Question about HP Computers & Internet
My monitor goes to sleep randomly - HP Computers & Internet
  • 1 more comment
  • hill4 Jul 17, 2008
    I will be online and for no reason at all the monitor turns off
    but the hard drive stays on. I have to turn off the hard drive manually and then turn it back on again .
  • Kevin Shafer
    Kevin Shafer May 11, 2010
    Have you tried turning off just the monitor and turning it back on again? Or unplugging the monitor from the back of the tower and plugging it back in again there?
  • Kevin Shafer
    Set off an alarm clock randomly to wake it up :c) Or, post more information and someone can help you.
    Scholar:
  • 52 Answers
Your monitor is controlled by the POWER setting on your PC. From the desktop, right click and select properties, then choose settings. Make sure your monitor setting has a long enough time setting that it doesn't go off while you are using it.
Posted on Jul 18, 2008
Monitor goes to sleep immediately after turning on the computer. How can I fix that?
go to start,then pc settings,then monitor or power options the to power and sleep and change on plug to 4 hours and on battery to 10 minutes
Jun 11, 2015 | Computers & Internet
Optiplex 745 monitor goes to sleep randomly
In regards to your issue with your monitor: For a monitor to display "no signal input" there is likely a problem with the monitor making a connection to your input source (yes I know duh). First and easiest thing to fix this is to check your cables going between your computer and monitor, if your computer and monitor start out working and then fail to communicate, there is a good chance that the cable might be coming loose just enough that the connection fails. I might suggest that if you have, as you say another computer, that you try swapping monitors to check where the problem lies.
Hope this helps some.
Aug 12, 2013 | Dell OPTIPLEX 745 PC Desktop
Monitor randomly goes black
saet monitor to never sleep
Feb 03, 2013 | Computers & Internet
Hp w2207 monitor randomly goes to sleep randomly, using windows xp
First make sure all the cables are securely plugged in. By randomly, do you mean a set amount of time of inactivity? Try this. If that doesn't work, it may be time to replace your graphics card (or buy one) or time to buy a new monitor.
Good luck.
Mar 07, 2011 | HP w2207 Monitor
My moniter will randomly go into sleep mode
Look at the power management settings.
Feb 28, 2011 | Computers & Internet
Montior goes black i turn off the monitor and turn it back on i can do about 2 things and screen goes black again repeat this as many times as i want. Gateway FHX2300 monitor
My monitor has been switching connections on me randomly. Hit the menu button. The one to the left of the power butter when facing the screen. Hit the left arrow twice then hit the menu button again. This will open up the screen where you can choose one of three inputs. I'm going to assume that it is on the incorrect input so use the arrow keys highlight what input you are using and the hit menu button again and your screen should return to normal. Mine only does this randomly when it goes into screen saver, hibernate or sleep. I don't know how to permanently get it to stop doing it though.
Aug 23, 2010 | Gateway FHX2300 LCD TV
Monitor goes into sleep mode at random
Check your power options in your control panel - default is usually 20 minutes to put monitor to sleep - you can adjust the time there. The monitor itself does not usually have this as a function so I would start there first.
Mar 25, 2010 | HP w1907 LCD Monitor
Monitor goes to sleep and won't wake up
You can google search for an app called NOSLEEP.EXE
It was written by a Symantec employee to keep your screen active regardless of pic settings.
Install and run it. That will verify the issue is with of or monitor
Software is free
Apr 09, 2017 | Mag Innovision LT776s 17" LCD Monitor
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
