Question about Toshiba Satellite 1715XCDS Notebook
Broken display screen
My great granddaughter stepped on the laptop and the screen broke. What steps do I use to replace it?
    Genius:
  • 2,028 Answers
Are you wanting to replace the screen yourself?
Posted on Jul 17, 2008
  • Ryan Rogers
    Ryan Rogers Jul 18, 2008
    Good. I think that you should know that you can get a decent deal on a screen at Ebay. Ebay is where I get a majority of screens for my customers.
My daughter-in-lase STEPPED ON my granddaughter's Nook!!!!! Now, although the screen is not broken, there's nothing but lines all over the display. Is there any hope of saving it?
The device cannot be fixed.
Your information is another matter. Any book, music or app you bought will still exist in the account. Also, ANYTHING sent to the cloud will still be there.
All else you put on your Nook is gone unless there is a copy on a PC where it was originally.
If anything was transferred to a SD card, it is still there.
Mar 10, 2017 | Barnes & Noble Nook Tablet
Screen frame broke
Screen frame being the Display Bezel.
http://h10032.www1.hp.com/ctg/Manual/c01573159.pdf
With the laptop closed, the top cover is the Display Enclosure.
Is it broken also?
http://www.lapzone.com/servlet/the-54572/HP-Pavilion-G70-17-dsh-inch/Detail
Can you say OUCH! That's the cheapest I found, but it was a quick search. Hopefully you'll have better luck in searching.
The HP part number, for the Display Bezel of the HP G70 series, is;
HP 488386-001
The HP part number for the Display Enclosure is;
HP 488379-001
Base Enclosure;
With built-in modem, Digital Media slot, AND -> with HDMI port,
HP 489114-001,
http://www.impactcomputers.com/489114-001.html
Base Enclosure:
WITH built-in modem, Digital Media slot, and NO -> HDMI port,
HP 501252-001,
http://www.ebay.com/itm/ORIGINAL-COMPAQ-CQ70-Case-Bottom-Covers-501252-001-Grade-A-/330628933816?pt=LH_DefaultDomain_0&hash=item4cfb0528b8
Hinge Kit; (2 each Hinges),
HP 488384-001,
http://battery-adapter.com/product_info.php/products_id/3900/vSPS:+488384-001
You have more damage than just the Display Bezel, I feel.
Access what damage you have, and I'll step by step guide you in replacing.
Just post back in a Comment.
Regards,
joecoolvette
Jan 29, 2013 | HP G70-250us Notebook
Replace laptop screen
STEP 1.:-Turn off the laptop and remove the battery.There are no screws securing the screen bezel. Start separating the screen bezel from the display cover with your fingers.
STEP 2.:-Continue removing the screen bezel on the top.
STEP 3.:Remove bezel from the hinges.
STEP 4.The screen bezel has been removed.
STEP 5.:Remove six screws securing the LCD screen assembly.
STEP 6.:-Separate LCD screen assembly from the display cover.
STEP 7.:-Place the LCD screen assembly face down on the keyboard. Now you can access the back side of the screen and disconnect cables.
STEP 8.:-Disconnect the video cable connector from the LCD screen controller board.
STEP 9.:-Parts of the video cable could be glued to the screen. Unglue the cable.
STEP 10.:-Disconnect cable from the inverter board.
STEP 11.Remove the LCD screen assembly.If you are replacing the LCD screen you’ll have to transfer mounting brackets from the old screen to a new one.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 23, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Hp pavilion dv9000 laptop with a broken hinge. It fell from my bed a it looks like the piece of metal inside one of the hinges is broken.
Check out these WEB sites, they are helpful :-
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br...
This isn't for a Gateway laptop, granted. But all laptops fall into a general replacement like this.
Inside my laptop
Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Sep 28, 2009 | HP Pavilion dv9000z Notebook
Laptop screen is damaged
you can continue using your external display or purchase a new screen and install it . check out this site for good step by step instructions, just find your model. Good luck to ya
Jun 11, 2009 | Toshiba Satellite Pro A200-EZ2204X...
Broken Screen
Do you still have a warranty on the computer?
Does the credit-card that you used to purchase the computer have an "all perils" clause, i.e., will they fix anything that you broke?
I would take the computer & the screen-from-eBay to a qualified technician, and have him/she do the replacement work.
May 31, 2009 | Acer Aspire One Netbook 8.9" Notebook
Oevrall screen is black
First off where did you buy the replacement screen? Second did that screen also come with new ribbon cables?
If you bought the replacement online and just installed it without reading the instructions or it didn't come with any then you have the reason there.
If you did read the instructions and followed the steps correctly, then did the replacement come with new ribbon cables and connect lines is the next part, because the reason the first screen failed was not only the screens dynamics, but the constant open and closing, bending causes the cables to get worn in the same area and eventually it will tear or just break. And since you stated that the hinges had broke first that automatically says that the screen will fail due to not being able to function as it should. So with that said, and your answer was YES to the new cables, then final step is to retrace your steps when installing. Because you forgot to reconnect something to have the screen light up. If the white light on the screen doesn't light up you will see what you see now.
I suggest you to goto ifixit.com they have a step by step with images to install or replace parts on all Apple portables. Just follow their instructions correctly to find your PowerBook and then use their install steps.
-Luke
Jan 19, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Contacts... broken screen
Menu, 6, 5, 2, 1, OK - at least that is how it is done on my KE970 - copies all contacts from phone to SIM
Oct 21, 2008 | LG Shine KE970 Cellular Phone
MP3 Player inner LCD Screen Broken.
Unfortunately you wont be able to replace the LCD screen..You will have to purchase another mp3 player..I hope this helps..
Please rate accordingly
Thank you
Computerrep
Mar 21, 2008 | SanDisk Sansa e260 MP3 Player
Broke screen
My psp screen cracked on the inside.I can't watch movies or play games cause the screen broke on the inside. Can i relace it?
Dec 13, 2007 | Sony PlayStation Portable (PSP) Console
Toshiba Satellite 1715XCDS Notebook Logo
49 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
