Question about Kenmore 47722 / 47724 / 47729 Electric Double Oven
790/9546/1990 Kenmore Electric Range
How do I set my oven to start at a given temperature at a given time of day and for a set duration before turning off? Can't find my manual.
    Scholar:
  • 170 Answers
Here's a link that you can order your manual from: http://www3.sears.com/. Good luck!
Posted on Jul 21, 2008
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
2 hobs on my electric cooker are not working
Fixing Electric Stove Burners that Don't Heat Up Properly ...
? 2:34
www.youtube.com/watch?v=GfqaPcha__o
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
Electric Range Stove Repair: How To Repair Burner ...
? 6:52
www.youtube.com/watch?v=ndQU7RtqfRw
Jan 31, 2012 - Uploaded by applianceassistant
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
I have a kenmore oven. Just got an F2 error and the oven element will not turn off. Even when powered down, it heats back up when oven is in off position.
Range "Older Style"
F2 Oven too hot Replace relay board (if present) or oven temperature sensor
Range "Newer Style"
F2 Oven temp sensed; over 600F sensed by control in time of day mode, bake mode, or over 900F sensed in clean mode. Ohm test the oven temperature sensor, if OK, change power relay board.
Oct 17, 2012 | Kenmore 40494 / 40495 / 40499 Electric...
What does error E1 F3 mean kenmore range oven
Hi....F3 Open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Apr 12, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Have a Kenmore electric drop-in range less than 2 years old. Turned on self-clean cycle but after an hour or so started beeping and F3 was displayed. Have lost manual.. What does f3 mean?
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Aug 04, 2010 | Kenmore 42161 / 42169 Electric Single Oven
Display on kenmore electric double oven flashes F3 soon after setting temperature and oven turns off
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%%
Jul 19, 2010 | Kenmore 41389 Electric Double Oven
40494 / 40495 / 40499 Electric Single Oven: have a kenmore self cleaning electric range it was...
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
May 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore double oven flashing "door locked"
Jul 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric range F5 and F3 warnings
May 13, 2008 | Kenmore 30169 Electric Single Oven
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Kenmore 47722 / 47724 / 47729 Electric Double Oven Logo
201 people viewed this question
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
