Question about Gateway Computers & Internet
I PURCHASED MEMORY AND HARD DRIVE UP-GRADES FROM GATEWAY. I WAS TOLD THAT THIS WILL CORRECT MY FATAL ENGINE ERROR PROBLEM AT START-UP. THEY SENT IT WITH-OUT INSTALLATION INSTRUCTIONS.
  • 282 Answers
I dont think its a problem with the hdd and the memory,it could only be problem with startup programs on your computer that is corupted,maybe you can provided the complete error message,maybe i can help you out
Posted on Jul 17, 2008
Need help with a error f3f2000002 on my toshiba
That is a fatal hard drive error, possibly damaged sectors. Purchase a new hard drive and install your OS then using a usb sata connector from fleabay, copy what you can from your old drive back to your new drive.
Hope that helps to recover some or all of your data.
Dec 22, 2013 | Computers & Internet
Bootmgr is missing
That is a fatal error and possibly caused by a bad sector in the hard drive. Try starting with your OS disc and select repair.
Dec 12, 2013 | Acer Gateway NV53A36u
Canon MP560 has error code 6C10. What di I do?
There is no fix for this error code. I called canon support and was told it's a "fatal" error and the machine had to be serviced. Since it was under warranty they sent me a replacement and I sent back the broken unit. Canon paid for postage both ways.
Jan 31, 2011 | Canon MP560 All-In-One InkJet Printer
I have a gateway desktop that is beeping before post. It beeps and will not post.
It depends on the motherboard model, but here is an example of the error codes for a gateway:
Beeps Error Message Description 1 Refresh Failure The memory refresh circuitry on the motherboard is faulty. 2 ECC Error Error Checking and Correction (ECC) is supported on this product. 3 Base 64 KB Memory Failure Memory Failure in the first 64 kilobytes (KB). 4 Timer Not Operational Memory Failure in the first 64 KB, or Timer 1 on the motherboard is not functioning. 5 Processor Error Ther processor on the motherboard generated an error. 6 8042 - Gate A20 Failure The keyboard controller, 8042, may be bad. The basic input/output system (BIOS) cannot switch to protected mode. 7 Processor Exception Interrupt Error The processor generated an exception interrupt. 8 Display Memory Read/Write Error The computer video adapter is either missing or its memory is faulty. This is not a fatal error. 9 ROM Checksum Error Read-only memory (ROM) checksum value does not match the value encoded in BIOS. 10 CMOS Shutdown Register Rd/Wrt Error The shutdown register for complementary metal-oxide semiconductor (CMOS) random access memory (RAM) failed.
Nov 10, 2010 | Computers & Internet
MicroSD card has "fatal errors"
hi i have a 4GB microSD memory card in my blackbery and it started not reading properly not it says the memory card cannot be accessed due to fatal errors i now cant access nither pictures oe music on it can someone please help me
Jan 08, 2010 | SanDisk 8GB microSDHC Memory Card with...
Replace a hard drive
Appears that way... try to Boot from a CD or Floppy that will confirm your fear. Most HD will only last 4-6 years.
Dec 31, 2009 | Gateway Essential 400 PC Desktop
No arranca sistema operativo se reinicia
suddenly turn off and set error and change hard drive and does the same when preparing to read the hard drive is restarted --------------------------------------------------------------- The hard-drive has completely failed, or the hard-drive's "S.M.A.R.T." report has sent a message to Windows that the hard-drive is having problems, and that it is soon to fail. You should copy all your files (to a USB memory-stick, or to a CD-R or DVD-recordable) and purchase a new hard-drive.
May 27, 2009 | ECS C51GM-M Motherboard
Will not start, Nonsystem disc error displays
I think this may be a bad optical drive. Can you try an external drive?
Char S.
May 24, 2009 | Gateway Solo 5300 Notebook
Dell tech in who-knows-where told me to reinstall operating sys, XP Home. About half way thru, error message, "Windows detected fatal error, shutting down." Tried 2 times more same message. Help! Dimension...
The fatel error is cause by memory/ and or CPU giveing out if the unit is under warrenty then I would suggest having them diagnose it , if its not then purchase some memory with the same spec's and try reloading again.
Apr 22, 2009 | Dell Dimension B110 PC Desktop
Satellite pro 4600 windows 98 fatal error
What OS are you running on the system? Did you recently install any hardware? If there is a recent hardware install, remove it and try powering on the system on.
If this fails, then you'll need the restore CDs/DVDs from the manufacturer. This will bring the laptop to it's factory default installation. Before doing so, I recommend purchasing a hard-drive enclosure for a laptop hard-drive and backup all important data.
Hope this helps :)
Nov 25, 2007 | Toshiba Satellite Pro 4600 Notebook
Computers & Internet Logo
22 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
