Hp pavilion dv1000/won't turn on
Plugged in will not work with plug nor with battery
  • Anonymous May 07, 2009
    what is a (SP) bobchuckley1
My HP laptop ran out of juice and wouldn't charge. It was the power connection on the mother board. A computer guy resoderd (sp) it for me and then it would turn on and charge the battery. Not sure if that helps.
Posted on Jul 18, 2008
2 Suggested Answers
mewms_14904
  • 1027 Answers
SOURCE: HP Pavilion dv1000 PC Notebook
Have you followed the recommendations on HP SITE
If the screen is blank they suggest disconnect the power, battery, and reset the memory modules.
Posted on May 26, 2008
Pavilion dv 1000 battery adaptor
You may take it to a tech center to fix it or buy a new charger. As for the cost, it is almost the same. So it is better to get a new adapter.
Replacement HP Pavilion DV1000 AC Adapter 65Watt 18.5V 3.5A
Nov 22, 2012 | HP Pavilion dv1000 Notebook
Hp pavilion laptop won't come out of standby
See if this works for you.
Unplug the power, remove the battery. Wait 2-3 minutes. Plug the power in without the batter. Turn on the system.
I do this for fun & feedback not $$$
Jim
Oct 03, 2011 | HP Pavilion dv1000 Notebook
My HP Dv1000 doesnt turn on when i oress the button, all the lights turn on then shuts off
Chances are your battery is dead. Make sure you plug it in and then try to power on.
If this does not work then you should take the lap top to a certified technician for troubleshooting and repairs.
Jan 22, 2010 | HP Pavilion dv9000z Notebook
Is this hp pavilion dv1000 battery a cheap one?
From the link you gave its seen that its comparatively lower than the other series.. Brand: HP Laptop BatteryBattery Info:
Li-ion, 4400 mAh, 11.10V, Black, 310.00(g), 205.15 x 59.20 x 37.50 mm
Rating: rate4.gif
Capacity Voltage Price($) 4400 mAh 11.10V C $ 57.79
8800 mAh 11.10V C $ 79.69
Availability: In stock
Notes for charging Hp Pavilion dv1000 Series battery :
  1. You must fully drain the Hp Pavilion dv1000 Series battery until the laptop goes into hibernation for your first use it.
  2. Store it in a cool and dry area. Do not expose battery to water or other moist/ wet substances.
  3. Do not forget to take away your Hp pavilion dv1000 battery from the laptop if you will not use it for a long time.
  4. Know that after that plug in your charger and allow it charge for 12 hours or depending on what the technician has told you. 12 hours is the max and you can use it while charging .
  5. Charge new Hp Pavilion dv1000 Series battery for three times at first. After that it will take less than 2 hours to fully charge your Hp Pavilion dv1000 Series battery.
  6. It is normal for HP laptop battery to become warm during charging and discharging.
  7. Learn that this is recommended so that the Hp Pavilion dv1000 Series will heat up for the time allowing ions to reawaken.
Jan 20, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
My hp pavillion dv1000 wont turn on it is plugged in but the charging light doesnt show up and when i push the power button nothing happens
Problem with your charger, try this :
1. Check whether the charger plug is properly inserted in the Power port/jack of your Laptop!
2. Check the power cord (any cuts OR torn-out)!
3. If above steps don't work, replace your charger.
Jan 02, 2010 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 works fine on CRT but no LCD screen
Sounds like the LCD backlight or inverter went bad. More probably the inverter,and that's good because,of the two, it's usually cheaper and easier to replace.
Before considering those,check the lid switch to make sure that it is operating correctly and not stuck down.
Ron
Dec 10, 2008 | HP Pavilion dv1000 Notebook
Battery life is very short
Not really. What happened is you shorted the life of the battery by always having it plugged in and in a charging state. The battery has a memory and since it's always been plugged in, it will never charge fully. There are products out there that will drain your battery down and reset the memory issue. But it would be cheaper to get another battery. If you are going to keep it plugged in the majority of the time, charge up the battery and remove it.
Jul 25, 2008 | HP Pavilion dv1000 Notebook
Charging cable gets hot, charge port too, not battery though
No it is not a problem. The power dissapiation in the adaptor causes it to become hot.
Jul 16, 2008 | HP Pavilion dv1000 Notebook
May 25, 2008 | HP Pavilion dv1000 Notebook
HP DV 1000
1) plug YOUR power adapter into your friends hp dv1000, see if it turns on laptop.on. If yes, then u have one less problem.
2) to trouble shoot a laptop takes a lot of skill, stuff is very small, things could be damaged just by pulling the wrong way. you would HAVE TO BE very carefull.
Look for the trouble shooting manual 1st. or find a good technical person.
May 05, 2008 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
1,131 people viewed this question
David Payne
David Payne
