I have a compaq presario 1500 and the power supply eventhough it sits snugly there is no power I have to twist and turn it and it gets power might run for a couple hours or mins (The battery is dead) and it looses it again. I saw same issues for the same model on the net but no defenitive answers from any body.
  • vivekmurthy Jul 18, 2008
    Thank You very much. You 100% correct.
    President:
  • 1,314 Answers
The only answer is the plug in itself has to be replaced on the motherboard. If you're not handy with a soldering iron soldering on multi layer circuit boards, then I would find someone who does.
Thanks and please take a moment to rate as fixya. Thank you.
Posted on Jul 17, 2008
I need a power supply model atx250w-12z
part number you need is KJ383AA, KJ383AAR
they have the dimensions that fit your computer please look for your self. Measure your power supply you have.
New PC Power Supply Upgrade for Compaq Presario SR5450F KJ383AA Computer
May 14, 2014 | HP Compaq Presario SR5450F Desktop PC
My presario 900 wont start
Either the motherboard is "dead" or the power-supply is "dead".
It's easiest to FIRST try a different power-supply.
Jan 04, 2014 | Compaq Presario 900 /1500 Series EVO...
Compaq Presario F700 Won't Turn On
Assuming the unit is plugged in, this could be an issue with the power supply, or an issue where the cord connects to the laptop. If the power connector on the back of the laptop is secure / doesn't feel loose or damaged, you may want to simply get a replacement power supply from a local electronics store. Be sure to take the make and model information of the laptop and the power supply with you to the store.
Jun 08, 2013 | Compaq Presario Notebook
My Compaq presario sr 1738nx desk top won't turn on at all. no blinking lights no fans nothing. if I unplug and re-plug back in the green light comes on for a second and thats it. nothing. ive swi
Sounds like the power supply has failed. That's where you plug the power wire into it. You could try opening the case and re-seating the main plug connector on the mother board. This is the big bunch of wires that ends in a 24 pin plug attached to the main board.
(See if you can borrow a power supply from a handy family member?) http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
Jan 20, 2012 | HP Compaq Presario SR1738nx-b Desktop...
Install new HD, plug into wall, no lights come on.
Are you sure the HD was installed correctly? The pins not mating properly might be the cause of the problem.
Make sure the power supply is working. Look at the brick (the box on the cord), it may have a light (an LED).
Dec 14, 2009 | Compaq Presario M2000 Notebook
My compaq presario 900 won't turn on
1. Check if your battery is fully charge or if there is power in your Compaq Presario 900.
2. Check for defect in your power switch.
Sep 21, 2009 | Compaq Presario 900 /1500 Series EVO...
Compaq presario wont turn on
Hello there:
when you turn on the computer and look at the back of the power supply and see if the fan is even working and blowing air if not you will want to remove the power supply and either have it tested or replaced there is a linkable fuse in these depending what type you have this fuse may be soldered in place or it may be able to be removed and replaced. ok i hope that this is helpful as what to do.
please dont forget to rate my solution for you.
best regards
mike
(USN) RETIRED
Aug 04, 2009 | HP Compaq Presario SR1420nx...
Flashing Green Light on Power Supply
get yourself a themaltake ps
make sure you remove the old one and take it with you to the shop or get the shop to do it for you if you dont have the expertise yourself.
hope this helps
Dec 31, 2008 | Compaq 300Wt Presario ATX Power Supply...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
