Question about Mitsubishi WS-55411 55" Rear Projection Television
4 pin or 6 pin
Can you tell me if my Mitsu WS-55411 55 inch tv has a 4 pin or 6 pin IEEE 1384 port?
Thanks!
It has neither. It is not firewire capable.
Posted on Jul 18, 2008
How to transter video file to laptop
Do your laptop have a Firewire (IEEE 1384 port)? If yes, get the correct firewire cable.
Camcorder played video into the firewire and you can save as wmv or mpeg depending on your software
Aug 13, 2014 | Panasonic HC-V110K Full HD 38x Long Zoom...
Advice was given to me to buy firewire cable as my sony handycam DCR-TRV22E wont recognize by my mac OS X ver. 10.6.6? what type of firewire shld i buy?
I'm glad to provide the information about the required firewire cable.
All Sony Camcorders are having 4 pin firewire/i.LINK port.
You can purchase a Firewire cable depends upon the number of pins available on the firewire port on the Computer.
If you have 4 pin firewire port in the Computer, you can purchase a 4 to 4 pin Firewire cable.
If you have 6 pin Firewire port in your Computer, you can purchase 4 to 6 pin i.LINK cable.
In rare cases, it may also 4 to 9 pin.
Please refer the manual of your computer or contact apple to get the information about the number of pins available on the Computer.
You may also get back to me with the model # of the Computer so that I might be able to check the pin information.
Thanks for understanding.
If you need any further assistance, please let me know..
Feb 22, 2011 | Sony Handycam DCR-TRV22E Mini DV Digital...
EMac stuck on loading screen
Well i don't know of a fix for the issue u have, but i do have a tip and you might be able to fix the issue you have this way as well. But if you plan on transfering files from one mac to another esp. if one is either an older mac or a portable. you would always want to make one or the other a target disk instead of two stand alone mac's.
Why, because your eMac's older and the data transfer might be failing or can't process the data fast enough to get broken down to bits to be put back on the other end thru the cat5 line. But to transfer files of over 1 GB i would recommend you start the iBook in target disk mode. But since your eMac is the one with some issues put the eMac as the target.
To connect two mac using TDM (Target Disk Mode) you will need to get either a 6-pin IEEE to 6-pin IEEE firewire 800 cable, a 6-pin IEEE to 9-pin IEEE firewire 800 cable, or a 9-pin IEEE to 9-pin IEEE (if your eMac has a 9-pin port) firewire 800 cable.
Then you connect the cable to one of the eMac's 6 or 9 pin ports and the other end to one of the iBooks firewire 800 ports. (the iBook has both the 6 pin a48d559.gif and the 9 pin. 24a3000.gif800 ports) To start up as the target disk you press and hold T immediately after pressing the power on button. once you see the firewire symbol bounce around the screen you can let go. Now its like connecting to a external hard drive.
Jun 18, 2009 | Apple eMac Desktop
No 1384 firewire driver for Panasonic PV-GS300 camcorder
I found the recipe. To get my DV Camcorder to work using 1384 (Firewire) on my computer I did:
1. Get a good cable. If you paid less than $20 for it, you got the wrong one.
2. Ensure that the 1384 (firewire) port is enabled on your computer. Go into the BIOS setup and check to be sure. Mine was OFF!
3. If you get an error with Windows XP not being able to find your hardware, you need to get all the drivers. There are four or five of them along with a configuration file. Miss any one and you are dead. My solution was to reinstall Windows Service Pack 3. This took a long time, but fixed the driver problems.
Feb 17, 2009 | Panasonic PV-GS500 Camcorder
Hi can someone please tell me what i need to convert my old vids
One hour + $45---
Although the View Cams are no longer supported by Sharp most I remember have a digital connection through which the video will upload to you computer. Laptop, desktop or tower? IEEE 1394/ iLink 4-pin or 6-pin? Find the appropriate connection for your computer and go. The Sharp's end should be a 4-pin connector. You computer's native one probably is 6-pin. Any consumer electronics store will have the 4-to-6-pin cable. Cable to computer then cable to turned off camcorder. Turn on camcorder. Windows Media or Toast will handle most simple home projects. No IEEE 1394 on your computer? I get a generic PCI-slot add on card (up to $20 at the same stores), install it and (already have a DVD burner?) ..go!
The alternative path costs about $80.
Take the cam with you to the store. Find a generic A/V cable( a 3-ringed 1/8-inch pin plug[to the camera with video=yellow and 2-channel-white=left and red=right]audio dangling from the other end for a converter) and buy a A>D converter(Turtle Beach, Dazzle etc) that connects via USB. These converters usually come with software to make happen what you want. Good Luck
vac8
Jan 14, 2009 | Sharp Viewcam VL-AH130U Camcorder
Mitsu 65513
I also have the blinking green light problem with my WS-65513 Mitsubishi TV. I would appreciate any information you could send to help fix this problem. Thank you, Keith. elitemachine @netnitco.net
Nov 04, 2008 | Mitsubishi WS-65513 65" Rear Projection...
MY IEEE 1394 port does not recognise camcoder
Although this post is rather old, I can tell you that the mini 4-pin firewire port is the bane of my existence. The 6-pin port is made rather sturdy with heavily shielded cable. The 4-pin uses the same heavy cable, but does not have the strength to support the cable, if it happens to droop. This causes pins to get slightly bent out of alignment, and upon re-insertion, you can get crushed pins if you are not VERY careful. Examine both your cable end and the port on your camera/deck - you will probably find one or more of the pins have been pushed back. Pray that it's the cable that's dead, and not the port in your camera/deck. I have a Canon XL1 and a Sony DSR-40 with the same problem - crushed pin in the unit's port. I'll have to spend $$$ to get these ports replaced.
May 17, 2008 | Panasonic AG-185 Camcorder
That damn blinking light
If you can solder and know alittle about electronics, you can DIY
Jan 05, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WS-55411 55" Rear Projection Television Logo
65 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
