternator noise, and by air bubbles flowing across transducer.
For starters make sure your fishfinder is on an independent circuit and not on one powered by your ignition switch. In other words, you should be able to turn your fishfinder on, even though the engine is turned off. Ideally the fishfinder should be wired directly to the battery with an in line fuse.
Try running the boat at a speed slightly higher than trolling speed, then kill the engine, as the boat slows down to trolling speed do you still see false echos? If yes then the problem probably lies with how the transducer is mounted, or where it is located on the hull.
If you don't see the false echos when the engine is off, it may be necessary to reroute the transducer cable to keep it away from the boat's ignition wires. You can get transducer extension cables if necessary. Also there are filters that you can buy that suppress alternator noise buy attaching between the battery and the engine.
Another common cause of false echos from electrical interference is a transducer cable that has been cut and spliced.
I hope this information helps. Please reply if you have any questions about my response.
Posted on Feb 26, 2008
  • 848 Answers
SOURCE: GPS module not responding
there may be some code lost in your module so you have to contact the service center to solve this problem......
Posted on Jul 11, 2008
SOURCE: I get a message on the screen of my LCX-15MT
To get the updates, start with a blank card. The first time you use it you will plug it into the card reader. It may ask you to format here. If so click "OK". If not: Go to "My Computer" - it will show up there as a storage device. Right click and select format. It will in effect "erase" the card and "prep" it for further use.
Follow the prompts. When done you should be able to go to the site you wish to download from and when you click on the file it will ask if you want to save it. "Yes" to your "Desktop". Once done you can open "my computer" - double click on the card reader. It will open with nothing in it. Reduce the screen pic for the reader so you can also see your desktop. Put cursor on desktop file - Right click and hold the button down while you drag the file to the card reader file and let go of the button. Click "Copy Here". Now you should be able to take the card and insert it into the display to run the actual update.
Posted on May 08, 2010
SOURCE: I have a tom tom go 920 when i turn it on all i
Call customer service with the unit plugged in to the cradle. They can walk you through some updates and if necessary reformat the unit. If that doesn't work and it's out of warranty then you're screwed. They have a software glitch and if reformatting doesn't work and it's out of warranty then they suggest you throw the unit away and buy another. Trust me, I won't buy another TomTom.
Posted on Aug 31, 2010
SOURCE: lowrance 330c gps not responding
do you have both power and ground wires hooked up?
Posted on Jan 12, 2011
Lowrance 330c gps not responding
Jul 27, 2010 | Lowrance LMS-330C GPS Receiver
Lowrance LMS 337
I wonder if the module has failed again, have you tried reseting the device?
I'm looking into this but I suspect that repairs are required again.
Jul 09, 2008 | Lowrance LMS-337CDF GPS Receiver
My lowrance 520c GPS stopped working. When I turn it on it shows the last lake I was AT. And the trail marker does not work
I have a 525... Several things and go step by step... First, make sure your getting 12v of power to your "puck"... On the Lowrance site there is a step by step guide for testing. Just because your getting power to the main unit does not mean your getting power to your the gps module. There are three different power sources on these units. Main power, sonar and gps! If your getting 12v coming out of the data port then check power to the cords, and to the T... If all that is correct the its likely your gps module. You can order a new one directly from Lowrance customer support for 50% off the normal price as a replacement. They will likely upgrade you to the 4000 series. Comes with all wiring, T connector but not the resistor cap. Best time to call Lowrance is 8:15 am central time when the phones are turned on!
Mar 04, 2010 | Boating
Lcx-15ct (gps module not responding)
Before you give up on the LGC-12S you have now though, try plugging the LGC-12S right into the LCX-15CT without an extension cable. If the module not responding goes away...you just need a new extension (GPSX-25G p/n 99-46).
The power cable has a set of yellow, blue, orange, and bare data wires. If these wires short together, you can get the module not responding error.
If all that doesn't help...the LGC-12S is bad.
The LGC-12W p/n 112-06 will work with the LCX-15CT. You probably get this at many marine electronics dealers or go to lei-extras.com and buy it straight from Lowrance. They cost $229 so you might want to shop around putting that money into a whole new system altogether.
Make sure you have the latest software updates if you get the newer LGC-12W. These can be downloaded at http://www.lowrance.com/en/Downloads/Product-Software-Updates/
Let me know if you need more help.
Jul 10, 2009 | Lowrance LGC-12S GPS Receiver GPS Receiver
HAVING A PROBLEM WITH MY LOWRANCE 525C WITH EXTERNAL ANTENNA. IT KEEPS TELLING ME GPS MODULE NOT RESPONDING. I HAVE CHECKED ALL CONECTIONS AND CANNOT FIND A PROBLEM. WHAT NEXT
Make sure that you have powered the NMEA 2000 network. The display unit's power cable has a set of red, black, and sheild wires that need to be hooked up to a 12VDC power source. There is a power diagram somewhere in the manual that should show this.
