Cars & Trucks Logo
Posted on Jul 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Arter I put on Seat Belt, another chime goes on for 6 rings,then stops
The chime goes on sometime when I go uphill after driving awhile. No sensor lights,no problems ,just chimes at odd times ,always after seat belt chime finishes.
  • Anonymous Mar 24, 2014
    5 chimes in 5 intervals
Anonymous
Level 3:
  • Master 373 Answers
  • Posted on Jul 17, 2008
Anonymous
Master
Level 3:
Answers
373
Questions
Helped
324514
Points
1445
HI.
ON Ford cars and Suv's,
Some times the sound chime after the seat belt buklet.
Is like a open door.
The problem on this car is that the the DOOR AJAR SWITCH. come danaged. and the Body cumputer don't recievethe door close signal.
But is intermitent.
The door ajar switch is on the door lacth.
You only can get front the dealer.
OK. I hope this information can be useful for you.
Thank you.
David Britt
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 10, 2013
David Britt
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
735
Points
Warning chime goes off. The door ajar in the drivers side was malfunctioning but was replaced. Nothing on the display says anything. All is functioning fine.... What else?
1helpful
How to fix or disable passenger seat belt chime? It sometimes goes off for no reason.
There is a switch in the seat that operates when someone is sitting on it. This will operate the seat belt warning if someone sits on it and does not do up their seat belt. It appears that this switch is intermittently faulty. If you remove the seat (usually only 4 bolts) you should find the wires to the switch and can either bypass it or replace it.
3answers
Faulty seat belt alarm
YOU CAN' DISABLE THE ALARM.IS PART OF SRS SYSTEM.BUY FROM YOU LOCAL DEALER BELT BUKAL ONLY AND REPLACE.IS EASY AND LOW COST.
2answers
My warning chime goes off at random.
Check all your seat belt attachments! This seem to be a leading oroblem with all vehicles that has a few miles on them. All it takes is wasting coffie or soda's into one of those locking mechanisms and it thinks the seat belt is not locked. All these vehicles have seat sensors too! If you sat anything more than 3 to 5 lbs on the seat, it thinks someone is sitting on the seat and the chime will continually go off and drive you nuts. Hope this helps you with your problem Sir
2answers
How do I shutoff the seat belt chime ona 2010
Does putting the safety belt on have any effect? Generally the system works by having pressure sensors in the seats. Anyone sat down without a seatbelt on whilst the engine is running triggers the chimes. If you are carrying a box of heavy items on one of the seats this will have the same effect. The only thing is put the seatbelt buckle together.
2helpful
2answers
My door chimer won;t stop ringing it;s driving me crazy help
Look for the plunger coming out of the frame where the door hinge is. Is it broken? When you open the door the plunger is released (comes out) and grounds sending the signal to chime, however this should only happen if your lights are on or key is in. The chime controller may have failed and that's why it also could stay on. Does it happen when the key is in, while driving, or even always stays on? Need more info.
2answers
How can you turn off the Hyundai Santa Fe 2007 seat belt chime
well you could cut the dinger out.. but I would not recommend doing that. Usually it makes more sense to just wear your seat belt as local laws require
Chime goes off
Open the drivers door and look at the hindge area and you will see a black rubber accordian tube between the door and the pillar.This is the protective cover for the wiring harness. Now take a screw driver and stick it into the latch that latches when u close the door and trip the latch. Now start up the vehicle and wiggle the black tube and see if you can duplicate the concern. If so then pull the cover back and inspect the wires for a broken wire. these models are bad for this happening.
2helpful
2answers
1995 Jeep Grand Cherokee seat belt noise and light.
Hi
There is a switch in the seat belt latch whe your sitting in the seat this will ba the part o the right side, see if something went into the latch part? or the switch is bad i think you have to replace the belt to fix the switch
RD
1helpful
3answers
I want to get rid of the stupid door chime.
That door chime was driving me crazy too. It turned out to be really easy to pull the power cord from the chime. If you fold down the glove box by pulling the two plugs out from the inside, you can see the chime up behind the dash just to the left of the glove box. Just pull out the cord attached by removing the clip and you are golden.
Ahhhh. Sweet relief. I have been chime free in my accent for 2 months, and it makes for a much more enjoyable car.
Enjoy!
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
