Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
Light blinking I just tried to open My Book and it won't respond. The WD icon is gone from my taskbar. When I try to use the shortcut icon it tells me, "Network connection that the shortcut refers to is unavailable. Make sure disk is properly inserted or the network resource is available." The light on the front of the external drive is going off and on, almost like it is on standby but I can't do anything with it. HELP!!
  • 2 more comments
  • edgar1813 Jul 29, 2008
    Same exact problem. Anybody could advise?
  • mumbles420 Jul 30, 2008
    I'm having the same problem as lu73. I clicked on the My Book shortcut icon and it says "The drive or network connection the the shortcut 'My Book (E).link' refers to is unavailable. Make sure that the disk is properly inserted or the network resource is available, and then try again." I'm a photographer and need my client's images A.S.A.P.!!!
  • Todd14 Aug 25, 2008
    hi, i have the same problem, but i just bought it and i haven't even had the chance to use it yet. I can't even look at anything on it and there is no image of it on my computer. Its as if i had plugged nothing in, and the power off and back on fix doesn't even work for me.
  • Anonymous Mar 24, 2009
    My mybook office edition is also blinking. It happened after it froze and I pulled the power cable.
Hey, i just had the problem but i had given up on solving it, so i had left it blinking for a while. After a little bit, a window popped up saying "Driver Software and Updates have been successfully installed and device is ready to use." Maybe the blinking light just means that its looking for updates or driver software or something. Try leaving it blinking with your computer on overnight (with internet connection of course), or something of the sort. Worked for me. Hope this helps.
Posted on Aug 25, 2008
A TEMPORARY SOLUTION IS TO PRSS AND HOLD THE POWER BUTTON..... POWER IT OFF.... UPON RESTART U SHOULD BE ABLE TO GET IN.... I don't know why this is but it's a temporary fix.... It will still happen.... I am looking for a better more permanent answer
Posted on Aug 05, 2008
The best solution for this problem is not using Western Digital and beware of other brand such as Calvary, that use WD drives inside. Probably the best bet is using interior drive that you can see 1st and buy exterior container and install yourself. I keep HD movies on 20 drives and WD has been a nightmare
Posted on Sep 09, 2008
Damn bro, this is the same exact thing that it happening to me right now. I just started doing research on this problem right now. I'm a photographer and I NEEEEEED to get me images back A.S.A.P., so if you have any information on this please get back.
Posted on Jul 30, 2008
Hi have hardrive for 5 months disconected it for going away came back conected back up not working front light keeps on blinking on and off
Posted on Aug 07, 2008
How can i check my ink levels
Hope this will help.
To check the ink cartridge status, do one of the following:
  • Double-click the printer shortcut icon on your Windows taskbar. To add a shortcut icon to the taskbar,
    Open the printer driver, click the Maintenance tab, then click the EPSON Status Monitor 3button.
Good luck.
May 22, 2014 | Epson Stylus DX6050 All-In-One InkJet...
Hi there, I'm using a WD drive with a Macintosh. It accidently became unplugged, or partially so, when my young son brushed up against the plug. Since then it won't mount and there white light on...
Ouch. The blinking light is bad. But try this:
1. Run the WD discover tool
2. Go to "configure" and acknowledge there is a blinking light. This might give you access to the data and drives.
3. If the status says "good" then everything is fine. If not, then you probably have a bad drive and need to contact WD tech support. Hopefully you still have a warranty for it if this is the case.
Let me know if this works!
Aug 25, 2011 | Western Digital My Book Essential 1TB...
I have a WD that i've had for a little more than a year, tonight it won't turn on, it shows an icon in my computer and lights blink very dimly except the bottom one which blinks brighter, i have a...
You can try a free program like Recuva to save your data: http://www.piriform.com/recuva
A good choice for fast remote data recovery performed over the internet is: http://FreeDataRecovery.us
Another reasonably priced choice but you need to ship out the drive is: http://300dollardatarecovery.com
Jul 26, 2011 | Western Digital 500GB My Book Pro-External...
My folder's turned into 1 KB Shortcuts on my 500 GB WD Hard Drive, it seems like memory in my HD is used, but when i click in to open folder it says that file cannot find :(
Well, it's obviously your external WD drive infected with virus which stop you from accessing the data by turning them into shortcuts (such as 1KB or 2KB). This blog article how to fix folder become shortcuts should help you out. Follow the step by step please. Note: do not attempt to format the drive before you try.
Aug 18, 2010 | Western Digital My Book Essential Edition...
My desktop Taskbar is gone!
Bring up the task manager. Click [File] then "New Task(Run)". Type "cmd" into the text field and press Enter. This will open the command prompt.
Dec 08, 2009 | Computers & Internet
Hi There! I am having problem opening my hp director program
  1. Open HP Director using one of the following methods:
    • From the desktop : On your computer's desktop, look for the HP Director icon (c01425509.gif), and then double-click it.
    • From the Windows taskbar : Click Start , click All Programs , click the HP orHewlett-Packard folder, and then click HP Director .
    Although HP Director does not appear to be open , it is open and loaded into the computer's memory, but it does not open in a new window as usual.
  2. Without navigating to another open window, press Alt and Space bar at the same time. The Shortcut menu displays near the top-left corner of the computer. Figure 1: Shortcut menuc00833293.gif If the Shortcut menu does not open, repeat steps 1 and 2 until it does.
  3. Select Minimize from the Shortcut menu.HP Director displays (minimizes) as an item on the taskbar (the row of open software programs that appears at the bottom of the desktop screen). If HP Director does not minimize, click Minimize again until it does.
  4. Click the HP Director icon on the taskbar . The software opens and functions normally.
Dec 08, 2009 | Microsoft Windows XP Home Edition
The adapter to my Western Digital Book does not respond
The monitor requires a adapter with a current output of 4 amps. but the Western Digital Book adapter can only supply 2 amps (half the current required by the monitor).
This means using the WD adapter on the monitor will stress this adapter beyond its capacity and continual use of this adapter on the monitor will cause it to fail and/or switch off if it has overload protection.
If you are having problems with the 2 amp adapter on the WD Book, then the power adapter could be faulty or it maybe OK when the adapter cools down.
I suggest you get a 12 volt 4 or more amps adapter for the monitor.
You may need an adapter for the WB book too if the adapter is faulty.
Dec 06, 2009 | Western Digital My Book Essential Edition...
Hp director does not open when i click on the icon
After installing (MS IE 7 or MS IE 8) browser on the computer that is connected to the HP product,This issue occurs on some HP products. The MS IE 7 or 8 browsers might be incompatible with HP Director
Follow these steps to use a workaround to open HP Director each time you use the software. These steps must be repeated each time you use HP Director.
1-Open HP Director using one of the following methods:
From the desktop : On your computer's desktop, look for the HP Director icon ( ), and then double-click it.
From the Windows taskbar : Click Start , click All Programs , click the HP or Hewlett-Packard folder, and then click HP Director .
2-Without navigating to another open window, press Alt and Space bar at the same time.
3-Select Minimize from the Shortcut menu.
4-Click the HP Director icon on the taskbar ( ). The software opens and functions normally. NOTE: The HP Director window and icons might appear larger than normal, but the software is functional.
5-Repeat Steps 1 through 4 every time you use HP Directo
Thanks,
Nov 30, 2009 | Computers & Internet
Lost dell remote access iconon taskbar
If you still have the shortcut for Dell Remote access in your start menu, right click on it and select copy, then right click on your taskbar and click "Open Folder" when the folder opens click paste.
Mar 18, 2009 | Dell Computers & Internet
Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
1,812 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
