Question about Acer Aspire 5500 5570-2609 Laptop
My Screen is pink
I have a acer laptop and my screen keeps going pink. It will be normal for a bit ( sometimes minutes sometimes hours ) then it flashes back to pink. I've tried turning off my computer, removing my pictures on my screensaver I"ve even chanted over it nothing works. Please help it's driving me colorblind.
  • duncan_matth Dec 01, 2008
    the same with me "fiddling" with the colour resoltion settings worked for a while but now ..nothing. my eye's can't take anymore and I'm starting to buy elton john cd's help!!!!
  • 38 Answers
There must be some problem with the hardware of screen. get it checked from a professional
Posted on Jul 17, 2008
Sir, I am using Acer Aspire 4530 laptop. About 3 days ago I unplugged the main power supply. The laptop was running on battery. After an hour all of a sudden there was blank screen. I can seen black and...
You must have hit the screen and damaged it, that's the only way you get those colored lines. Contact Acer tech support for assistance in replacing the LCD. You will have to go through a bit to get a phone number. http://secure3.tx.acer.com/findsystem/FindSystem.aspx?title=Contact+Support&brand=Acer
Mar 05, 2011 | Computers & Internet
Screen freezes and shows crazy purple colors in the screen or pink horizontal lines. The one time it shuts itself down, the other i have to use the on/off button to shut it down. When restarting it gives...
Incedible in one web page I found this solution and its work for me, the problem is the batery, just remove and no more frezee screnss and horizontal lines in color purple, Hope this helpt to you.
Oct 26, 2009 | Acer Aspire 5520-5908 Notebook
Pink vertical line in acer aspire 4736z
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 09, 2009 | Compaq Presario M2000 Notebook
Laptop LCD goes black after a few seconds
Yes, The pink tint is an indication that the backlight is failing. Now the backlight is basically dead, the best way to get back going is to do an Ebay search for your model laptop and get a new screen. Most screens can be purchased for around $50.00 - $70.00 and they are very easy to swap. Email me if you need more info.
Buddy
Corporate Computer
www.ccl-la.com
Aug 03, 2009 | Samsung SyncMaster 940N Flat panel Monitor
I have acer aspire 4315 sometimes screen turn to pink but i can read but its annoying.. help pls.
Hi I have a Acer Aspire 1694wlmi, and when I start her up I get a pink colour to the screen, after 1 minute it reduces to only one corner?
Jul 15, 2009 | Acer Aspire 5610-4648 Notebook
Compaq 7550 monitor keeps turning pink. Works fine for a few minutes then back to pink and hard to see. Sometimes moving the mouse quickly will help but only for a few minutes. Have tried adjusting all...
Defective CCFL backlight may has the following symptom:
· Screen flashs on red/pink and off.
· Picture stays on in red and slowly be come normal.
· Picture flickering with dim display.
· Picture flickering on and off.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 14, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer 5634 laptop screen occasionally turns pink!
You have broken wire that connect screen to the motherboard, when moving screen it connect somtime and sometimes disconnect. It about 18pin wire but only one is broken.
Jan 12, 2009 | Acer Aspire 5630 Notebook
White turns to pink on acer laptop
The problem is CCFL light bulb in the screen. It is starting to die :( Can be replaced but that is not an easy task (easier is to replace screen as new bulb comes with it)
Compaq laptop pink screen sometimes
The normal cause of a pink tinted screen is that the LCD back light is beginning to fail. Kind of like a regular florescent bulb does when it starts to go bad. It may last for a while, but eventually you'll have to replace it.
Ron
Dec 13, 2008 | Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
418 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
