Question about Dishwashers
I need a wiring diagram for a older model bosch dishwasher model no. smu2042uc/14 .
The diagram has to cover the switch( on/off, cycle settings ) panel with 4 wires and one plug that connects to the switch motherboard. switch link below. the wires have different colors and the switch has different numbers with asterisks. i need to know which wires go on which prong.
SOURCE: I have a Bosch SMU2042UC/14
It it leaks replace the seals
Posted on Sep 12, 2008
micromaster
  • 3614 Answers
SOURCE: I am looking for a
Despite the magic it performs in the kitchen, a dishwasher is actually quite simple--it is essentially a watertight box that sprays dishes with hot water and soap, drains out the dirty water, and then dries the dishes.
Hot water is delivered through a supply hose that connects to a valve that controls the water's distribution to spinning spray arms.
A pump gets rid of the dirty water, and an electric heating element dries the dishes. All of this is operated by controls that may be very simple or quite complex.
Posted on Oct 05, 2008
  • 338 Answers
SOURCE: Maytag Dishwasher Doesn't Start
on a dishwasher an ohmmeter is almost useless. the best way to check is to look for voltage. at the door switch check for voltage to ground on both sides. if you have 120 on both sides of the switch then follow the wire over to the control board. if you have 120 going into the control board and nothing coming out of the control then you nood to start looking for a broken neutral. however the likelyhood that its the control panel may be a better idea especially if you are hitting buttons and nothing happens. try reseating any ribbon cables
Posted on Nov 25, 2008
  • 31 Answers
SOURCE: wiring diagram
might be this one: ftp://download.intel.com/support/motherboards/desktop/se440bx2/72163201.pdf
Posted on Apr 01, 2009
  • 1779 Answers
SOURCE: Looking for a wiring diagram for a 2006 Ford Expedition
7way- black is 12volt (power), brown, running lights, yellow is left turn signal and stop light, green is right turn signal and stop light, white is ground, blue is brakes, and orange is aux power (can be back up lights, if trailer equipped w/ them). 6way is the same, minus orange wire. I have run into some variations to the above color codes (brown, yellow and green only-sometimes these 3 are different than stated, but only mixed as that group, as to what they control- example would be green is running lights, brown and yellow are turn signal and stop lights, the others should be as stated), if you have any trouble with things not working properly, it may be due to these variations, although the above are pretty standard. If you have an ohm meter you can check as you go (check for power at black wire- should be constant 12v, turn on turn signal and check for power-it will fluctuate from approx. 12 volts to 0 volts as the signal power pulses in the wire) hit the brakes, blue wire should show power, etc. Let me know if you need more help as you go.
Posted on Apr 11, 2009
I am looking for a wiring diagram for a Bosch Dishwasher SMU2046UC/14.
There should be a wiring diagram and other service information on a piece of paper behind the toe kick cover plate. That's where I found mine. Good luck.
Feb 07, 2016 | Bosch Dishwashers
I am looking for a new or good condition used part #00150467 This is the 4 button selector switch for Bosch SMU2042UC/14 Dishwasher
try e-bay and type in the search box --4 button selector switch for bosch dishwasher
if there are any you will get pages of sales for new and second hand
try cruising all the appliance shops that service /repair dishwashers and see if any one has a part from a machine that suffered other failures
Sep 11, 2015 | Washing Machines
Where to buy timer motor for my bosch dishwasher SMU2042UC/14
I have had success finding appliance parts on Amazon of eBay, especially if you have a part number or Model number.
Nov 03, 2013 | Bosch Dishwashers
Need owners and/or service manual for Bosch dishwasher SMU2042UC/14
The specific model manual seems unavailable online but,click on the link below to get to the product support site and see the available manuals.
www.bosch-home.co.uk/customer-service/download-product-manuals.html
Hope this helps.Thanks!
Jan 07, 2012 | Dishwashers
Bosch dishwasher shu43c07uc/14 dead
Control is available.
There was a recall on control modual because of fire dangers.
Call and get an auth number from Bosch 800 856-9226
Apr 20, 2010 | Bosch Dishwashers
Bosch dishwasher sps546 will not fill. switches on ok
you have to remove the cover of your unit in able to access the valve/.pump
Jul 08, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch dishwasher model SMU4052UC/14, Won't fill
you need to check the water solenoid valve. if you follow the water line coming into the dishwasher you will find the valve(first spot in the water line with two wires coming from it) if you pull the wires off you should see 110 v when it is trying to fill with water if you do then test the valve for continuity.
May 06, 2009 | Bosch 36 Inch Pyramid Chimney Hood - Black
Burnt wiring on Bosch SHX46A06 Dishwasher
Bill that is exactly what happened, the connection wasn't correct from the start. The Bosch dishwasher pulls 11 amps during the cycle while heating the water to temp. The cooler the water the longer the heat time. Your dishwasher came with a set of wire nuts that where suppose to be used. Be sure when you correct this to use 20 amp wire nuts with the unit. This will stop this from happening again.
Aug 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
My bosch exxcel dishwasher will not drain after wash cycle
That is because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
May 26, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Dishwashers Logo
180 people viewed this question
Top Dishwashers Experts
