SOURCE: Need float height specs for 82 XS400J and 78 400 special
Alas I could only find a link to a manual for $10...
May be worth it tho if you plan to kep the bike for a long time??
http://www.tradebit.com/tagworld.php/yamaha+xs+400+seca+workshop+repair+service+manual+download
SOURCE: need to know the correct float level on my 85 400
32mm
You can download the service manual from:
http://www.files.pioneerx.co.uk/view.php?file=Motorbike%20Files/XS360-400/Yamaha_XS360_400_Service_manual.pdf
SOURCE: setting float level on HSC40 Hitachi carburetors on 1986 Virago
I have a 1982 Virago 750 that I just did a carb rebuild to. To set the float levels I built a jig from wood that simulates the position of the carbs when mounted on the bike. This jig clamps into my bench vise. I created a fuel supply using a small funnel and a piece of fuel hose mounted above the level of the carbs.. After that all you need is a short length of transparent fuel hose to attach to the drain on the bottom of the float bowl to provide the visual indication of the float setting. Now you are ready to set up the float levels on your bench. This is way easier than trying to set them up in the bike.
Make sure that the jig is set up so that the carbs sit as level as possible across the pair and that they sit as close to the natural position in the bike in the lengthwise position when the bike is sitting level.
The process of setting up these floats can be very tedious, be patient. It may require that the float bowls be removed multiple times to get it correct (I replaced the philips head machine screws with allen head screws to make this easier). Printed instructions for the procedure look for a certain fuel level setting plus or minus 1mm. This kind of tolerance can be quite difficult to get when the only adjustment you have to work with is to bend the metal tang on the float assembly.
SOURCE: just need the height setting for the floats the
YOU CAN ADJUST FLOATS WITHOUT SPECIAL TOOLS. ALL YOU NEED IS A FOOT LONG PIECE OF CLEAR TUBING, SIZED TO FIT THE BOWL DRAIN. SET FLOATS AS CLOSE TO WHAT THEY WERE WHEN YOU REPLACED IT. INSTALL THE BOWL AND PUT THE TUBE ON THE DRAIN. OPEN THE BOWL DRAIN SCREW WHILE HOLDING THE TUBE UP BESIDE THE CARB. WHEN YOU GET THE TUBE BESIDE THE CARB ASSY., THE GAS IN THE TUBE SHOWS YOU THE EXACT LEVEL OF FUEL IN THE BOWL. FROM THIS YOU CAN MAKE ANY ADJUSTMENTS NECESSARY FOR CORRECT LEVEL. THE LEVEL SHOULD BE RIGHT BELOW THE PLANE WHERE THE BOWL MEETS THE CARB BASE.
