Question about Samsung Cell Phones
IT KEEPS TURNING OFF WHEN I PLUF THE USB IN THE COMPUTER AND WHEN IT CHARGERS,FULL BATTERY,IT DIES OUT QUIKC
Reason for this is a short circuit in the board or the charger cable, try buying a battery charger for your battery and see what happen? you can get an after-market battery charger if you search online for it! I brought an used phone one time and charge it over night and when unplug it drop to a full bar to one bar of charge, figure out that the cable was shorted and so i ended up just buying an another battery and a battery charger and it now work fine!
Posted on May 19, 2009
  • 282 Answers
I guess theres a problem with the board of your cellphone,there might be some components that has been shorted out and thats the reason why it drains battery so fast and it shutsdown upon connecting to the usb
Posted on Jul 17, 2008
What is the charging time for agfaphoto 800 1.2v
Charging a battery depends on the battery capacity and the current you use to charge.
The best for a rechargeable battery is to charge it with 10 to 20 % of its capacity. If you choose 10%, you charge for 14 hours and 20 % you charge 7 hours.
Most chargers, charge on a higher current. (quick chargers), but just try to calculate what it takes to get 140% into the battery. That is the maximum time needed to charge.
If after that time the battery is still not "full" or at least the chargere light does not indicate it is finished charging, it could be the battery is defect.
Dec 31, 2014 | Cameras
I charged my droid razr maxx to 100% then battery keeps dying within 15 minutes pls help
Hello My Dear Friend:"::
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 19, 2013 | Motorola Mobility Motorla MOTXT912 DROID...
It keeps turning off
Hello
Try recharging the battery if the MP3 player is not turning on. To recharge the battery, connect one end of the USB cable to the USB port on the MP3 player and the other end to an open USB port on your computer.
Press the "Menu" button if the player keeps turning off periodically. Select the "Settings" option in the Menu and select "Power."
Select "Auto Power Off" and turn off the sleep settings.
Try turning the player back on. If it does not turn on, perform a reset. To do this, press and hold the "Power/Menu" button for at least 15 seconds.
Apr 11, 2011 | Jensen SMP-215 MP3 Player
Hello, I have a laptop Toshiba Satellite A105-S4134 . For some reason it is burning the chargers, I already replaced 3 or 4 of them. Do you know what the cause coudl be , thank you!
check whether your electrical socket where u pluf the charger is earthed or grounded .If its not grounded it will burn your charger
I hope this will help you
good luck
Mar 15, 2011 | Toshiba Satellite A105-S4134 Notebook
My polaroid t831 is completly dead. i lost my battery charger and i only have the computer USB charger left. but it doesn't work at all. I have tried to look online for polaroid chargers but i had no luck...
I found chargers and batteries for this camera by searching Amazon for "polaroid t831". There are also cheap universal chargers that will charge any small camera or phone battery, like THIS ONE
Most cameras don't charge from the USB cable.
Dec 08, 2010 | Polaroid PDC 5080 Digital Camera
MESSAGE STATES THAT BATTERY IS LOW, AND KEEPS SHUTTING OFF. BATTERY SHOWN ON SCREEN AS DEAD.
plug it in to your computer via the usb cable for a few hours, the car and home chargers are not recommended for the initial charge as there only a trickle charge...if it still hasn't charged up using the usb cable, there is probably a problem with the usb port(charging port)
let me know how you make out after charging it via the usb cable that was supplied with the unit.
bill
Aug 20, 2010 | Tomtom ONE GPS Receiver
Trans went out on my 98 sebring, i started every week for a while,then not for several months, the batt went complele dead, replaced with a new 1 now it wont start,just keeps turning over, checked all the...
Did you cycle the key a couple times. Sometimes it needs to reset the computer after the battery dies. Also,try holding the gas pedal to the floor while turning over. This will help if flooded with gas from starting so many times.
Aug 17, 2010 | 1998 Chrysler Sebring
Battery dies when i plug it into the computer
Use a separate card reader instead of the camera.
Jun 30, 2010 | Olympus FE-4000 Digital Camera
Charger
Your USB port must be repaired. In the meantime, hopefully, your computer has another USB port that you can use. Battery is a replaceable lithium ion rechargeable battery. There are battery chargers that you can connect to wall outlets - the type that plug into the computer would probably require that you plug it into the USB port, which you said is broken - so that's a no-go. There are multiple vendors for battery chargers - one possibility is http://www.greenbatteries.com/
-Tha Mp3 Doctor
Jun 02, 2008 | SanDisk Sansa e260 MP3 Player
Cell Phones Logo
77 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
