Question about LG MV-1444Y Microwave Oven
Gallaxy microwave Hung in apartment 2 years ago.Used but 5 times.Tenants moved in and microwave was dead.I checked the fuse behind the panel (grill)it checked out good.I am a licensed Electrician! I jumped some switch to the back and it light came on and the table was turning.So I know the power supply is good.Is there any other fuses in the back?What else should I check or do I take it to repairman and is it worth it? Thank you CHIP
  • LG Master
  • 9,086 Answers
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
How do I get to the fuse in my microwave
It of course depends on your full model number, but since you posted under the model KHMS155LSS, I'll assume that's it.
You have to remove the grille across the top and may have to remove the control panel assembly.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
In this model, there is one fuse (20A) and two thermostats which can be defective, any of which will render the oven dead.
Dead meaning no display, no light when you open the door, and no response when you press a pad on the keypad.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
I have a copy in my files if you don't find yours.
Nov 27, 2012 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Whirlpool GH5184XPS-7 microwave oven dead, no power.
The problem is in the magnetron or the inverter board.
May 27, 2012 | Whirlpool Microwave Ovens
We have magic chef Over the Range Microwave Oven Model: MCO153U. Microwave was dead and no power
The original problem, was probably caused by a bad door switch along with the fuse, now there is a good chance the control panel is damaged, you will need a professional to assess if the item is worth fixing.
Apr 21, 2012 | Magic Chef Microwave Ovens
Roper microwave /hood has stop completly working model # MHE14XMG1
The magnetron can overheat if the internal cooling fan fails, when you run it empty, when you run it a long time, or when you cook low-moisture foods like popcorn, bacon, or baked potatoes.
When the magnetron overheats past a certain point, its thermal protection device will kill power to the whole unit.
If the protection device is a thermal cutout, it will need a new thermal cutout.
If the protection device is a thermostat, it should reset after the oven cools down. If not, it will need a new thermostat.
You or someone you know can check this.
At my Web site, I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components. I've attached a marked excerpt.
In this model, the other parts which can commonly fail and render the oven "dead" are the 20A line fuse, and one of the cavity thermostats.
You can order parts from the Pros here. Just enter your full model number to do a lookup.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 05, 2017 | Microwave Ovens
Was working fine, punched in time to cook, hit start ...it ran for a second and then just went dead. No light, no display Microwave is 10 years old but never had a problem before
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. remove the fuse and check for continuity across the fuse. Replace fuse and microwave should begin working.
Feb 11, 2011 | Whirlpool MH7140XF Microwave Oven
MICROWAVE IS DEAD. IT CAME ON FOR 3 SECONDS AND THEN WENT DEAD. NO LIGHTS NO CLOCK NO NOTHING. IT IS BUILT IN OVER THE OVEN. IT WAS MANUFACTURED IN 1998.
sounds like you may have a blown fuse. . remove the 2 screws at the hop thats holding the ventillation grill. remove screw holding control panel. push control panel up slightly and lift out. . there should be another metal sheet covering the opening. remove and your fuse should be right behind that.
Feb 04, 2011 | GE JE1640WA/GA Microwave Oven
Ran microwave w/o food inadvertantly. Nothing works, no display. Breaker swith OK.
It may be the fuse, which is usually located behind the grille, on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Maytag owner's manuals and installation instructions here.
Dec 13, 2010 | Maytag MV1153BAW 1000 Watts Microwave Oven
Control panel went off and hence it stopped working
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
You can download Frigidaire / Whirlpool installation instructions here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Nov 26, 2008 | Frigidaire PLMV169DC Microwave Oven
Microwave stopped working for no reason
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find your tech sheet, you can download it here.
You can download Whirlpool owner's manuals and installation instructions here.
Nov 21, 2008 | Whirlpool MH1140XM Microwave Oven
Blowing fuses
[double post]
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
But I would wait until the authorized servicer gets there (or take it to them) to maintain your warranty.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 02, 2008 | Maytag MMV5207A Microwave Oven
LG MV-1444Y Microwave Oven Logo
95 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
