Question about Vizio L32 32 in. LCD HDTV
Vizio l32 My set was doing the blink on and off while watching the just quit comming on now i have an led light but it remains green any ideas?
    Sergeant:
  • 280 Answers
It may be Connections on the signal or power supply board OR sometimes a short in the picture tube.If the picture tube is shorted it can be cleaned using a CRT restorer. This will most times buy you a few more years of service. Connection problems on the boards is a pretty easy fix for most techs
Posted on Jul 18, 2008
The light blinking on the TV
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 14, 2016 | Vizio L32 32 in. LCD HDTV
Vizio m550nv amber light is on but tv will not power on
EASY HOW TO FIX LED Vizio TV- no power - YouTube
? 6:13
https://www.youtube.com/watch?v=9xZcTWr2yV0
Nov 5, 2013 - Uploaded by Tampatec
DiY How to Fix led / lcd Vizio TV service repair - no powerservice repair review guide no red blinking led ... Theorange/amber light turns on when plugged in. But the TV won'tturn on after that (the light does not turn white).
Vizio TV logo Flashing (Blinking), TV will not turn on, not ...
? 4:01
https://www.youtube.com/watch?v=MDzCzZdgbdg
Jan 5, 2012 - Uploaded by Leo P
This is model XVT3D424SV, I was watching a DVD, I switched the input to TV, tried to connect to netflix, it was ...
HOW TO FIX VIZIO TV - What causes no power - YouTube
? 5:53
https://www.youtube.com/watch?v=5k1Mc1f6O3E
Jan 17, 2016 | Vizio M550NV 55 in LCD HDTV
Magnavox 51MP6200D/37, when watching, the picture faded to black and then the sound went within a minute. now the power light just blinks and to turn it off we have to unplug it.
maybe you set it in freeze mode or timer.... the blinking reason mostly is for freeze and standby mode.... try to rest your program in tv.
May 27, 2011 | Vizio L32 32 in. LCD HDTV
Screen turned green while watching and remains that way.
that's because it has a loose cable. check all are pushed well home. Bean cleaning behind it today?
Apr 05, 2010 | Vizio L32 32 in. LCD HDTV
AOC color monitor model 5En...during power on all led lights blinks then stops blinking without display action. all led lights on no more action observed.
actually if u repair an aoc monitor alone without getting connected to cpu once u switch on the monitor all led's will lit on ( green light ) it will remain on situation until u connect the vga connector to cpu that's the time led's will lit off and only the power led will remain in green condition.some aoc 5en once u power on power led is in green condition and if not connected to cpu it will be in orange condition.hope u get some idea but i am not sure if it will work with ur monitor. but as long as LEDs lit on i think no problem with ur monitor.
Nov 02, 2009 | AOC 5 En 15" CRT Monitor
Vizio l32 32 in. hdtv will not come on even if pluged in
If the led light is on or blinking, go ahead and replace the mainboard, if there is no led light at all, then replace the powerboard.
If you have further questions just post a more detailed sympton in order to give you a better answer.
Thanks.
Jun 13, 2009 | Vizio L32 32 in. LCD HDTV
TV goes black, won't power off
If the power indicator remains on (or LED remains green) when the unit goes dead, you will need to replace the main board to resolve.
Dec 22, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 TV won't turn on. yellow power light lit, should turn to green when button or remote is pressed, and set should come on. No response to either remote or manual buttons. No change after unplugging...
Had same prob;em. Replace main board and now works just fine. You need to take the back off and under the metal cover is the main board. The part number should start with 3320-xxxx-xxxx. You can purchase the board from Vance Baldwin. vancebaldwin.com sign in as a guest. I will warn you the cost of the board is high.
Steve
Aug 05, 2008 | Vizio L32 32 in. LCD HDTV
Vizio tv no sound no pitcher
If the LED is blinking it could be the inverter board. If there is no LED then the power supply may be a fault. some times both boards have faults like bad capacitors
Jul 01, 2008 | Vizio L32 32 in. LCD HDTV
Vizio 32 does not turn on
The tv not not power 0n dead set,1 ic blown out stby sw,how I can fix the board.Thank you.
Jun 21, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
