Cars & Trucks Logo
Anonymous Posted on Jan 25, 2011
Sanyo tv model ST21G1 chassis AC5G, will you please help me find the value of R617,power suppy section,thanks.
Colin Stickland
Level 3:
  • Yugo Master 22,516 Answers
  • Posted on Jan 25, 2011
Colin Stickland
Yugo Master
Level 3:
Answers
22516
Questions
Helped
6993089
Points
66324
Look for the colour code on the resistor and then look it up on a chart ,different values between a silver band and a gold band but the value is the same its just the % tollerance ,gold band is a lower tolerance
  • crespabs Jun 18, 2011
    The value of R617 is 820 ohms
Is chasses on kia sportage 2001 model strong
about as strong as folded 1mm thick sheet metal can be. Most cars now do not have a chassis but are uni-construction which means that the whole body is the chassis and if you are planning in fitting a tow bar to the car then get a tow bar fitter to do the job with an approved tow unit that has been designed to spread the stress over a large section of the car.
2answers
I need to get my radio code for a 2000 mitsubishi diamante,someone help me please!!
contact your local mitsubishi dealer and give them the chassis number and they can supply the code
Location of the chassis number on a 1989 mitsubishi triton
model not listed in my alldata book ,most models are on the top of the bulkhead under the screen ,but some big 4x4 are showiing at the back over back wheel and to the rear of it on the chassis so no doubt its corroded away ,if it has restamp it before you try importing it or you will need this certificate from dealer plus that paper signed by technical engineer and another from the customs then this and that ,in the end the paperwork costs more than the value of the vehicle ,i know because this is spain ,and of the decline of the forests through paperwork .
9helpful
2answers
I want the diagram of the 1999 Dodge Grand Caravan's fuse box. where can I get one?
I suggest visit autozone.com (free register) and check the Chassis Electrical and Wiring Diagrams sections.
Hope this help to solve your problem (remember comment and rated this) TY for using Fixya.
1helpful
Hi, have most of the MX5 books but where does this car originate. chassis no.JMONA30P500100161. Its a 1996 into New Zealand from somewhere? Anybody help with this.? Thanks out there
How to read a VIN
1st character- Identifies the country in which the vehicle was manufactured.
For example: U.S.A.(1or 4), Canada(2), Mexico(3), Japan(J), Korea(K), England(S), Germany(W), Italy(Z)
2nd character- Identifies the manufacturer. For example; Audi(A),
BMW(B), Buick(4), Cadillac(6), Chevrolet(1), Chrysler(C), Dodge(B),
Ford(F), GM Canada(7), General Motors(G), Honda(H), Jaquar(A), Lincoln(L), Mercedes Benz(D), Mercury(M), Nissan(N), Oldsmobile(3), Pontiac(2or5), Plymouth(P), Saturn(8), Toyota(T), VW(V), Volvo(V).
3rd character- Identifies vehicle type or manufacturing division.
4th to 8th characters- VDS - Vehicle Descriptor Section. These 5 characters occupy positions 4 through 8 of the VIN and may be used by the manufacturer to identify attributes of the vehicle. Identifies vehicle features such as body style, engine type, model, series, etc.
9th Character - The check digit "character or digit 9" in the sequence of a vehicle identification number (VIN) built beginning with model year 1981 (when the 17 character digit format was established) can best be described as identifying the VIN accuracy.
A check digit shall be part of each vin (since 1981) and shall appear in position
nine (9) of the VIN on the vehicle and on any transfer documents containing
the vin prepared by the manufacturer to be given to the first owner for purposes
other than resale. Thus, the VINs of any two vehicles manufactured within a 30
year period shall not be identical. The check digit means a single number or letter
"x" used to verify the accuracy of the transcription of the vehicle identification
number.
After all other characters in the VIN have been determined by the manufacturer
the check digit is calculated by carrying out a mathematical computation
specified. This is based on vin position, sample vin, assigned value code,
weight factor and multiply assigned value times weight factors. The values are added and the total is divided by 11. The remainder is the check digit number.
The correct numeric remainder - zero through nine (0-9) will appear.
However, if the remainder is 10 the letter "X" is used to designate the check
digit value/number.
10th character- Identifies the model year. For example: 1988(J), 1989(K), 1990(L), 1991(M), 1992(N), 1993(P), 1994(R), 1995(S), 1996(T),
1997(V), 1998(W), 1999(X), 2000(Y)------2001(1), 2002(2), 2003(3)
11th character- Identifies the assembly plant for the vehicle.
12th to 17th characters- VIS - Vehicle Identifier Section. The last 8 characters of the VIN are used for the identification a of specific vehicle. The last four characters shall always be numeric. Identifies the sequence of the vehicle for production as it rolled off the manufacturers assembly line.
Vehicle Identification Numbers (VINs) are used to uniquely identify motor vehicles. Prior to 1980 there was not an accepted standard for these numbers, so different manufacturers used different formats. Modern day VINs consist of 17 characters that do not include the letters I, O or Q.
1helpful
3answers
Fuel filter
on the accent remove the rear seat bottom cushion , and fuel tank sender access cover , remove fuel cap from tank to relieve any pressure , remove ground connector and fuel lines to replace filter .
who would have guessed . is it worth a fixya ? thanks.
Top Yugo Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Yugo Expert? Answer questions, earn points and help others
