Sony Ericsson K850i  Mobile Phone Logo
wajid shaikh Posted on Jan 25, 2011
Hi! i need to buy a new body for my K850i handset.\r\nCould you please help me in this regards. Thanks in advance, Wajid
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 09, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
90
Points
Hi sir my sony ericsson mobile body is broken so i had some provelem i want purchase new body kindely help me
My K850i sony ericsson when you turn on, no light,no display in the screen,but keypad light is ok..pls give me a diagram to solve my problem thanks.
In that case if you can receive the call then there is display Problem you should change your display,
If your not receive any calls then please renew the Phone Software
Both Can be done only in Sony Ericsson service center Please Visit your nearest Sony Ericsson Service center they will provide you solution.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
I have Phillips CD150 handset. I am getting message as INITIAL, but the phone is not working. I have reconnected all the wirings again but still it is not working. Thanks in advance for sending me...
there is a problem with the Base unit (Charger), repair man said that the main IC should b changed which is too costy, better to buy another set.
The handset of the faulty unit can be paired with the new set.
in short the handset shows what it receives from the base (charger) so it has no fault and may be used with another set
8helpful
I have Samsung WEP 495 Bluetooth headset. I have lost its customer manual. I need its password for pairing it with my NOKIA Mobile handset. Please help me out. Regards and thanks in advance.
The default pass key is 0000 but before entering the key in your mobile, you'll have to enter your wep 495 into a pairing mode which you can do by pressing & holding the call button till the led gets stable.
Thanks & Regards
Vaibhav Y. Dhakate
Oct 29, 2010 • Cell Phones
3helpful
2answers
I want to unlock my sony ericsson w910i fre how
hi friend,
press * and then press the right soft button to unlock if it doesn't works check this out Unlocking your Sony ERICSSON W910i is just the start of roaming freedom. This safe, simple process is one of the easiest ways you'll ever find to save money. The unlocking code and five minutes of your time will enable you to use your handset in ways you never thought possible.
We need only a short time (no more than 12 - 24 hours ) to generate your Sony ERICSSON W910i subsidy code. The sooner you place your order, the quicker you'll receive the unlocking code and be on your way. Both ordering and entering the code are easy. Just follow the instructions.
How It Works
  1. Select your phone and fill out our order form
  2. We will email your unlock code along with easy to understand instructions on how to enter it.
  3. Put in a different SIM card and enjoy your new freedom.
Once you have received your Sony ERICSSON W910i unlocking code, it is very simple to enter it:
  1. Remove the SIM card. Turn your handset ON
  2. PRESS the left arrow ONE TIME
  3. PRESS the * button TWO TIMES
  4. PRESS the left arrow ONE TIME
  5. The message "Personalize with MNC2" will appear
  6. You may now enter the Unlocking Code we sent to you. It may be necessary to PRESS ENTER or OK
    ERICSSON
    -W910i-,K850i-&-W890i-UNLOCK_...%20-">cgi.ebay.co.uk/UNLOCKING-FOR-SONY-ERICSSON-W910i-,K850i-&-W890i-UNLOCK_... -
hope this helps u
thank u for using fixya
please rate me............................
regards
sivaranjini
Hello:HELP ME PLEASE!!!!BIG PROBLEM TO MY K850i!!!
Hi
It would best if you return the phone from where you bought it since your are having multiple issues with a brand new phone, sounds unlikely so ask for a replacement.
Thanks for using fixya
Mother board
hi for a total handset replacement if u are in warranty period u can claim this with the purchase bill in any of the sony ericsson authorised showrooms.. and they will replace u with new handset... thank u rate me!!!
Master reset without using soft keys?
there is no code to make a fact reset on SE fones. But if you have the usb cable you can do it with some free softs.
2answers
K850i
Contact your network for a warranty repair on the handset every mobile phone purchased has a warranty period of at least 1 year and this covers only manufacturing faults . when you contact your network you will be required to go through some checks just to make sure that it is faulty and that it was a manufacturers fault .
But before calling your network leave the phone swithced on and remove the battery and the sim card .
Put the battery back in without the sim .
Turn the phone on .
When the phone has loaded remove the battery whilst the phone is on .
Replace the sim and the battery and see if this has fixed your problem .  If not you will need a repair
3answers
Siemens Gigaset 4200
Hello, Yes this happens when you add a additional handset to the system when all the intercom numbers are full. When registering a new handset, it "kicks out" on of the other handsets when it registers. The only way to correct that problem is to default your base and register each handset again, one by one. You won't lose your handset settings, but you will lose your messages and greetings, so check them before doing so. To default your unit, get all your handsets and go to your base. Unplug the power from your base. Hold down the page/registration key on the bottom of the base and keep it held down while you apply power to the base. After applying power, keeping the button down, count to 20. Then release the button and get each handset. Register each handset, and they will number themselves 1 through 4. If you need additional assistance, service or need to purchase another handset or base (you can register each handset to up to four bases to increase your range, this is unique feature in the cordless industry), you can go to www.cordlessrepair.com for all your Siemens cordless needs. Good Luck ! Let us know how it goes, we have a testimonial page on the website for people to leave comments on the technical tips or assistance they receive from our technicians.
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
