JVC THR1 DVD Digital home cinema system.
I have the powered sub-woofer & all the surround speakers from a THR1 cinema system. The sub-woofer uses the JVC 8 pin system cable to hook up with the dvd/tuner/recorder.My problem is that I only have the sub & speakers !! Does anyone know of ANY JVC dvd players that also use the 8 pin hook up cable so that I can search for one and get the system up and running? Its a shame that such good looking speakers are not being used !! Please help :-)
Many thanks
Graham (UK)
  • gyarr1 Aug 22, 2008
    I have much the same problem. My DVD unit still works apart from the recording function. I was wondering if it could be fixed at reasonable cost or would it be better to try and replace the unit with another JVC one. Do I have to try and find a TH R1 player/recorder replacement or are there other JVC players that do the same job?
    Graham, Newtownards, Co Down
  • 4 Answers
There is other Cinema Surround systems that use the same 8 Pin setup Aldis had one retailing at £49.99 and there are plenty on E-Bay www.eserviceinfo.com will provide schematics for these systems so you can select the right one.
Posted on Mar 05, 2010
SOURCE:
I wish to replace a subwoofer on a surround sound system
In most surround sound systems the sub woofer is powered separately and uses a standard RCA coax connection to the receiver/amplifier.
Replacing is simply plugging in the new and reconnecting the coax cable.
Usually the audio signal is Dolby Digital 5.1 the (.1) is the LFE Sub-woofer. The connection is between the Subwoofer RCA connector on the amplifier and connects to the (LFE-Line) in on the subwoofer speaker.
Hope this helps?
Aug 09, 2016 | Audio Players & Recorders
Speakers on cinema surround sound working on test only
More than likely the optical connection is defaulting to another source. The optical may have been intentionally assigned to another source and either needs to be reassigned or try switching the inputs on the unit until you hear sound...
Feb 04, 2014 | Logitech Z-5500 Audio Subwoofer Thx...
The left channel on my Nakamichi SoundSpace 8 has suddenly started
  • Complete home theater system with top-loading DVD/CD player, surround sound processor with AM/FM tuner, and center channel amplifier
  • Includes 5 satellite speakers (2-way, 3-drivers each) and dual active subwoofers with 6.3-inch woofers in bandpass enclosures
  • Supports DVD, CD, CD-R/RW, and MP3-CD formats; processor integrates DTS, Dolby Digital, Pro Logic II, and synthetic surround effects
  • Built-in sub woofer amplifiers separately power left- and right-channel satellites to minimize interference and crosstalk
  • Satellites measure 3.1 x 7.2 x 3.9 inches (W x H x D) each; subs measure 8.9 x 20 x 9.6 inches; 2-year warranty
Jul 22, 2012 | Nakamichi SoundSpace 8 System
I recently picked up the THC-c60 system without the supporting amplifier. Can I still use the subwoofer and the speakers without the amp? I note that it also came with a DIN cable, is there some way to...
You can use the sub-woofer and the speakers even without a supporting amplifier. The sub-woofer alone is powered with 167w per channel enough to power all the speakers. The DIN cables used to connect the sub-woofer to any source device like a computer, multi-media projector and others.
Dec 02, 2010 | JVC TH-C60 System
I received an I-HD901 surround system. How do I hook it up directly to my Sony tv and do I need to buy a receiver or an amplifier?
DON'T NEED A SEPERATE AMP THE SYSTEM HAS ONE IT IS PART OF THE CABINET THE DVD PLAYER IS IN, YOU CAN HOOK IT TO THE TV WITH A HDMI CABLE OR STANDARD VIDEO CABLE OR A PROGRESSIVE SCAN CABLE SETUP, FOR AUDIO U CAN USE STANDARD RCA CABLES, OR DIGITAL AUDIO, CHECK TO TO SEE WHAT OUTPUTS AND INPUTS THE TV G THE TV HAS ALSO CONSULT YOUR USER MANUAL FOR THE SURROUND SOUND. HERE ARE THE SPECS FOR THIS SYSTEM.
1000 WATT system total program power
5.1 Cube cinema HTS, 12 active drivers/magnetically shielded
I-Cube design satellite system
4 Multi-directional 2-way speakers()
center channel has 2-way with horn tweeter enclosure (200 WATTS)
Dual sub-woofers 400 WATTS; 2X6.5" aluminum poly-laminate cone
linked through digital custom crossover circuitry finished in: high-gloss piano and composite black w/silver brushed aluminum
complete 6 piece system (HTS surround speakers
Jan 08, 2010 | Sony DAV-S300 System
Connect a new dvd player at the home cinema set??!!!!
You can go for Samsung, Lg or any product of your choice. The most important thing is that you check the back of your old player to see the connections, and make sure the player you are about to by has those connections also so that you would be able to connect your old sub woofer and speaker with the new player.
Nov 06, 2009 | JVC TH-M45 System
JVC TH-M45
no, u cant use the speakers with other normal DVD player because it wont have amplification for the speakers... u can use the sub to other dvd player because its inbuilt 120 watt woofer. ur dvd player is 5-disc player as wel as 120 X 2 and 80 X 3 watts amplifier (AV receiver ).... so just the JVC better sound thru the sub and speakers... ENJOY
kanny_amancha@yahoo.com
www.kanny-sounds.blogspot.com
Jan 24, 2009 | Pioneer 1000 Watt 5.1 Surround Sound...
JVC DVD players
Use a sling for multiconnection to connect 8 pin input;
Sling Media - Slingbox
Jul 19, 2008 | Audio Players & Recorders
Jvc rx-e100rsl home cinema control center
unless there are some other connectors that may be used, i would think that the issue would be resolvable thru the system settings menu, there may be a speaker arrangement setting somewhere in the menus. The Sub is a .1 setting like 5.1 or 7.1, perhaps even 2.1 where the beginning number is the speaker channels and .1 is the sub. I would think with the sub being on a mono channel it woul/should work with any setting. If there is any more info you could supply I will further research this issue and try to help you get the sub working.
Jan 27, 2008 | Audio Players & Recorders
514 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