Make sure that you have the NMEA 2000 network connected properly. If it is a newer version LMS-525, it should just be a single 15ft cable that has two female ends, the module plugs into one end, and the other end plugs into the back of the display.
If it came with some T connecters and 120Ohm Terminator caps, then make sure you have that hooked up correctly. There should be a diagram in the manual for that as well but you just connect the two T's together like TT, put the 120Ohm terminators at each end, and run the extensions to the display and GPS module.
There is a decent troubleshooting guide for checking to make sure power is getting to the module at http://primus.lowrance.com/support/resultDisplay.do?gotoLink=92&docType=1000&contextId=426%3A92.273%2C600.639%2C92.113&clusterName=ClusterPublic&lang=english&docset=%2FDocuments%2FTroubleShooting%2FNew+Utility&contentId=42296cce-4f9b-40c8-9dcf-33d5df754009&responseId=135ccbe2cfd4f608%3A1fe88d%3A1225c5cc17c%3A-bac&groupId=4&answerGroup=1&score=986&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FTroubleShooting%2FNew+Utility%2FNU_GPS_ModNR.htm&result=0&excerpt=Module+Not+Responding+The+GPS+module+not+responding+(early+GPS+products+may+also+indicate+coupler+not+responding)+indicates+that+the+unit+and+module+are+no+longer+communicating.&question=gps+module+not+responding&resultType=5000#Goto92
If this doesn't tell you anything, most likely the GPS module is bad.You will need to contact Lowrance support to get it repaired/replaced. You can call them at 800-324-1356 or email them at http://www.lowrance.com/en/Support/Product-Support/Contact/
Jun 29, 2009 | Lowrance Lms 525c Df 5" Df Sonar...
Gps error message "gps module not responding"
Check the connectors and wiring between the GPS module and sonar unit. If it's an internal GPS module yo may have knocked loose a connector internally.
Jun 01, 2009 | Lowrance LCX-17m Sonar with GPS GPS...
Alarm says" gps module not responding"
"GPS Module Not Responding" is the display units way of telling you there is basically no GPS module connected. You didn't say which unit you have, so I am assuming this is something like an LMS-520? The GPS module is the LGC-3000? If this is the module you have, make sure that you have powered the NMEA 2000 network. The display unit's power cable has a set of red, black, and sheild wires that need to be hooked up to a 12VDC power source. There is a power diagram somewhere in the manual that should show this.
Make sure that you have the NMEA 2000 network connected properly. If it is a newer version, it should just be a single 15ft cable that has two female ends, the module plugs into one end, and the other end plugs into the back of the display. If it came with some T connecters and 120Ohm Terminator caps, then make sure you have that hooked up correctly. There should be a diagram in the manual for that as well but you just connect the two T's together like TT, put the 120Ohm terminators at each end, and run the extensions to the display and GPS module.
There is a decent troubleshootin guide for checking to make sure power is getting to the module at http://primus.lowrance.com/support/resultDisplay.do?gotoLink=92&docType=1000&contextId=426%3A92.273%2C600.639%2C92.113&clusterName=ClusterPublic&lang=english&docset=%2FDocuments%2FTroubleShooting%2FNew+Utility&contentId=42296cce-4f9b-40c8-9dcf-33d5df754009&responseId=135ccbe2cfd4f608%3A1fe88d%3A1225c5cc17c%3A-bac&groupId=4&answerGroup=1&score=986&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FTroubleShooting%2FNew+Utility%2FNU_GPS_ModNR.htm&result=0&excerpt=Module+Not+Responding+The+GPS+module+not+responding+(early+GPS+products+may+also+indicate+coupler+not+responding)+indicates+that+the+unit+and+module+are+no+longer+communicating.&question=gps+module+not+responding&resultType=5000#Goto92
Apr 05, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
I have an lms-530c it keeps coming up gps module not responding?
Your GPS module is not receiving power (12volts). In the instuctions should be an additional red sheet of paper explaining how to wire it correctly. If the wiring is done right, check the 3 amp fuse.
Sep 01, 2008 | Lowrance GPS
Gps module not responding
can not be fixed from home. i'll have to send it back to lowrance. tried soft reset and hard reset, gps module not responding icon still pops up on screen, thank you for the suggestions.
Jul 11, 2008 | Lowrance GlobalMap 3500C GPS Receiver
Lowrance332
had same problem with lms337. i had upgraded the unit but had not upgraded the lms2000 gps module. i was turning the isolator on in the boat which powers up gps module, if the lms337 is not powered up as well the gps unit goes to sleep. the upgrade fixes it by checking that the unit has not been turned on periodically. otherwise as soon as you power up gps module also turn on lms337. lowrance product support sorted this for me.
Mar 02, 2008 | Lowrance LMS-332C GPS Receiver
Lowrance LMS-337CDF GPS Receiver Logo
347 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
