Question about Sony Computers & Internet
I have a Sony RC10G computer, It will come on and stay on for 1 minute. It will go off and come pace on over and over. it want stop or come on all the time. I checked the fans they are good. I restored it to original factory restoration. It would not fix it. I tried a new harddrive and memory. I took it to a professional computer fixer to see what he could do. He tried everything, but it still want work. He said he give after 7 days of trying. Therefore I am turning to you to fix this peace of junk. Please tell me what is wrong and what else I can try. Thanks DR.BEn Powell
    President:
  • Sony Master
  • 1,314 Answers
Try the power button. Find out which two wires are attached to the power button and remove those from the system board. Check the resistance with a multimeter, should be 1 with the button not pressed and 0 with it pressed. Or, you can short those two pins on the motherboard with a screwdriver and see if the computer comes on and stay on.
Posted on Jul 17, 2008
Toro personal pace mower will not stay started?
If ir starts and runs for only a few seconds it's a dirty carb/bad gas. Drain the fuel system and use FRESH gas; change out your fuel supply monthly to avoid "phase separation" issues. If it runs for several minutes and then dies it is possibly a sticking valve. Do a compression check cold and after it stalls to confirm. Hope this helps
Mar 08, 2015 | Toro 20372 Recycler Personal Pace...
Toro personal pace 20372 starts, runs for 45 minutes then dies
Possible fuel blockage,or ignition source getting hot,electronic CDI unit ,check for spark at the plug when it stops.
Jul 21, 2014 | Toro 20372 Recycler Personal Pace...
My indesit condenser dryer stays on 1 minute and doesnt stop
Probably the timer is hung and will have to be replaced.
Aug 08, 2017 | Dryers
Hazard stop flashing after 1 minute and stays on
Yes, I replaced the relay box and it worked.
Feb 17, 2012 | Cadillac CTS Cars & Trucks
The treadmill speed is faster than reallife speed. I can easily run 7 minute miles on the roads (not racing, just running) and my wife is an eight minute metronome. But on the treadmill if I set it below...
the speed of treadmills are based on the companies regulations and are machine made. so they might not be 100% accurate. a treadmill is a simulated devise so it is never the same. var fctb_tool=null; function FCTB_Init_c8c9213424bf492d84f2bfaa8e62c574(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_c8c9213424bf492d84f2bfaa8e62c574(document['FCTB_Init_c3525ba5f17e4280b024b96d82d11976']); delete document['FCTB_Init_c3525ba5f17e4280b024b96d82d11976'] var fctb_tool=null; function FCTB_Init_6836227ebca14782a6c9f0284529fff9(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_6836227ebca14782a6c9f0284529fff9(document['FCTB_Init_f3124b0bb88c423dafd62627ed1118bc']); delete document['FCTB_Init_f3124b0bb88c423dafd62627ed1118bc']
May 05, 2011 | NRS Sole S77 Treadmill
PS3 HAS POWER BUT WILL NOT STAY ON. WILL TURN ON THEN TURN OFF WITH RED LED FLASHING IN A STEADY PACE OF 1 SECOND APART.
Sounds like the Yellow Light of Death. It is faulty solder on the graphics chip. You need an Infra Red BGA reflow of the solder underneath the chip. Best place in the UK is: http://www.playbackups.com/Playstation3-xbox-360-repair-repairs-manchester-bga-solder.html
Nov 09, 2009 | Sony Playstation 3 (PS3) Console
Lens goes in and out, stays out when off and says
I'm sorry that the lens of the camera is not retracting. Please make sure that the battery is fully charged and there are no dust particles near the lens which stops retracting. Check if you are able to access the Menu. If yes, then, please Initialize the camera under Main settings 1 Menu. If you are not able to access the menu, you may have to power reset the camera by removing the battery and press n hold the power button for 1 minute continuously. After that leave the button and insert the battery and check if it helps. If the issue still persists, your camera will require service.
Sep 26, 2009 | Sony Cameras
Starter will not engage anti theft light is on it is a 2005 cobalt
I found this on a website try this
1. Put the newly cut Master key into the keyway and turn it to the ON (RUN) position. A "security" indicator
light on the dashboard will stay on for 10 minutes.
2. Within 1 minute after the indicator light goes off, turn the ignition to "OFF", then return to the ON (RUN)
position. The indicator light again will stay on for 10 minutes (Do not remove the key.)
3. Again, within 1 minute after the indicator light goes off, turn the ignition to "OFF", then return to the ON
(RUN) position. The indicator light again will stay on for 10 minutes. (Do not remove the key.)
4. When the light goes off the third time, the new key is programmed into the computer and will start
the car. Remove the key and then re-insert it into the ignition lock and start the car.
All previously stored codes will be erased. To stop the process at any time, simply remove the key and use
an existing key to start the car.
Mar 25, 2009 | 2007 Chevrolet Cobalt Coupe
PS3 not playing any discs.
Sony charges 150$ plus s&h.
A new blu ray drive is 125$ if you know how to do it yourself it takes 10min to fix at a slow pace rather then the sony 3 month wait!
Sep 23, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
24 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
