Question about RIM BlackBerry Pearl 8100
Blackberry phone when someone calls me my blackberry will only vibrate not ring how do i fix this
I have the same problem.  Tmobile as well as a cell phone repair shop said the speaker is blown.  When I checked online many speakers blow on the pearl after 5months.  The repair shop said they could fix it for $100
Posted on Jul 19, 2008
Tip
BlackBerry Tour: How to make it ring and vibrate for incoming calls
You can customize your BlackBerry Tour so that either it rings when you get a phone call, or it vibrates -- or both. To make your phone both ring and vibrate when you get a call, go to your BlackBerry's sounds and ring tone options, which you can get to by either of the following two ways:
#1 - Use the trackball to go to the sound icon in the upper left corner of the main screen and click on it, then toward the bottom of the list that appears, select Set Ring Tones/Alerts, then select Phone.
#2 - On the main screen, press the BlackBerry button (the one with the seven dots) to take you to your Home folder. Scroll down to the Options folder (it's usually toward the bottom, and it has a wrench icon) and click on it, then select Sounds and Ring Tones.
From this scren you can select the ring tone that you want and adjust the ring tone volume. Then scroll down to Vibration and set it for On.
There is also an option for Vibrate with Ring Tone. If you turn this option on, the phone will both ring and vibrate at the same time when you get a call. If you turn it off, the phone will vibrate first, then ring. Either way, you'll get the ring and the vibration -- it's just a matter of whether they happen together or not. To see the difference between the two options, use the "Try it" option at the bottom of the screen.
When you've made the selections that you want, exit out of the options screen, but be sure to choose Save rather than Discard to save your changes.
on Jul 10, 2010 | RIM BlackBerry? Tour 9630 Smartphone
CAN'T HEAR MY PHONE RING WHEN SOMEONE CALLS ME I HAVE TO PUT THE PROFILE ON VIBRATE
Each of your profiles can be set to different ring tones and different volumes, so whatever profile you have your phone set to, make sure you have it on a ring tone you can hear, and make sure the volume is turned up. Let me know if this doesn't work.
Jun 18, 2010 | RIM BlackBerry Bold 9000 Smartphone
My blackberry will not ring when i receive messages! Only calls.
go to where your messages are and then hit the menu key then go down to where it says "Message Alerts" Here you can change e-mail, SMS, and MMS and all message prefrences. you can pick ring only vibrate only vibrate and ring etc etc. click back then click save
Dec 02, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
When someone texts or calls me my phone vibrates instead of ring
You probably have silent mode on. Try pressing and holding the pound or the star key. One of those will probably release silent mode, so that whatever ring setting you have can be used.
Nov 09, 2009 | LG RUMOR Cellular Phone
My alarm won't ring or vibrate, but both work when someone calls me. I have it set for vibrate/ring but the screen just lights up when the alarm goes off, doesnt vibrate or ring
Reboot the HH,restart the HH and follow the follwing steps Press Menu,Select Clock-press menu-select alert type as tone-select the tone from the given list and save it.Check whether if you are able to listen to the tone.
Aug 04, 2009 | RIM BlackBerry Pearl 8100
Blackberry storm lock
i have a blackberry storm myself and mine doesnt do that when its locked. if you click on the sounds option and scroll down it says set ring tones/alerts and it will let u pick the sound type to check if its on a sound or vibrate other than that you might want to call the store or check the website it could be your phone.
Jun 15, 2009 | Cell Phones
BlackBerry Storm 9530 will not ring
It seems like the problems starts after using an audio streaming app (Slacker)It also seems to correct after a reset(battery out and back in).
Feb 18, 2009 | RIM BlackBerry Storm 9530 Smartphone
Blackberry Pearl 8100- Contact picture/name does not show when certain contacts call.
You might try performing a backup in the Desktop Manager, then performing a device wipe. You can wipe the device by going to Options > Security Options > General Settings. Press the menu key, then select Wipe Handheld.
After the device is wiped, then use the BlackBerry Desktop Manager to restore the data back to the BlackBerry. Then test it out and have someone contact you.
Oct 01, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
87 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
