Question about Ubi Soft Petz: Dogz 5 and Catz 5 Compilation (008888682295) for PC
Petz 5 Ok I'm not sure you know anything about this game but I'll give it a try. on petz 5 i had to delete it but i saved my petz and I downloaded the game again but i can't get my saved petz into the petz 5 file it says it's full I tryd to delete some of the files but it want let me!!!! :( i want my petz back!
Are you importing the files? i don't know. look for a walkthrough
Posted on Aug 22, 2008
Tip
How To Fix A Non-Loading Problem On Petz 5
I have written this so many times, that I decided to make a tip out of it so I dont have to keep answering the same question over and over.
To fix the problem when your loading thing doesnt load fully, and it comes up with an error message, you need to follow these instructions.
a)Save your petz to a flash drive, or CD or floppy disk. NOT to the computor as they will get deleted. (this step is only if you want to keep your petz)
b) Uninstall and click "No" to "Do you want to save your petz?"
c) Install again.
d)Put your petz back on your game, by putting the Flash Drive/floppy/CD into the computor and copying the petz files into the petz folder. (if you kept your petz)
e) Play the game from My Computor, Petz 5, Play.
You will need to have the disk in whenever you want to play for e) to work.
If this doesnt work, ith saving your petz, skip steps a), and d).
Hope this tip helps. :D
on Jul 22, 2009 | Ubi Soft Petz: Dogz 5 and Catz 5...
I need to reinstall the software but don't won't to lose all my pets (one just had 4 babies). Is there a way around this? IS there a file I can save somewhere else, then add it back in when I reinstall?
I can't tell you from experience because I have never played that particular game. However any other game i've ever played where you save your progress, there is always a profile or saved game file.
You will want to open My Computer-->C:/ (hard drive)-->Program files--> Ubisoft-->Petz in there you will find a file or folder with an obvious name (user name, profile name, saved game) something along those lines. Save the entire folder if there is one or just the single file to your desktop, reinstall the game....when you reinstall just make sure you put the file or folder back exactly where you found it.
Note:: You may need to start a new profile when you reinstall, afterward just put your saved file back where it belongs for it to work properly. (Sometimes the game needs to create the profile folder or saved game folder in the directory.)
***** Last thing is when you do uninstall the game it may ask you if you want to delete user settings and saved game files. If it does click no, that way you won't have to worry about loosing your stuff at all.
Hope this helps, post back if you need any further assistance. Thank you for choosing Fixya!
Jul 17, 2009 | Ubi Soft Petz: Dogz 5 and Catz 5...
Petz 5 not working. error message comes up
When you unintall Petz 5 you need to not save the petz, which is an option just before it starts uninstalling. Unistall, Then install it again, and run the game from My Computor, Petz, then play.
hope it works for you.
May 28, 2009 | Ubi Soft Catz 5 (Windows) (680901) for PC
Petz5 won't play or uninstall Plz help!!
Im not sure what you could do about the first half of your problem, but i think i know a way that might fix the second bit.
Uninstall, and click no, i dont want to save my petz, and then continue w/ the uninstalling (and hope it works :p)
when thats finished, install again, and play the game from My Computor, Petz, and play.
hope it workz
Mar 22, 2009 | Ubi Soft Petz: Dogz 5 and Catz 5...
Petz 5 help!
at the moment you either would have to create new petz or try installing the game again. the way to see if you saved them is to go into the saved petz folder and find files of your animals , if they are there unlock and download any zip files and they should do it for you
Jul 18, 2008 | Ubi Soft Petz: Dogz 5 and Catz 5...
Help
Try deleting the game your petz well be saved!!!! and then re install it your petz well be in your files Go under local desk then look at the folders that come out your petz should be in there then press your right mouse button then transfur it to the petz 5 folder now your petz 5 disc must be in the computer! :) oh then just write them on the disc
May 13, 2008 | Ubi Soft Petz: Dogz 5 and Catz 5...
Can't get the sound to work on Petz5
Ok, I got an answer from Daniel Wright, who has SP 2 and this is what he says:
"The solution is easy, go to your Petz 5 installation folder and rename setupapi.dll to something like setupapi.bak - Petz 5 will now load without any problems.
The problem only effects Petz 5 as Petz 4 doesn't include that file, and providing the game is patched it continues to run just fine on XP SP2."
Dec 20, 2007 | Ubi Soft Catz 5 (Windows) (680901) for PC
Dogz 5 Won't Work!
This happened to mine 2. I uninstalled it, but the folder was still there, so I went on search, local disk, and searched ubi soft then deleted it. After that it worked, except I've noticed if you press save pets when uninstalling, it doesn't work.
If I want to keep my pets, I go into the ubi soft folder, adopted petz, then I drag my pets to a new folder I make on the desktop. When the game is reinstalled, I put the pets in the folder back into the adopted petz folder.
This has been the solution for me, but I don't know if it will work for others. Good luck!
Nov 25, 2007 | Ubi Soft Catz 5 (Windows) (680901) for PC
Ubi Soft Petz: Dogz 5 and Catz 5 Compilation (008888682295) for PC Logo
237 people viewed this question
Top Ubi Soft Computers & Internet Experts
 Shayaan Tanwir
Shayaan Tanwir
Frank Zabroski
Frank Zabroski
Piyal Perera
Piyal Perera
Are you an Ubi Soft Computer and Internet Expert? Answer questions, earn points and help others
