Question about Pioneer Car Audio & Video
I have a 6 disc pioneer CD player that will not play or eject the case of CD's? It trys but nothing happens.
    Scholar:
  • 91 Answers
This sometimes happens when you put two disc's in one tray. If it's not locked in the loaded position then you can take a thin piece of plastic (as thin as a credit card but longer, five inches or so) or the equivilant (like that impossible to open without cutting yourself plastic packaging) and slide it underneath the 6 disc cartridge. You need to work it in and out, eventually you will hit the release mechanisim.
If a disc is loaded then it won't work and you need to dissasemble the changer and manually retract the disc.
Posted on Jul 18, 2008
My CD will not come out from the cd player. I press on the eject button it nothing happens It plays though when I press play
Sometimes there is a small hole that you can push in a straightened paper clip to manually eject disc.
Oct 04, 2013 | Air Purifiers
Pioneer PD-M306 cd changer will not eject
That is why they don,t manufactur them any more, There has been nothing but (Problems) With them doing that. It is out of (Alighnment) Just look for a good used one, You can buy a used one for $10to $ 50, To get it (Repaired) Your looking at $50 to $120,
Oct 22, 2012 | Pioneer Audio Players & Recorders
Pioneer cdj 400 unit turns on, takes cd, cd spins and then just ejects it.
There are two reasons for this fault. The first one is with its disc loading mechanism. If the mechanism do not place the disc properly on to the reading chasis, this fault can be. It will spin for some time and will ejected automatically
The second one is with its optical pickup unit. If optical pickup unit do not read the disc; due to some fault to it [dust or dirt over the optical lens]. But in this case, there will be only "No Disc" display will be there. No automatic ejection will take place.
With your player, the first sated might be the case. The disc loading mechanism might need replacement.
May 29, 2012 | Pioneer Audio Players & Recorders
Turntable will power up, all the lights come on,reads the cd but does not play. unit has to be turned off then on to eject the disc ? (hope this helps) Any ideas?
One of the buttons has got stuck, so when you press the button you want to, its not getting the message to start / stop playing. This is also why the eject won't work. Either a new button, or replacement board would make it happen for you :)
Jun 24, 2011 | Pioneer CDJ-1000 CD Player
I have a 2004 Mazda 3 w/ a single disc CD player...which has not been working for several months. There is a cd in the player but nothing happens when I press the eject button nor the CD button; won't...
Possible that the cd disc has jammed due to a change in the disc- warming can bend some cd's, also if the cd is struck inside as the loading mechanism is struck. In both cases the set must be pulled out if there is no hope with trying to retrieve the cd softly assisting while ejecting. If you do not hear any noise while the eject is pressed then the loading drive is faulty , you need to remove the cd , open to check, If this is mechanical then you can softly push the cd out, if not the electonic section needs a check.
May 03, 2011 | 2004 Mazda 3
There is a cd stuck in my cd player, how can I get it out?
Try pressing the reset button. This sometimes helps eject the disc. If not i have found that by holding a second disc slightly above the stuck cd and very gently pressing down on the stuck cd, it can help eject the stuck disc. DO NOT INSERT A SECOND DISC. there is also a possibilty that the ejecting mechanisim is broken in that case taking in to the repair man would be the wise choice.
Respectfully
dreamsystems
Feb 04, 2011 | Pioneer DEH-P6900UB CD Player
6 discs in system, won't play or eject
take it manually by opening the unit
Jan 20, 2010 | JVC KD-G110 CD Player
Pioneer DEH-10 won't play cds
the cuircuit board on the cd drive is bad faulty. this is why the lens wont and can't read the info on the cd
Jul 07, 2009 | Pioneer DEH-1100 CD Player
Car Audio & Video Logo
82 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
