Nokia 6303 Cell Phone Logo
Posted on Jan 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have folder in received folder folder is not del give me solu.
Anonymous
Level 2:
  • Expert 204 Answers
  • Posted on Jan 25, 2011
Anonymous
Expert
Level 2:
Answers
204
Questions
Helped
55087
Points
833
You can't delete that folder from your handset by your handset
To delete that folder connect your memory card to a PC and in PC select folder>right click>select delete
If this folder is in phone memory connect the phone to a PC via USB cable go to that folder select folder>right click>select delete
Thank you Don't Forget To Rate
Windows nu are acces la calea, fisierul...
https://www.fonepaw.com/windows/windows-cannot-access-the-specified-device-path-or-file-solved.html
https://translate.google.com
Cauze pentru "Windows nu poate accesa calea sau fi?ierul specificat al dispozitivului" Eroare
Solu?ia 1: Ob?ine?i permisiunea fi?ierului sau a dosarului
Solu?ia 2: Asigura?i-v? c? fi?ierul este ?n pozi?ia corect?
Solu?ia 3: Debloca?i fi?ierul
Solu?ia 4: Dezactiva?i software-ul antivirus
Solu?ia 5: Reface?i o comand? rapid? c?tre fi?ier
Solu?ia 6: Recuperarea fi?ierului care a fost ?ters, eliminat sau deteriorat
Solu?ia 7: Activa?i contul de administrator ascuns
It gives error that your hard drive have 1mb free space
1. Go in control panel Add or remove programs or programs and features then uninstall the programs that you don't use or havn't used in a long time.
2. Go in control panel Folder options view tab at the top. Look for Hidden files and folders put a tic in show hidden files and folders.
Go in My Computer/Computer Click on the c drive then windows folder delete the update folders that have a $ infront of the name of the folders. Go back to Folder Options/View tab at the top. Hidden files and folders put a tic in Do not show hidden files and folders.
3. Right click on Rec bin choose empty rec bin.
4. Go in control panel / Internet Options clcik on settings next to the first delete button from the top then click on view files. On the upper roght clcik on edit/Organize choose select all. Then hit your delete key on your folder yes to conferm. Click on ok then in the next window click on delete button next the settings button you clicked on before.
5. Open notepad type del %temp% /q then save the file to your desktop name it Del.bat cloce everything out and double click the del file on your desktop.
6. Open the run command Hold the windows key down (left of the space bar on your keyboard) Press the r key. Type in %temp% Delete all the files and folders you can in that folder.
7. Right click on Rec bin choose empty rec bin.
If it still says low disk space I suggest saving your personal files and reinstall your oem system disk or add a second disk drive.
Terry
7helpful
3answers
Sms memory full del some sms
Your Inbox Only support 200 sms... And when I say Inbox it includes your My folder as well... So you see 197+ 26 beyond your range... Delete Data from my Folder.... Problem solved.
1helpful
2answers
Unable to delete a file in vista ultimate
Dear Sir,
Please restart u r pc once and then try for del. coz if that respected file from that folder is running then its not possible to del. Thats y u have to restart once for delete.
Cheers
Alpine CHA 5624 shows error disc 3
o porta-cds cha-5624 não lê os cds,aparece no autoradio ERROR01.Tem alguns anos de uso,qual a solução?Obrigado
In what folder are received faxes stored to on XP
the address of fax folder is given to the server. thats why it is giving such error. normally files received in my documents "my received files" folder.
1helpful
3answers
Pioneer DVR-K17RS ATA ACER CODE=39
Try to remove the device from Device manager, and then reinstall or upgrade the driver. If the error continues to occur, it may be possible to edit the operating system Registry to resolve the issue.
Click the Start button, press run and type regedit.
  1. In the Registry Editor window, in the left pane, double-click the HKEY_LOCAL_MACHINE folder.
  2. In the HKEY_LOCAL_MACHINE folder, double-click the System folder.
  3. In the System folder, double-click the CurrentControlSet folder.
  4. In the CurrentControlSet folder, double-click the Control folder.
  5. In the Control folder, double-click the Class folder.
  6. In the Class folder, click to select the {4D36E965-E325-11CE-BFC1-08002BE10318} folder.
  7. In the right pane, click to select the UpperFilters registry value.
  8. Press Del / Delete to remove the registery entry.
  9. In the Confirm Value Delete dialog box, click the Yes button.
  10. In the right pane, click to select the LowerFilters registry value.
  11. Press Del / Delete to remove the registery entry.
  12. In the Confirm Value Delete dialog box, click the Yes button.
  13. close the regedit window.
  14. Restart the computer.
2answers
Funny ust scandal.avi
" After receiving many complaints from people’s about this virus, I finally decided to guide the users about the removal of this virus. Some of the problems caused by this virus are :
1. Show Hidden Files and Folders not working.
2. My Computer Drives open another explorer window.
3. When you run a program, just in 2 or 3 minutes the program dissappears (Actually runs in background but you can not see its window in foreground).
Removal of this Virus
Unfortunately, I have no removal tool to remove this virus at the time of writing, but you will soon see one. You can try the manual removal of it.
Manual Removal
Caution : While the manual process is going on, do not open any My Computer drive.
1. Open up cmd by typing cmd in Start –> Run.
2. Type in cmd
taskkill /f /im smss.exe
taskkill /f /im killer.exe
3. The virus placed some files at the root of every drive so you need to clean them.
Repeat the following commands on cmd for all your drives (Here it is applied for C drive)
del /a:h /f c:\autorun.inf
del /a:h /f c:\smss.exe
del /a:h /f c:\funny ust scandal.avi.exe
4. Now you need to delete files in windows folder so type :
del /a:h /f c:\windows\killer.exe
del /a:h /f c:\windows\autorun.inf
del /a:h /f c:\windows\smss.exe
del /a:h /f c:\windows\funny ust scandal.exe
5. Now you need to delete one more file :
del /a:h /f “%userprofile%\Start Menu\Programs\Startup\lsass.exe”
6. Use PowerExes to delete startup entries like.
smss.exe
lsass.exe(if it does not remove then only uncheck it)
killer.exe
7. To restore Folder Option Settings Follow this page
Show Hidden Files And Folders Not Working
8. To Remove the virus from Flash Drive, Insert a flash drive cancel any Autoplay box.
Open cmd and type (Replace x by your usb drive letter)
del /a:h /f x:\autorun.inf
del /a:h /f x:\smss.exe
del /a:h /f x:\funny ust scandal.avi.exe"
(source of info can be found here)
4answers
Hidden files
hit show hidden files to left
Size increase of ms outlook
Negative on that partner...
Your PST (email folder) file should not be bigger than 1.8Gb, once it reaches that size, you cannot receive or send emails.
What you can do is save the email attachments on your hard drive and delete them from the email message itself, saving only the message.
Make PST files that only contain up to 1.5Gb, then create more with other names (like Inbox200712_01.pst, Inbox200712_02.pst) for example.
If you have further questions or comments, please do so. If not and if the answer was good for you, please rate it as FixYa!
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
