SOURCE: blue screen
this problem is due to blue video circuit. 1 Please check supply to blue video ckt. 2 check crt base for loose. 3 check loose contact & parts related to blue cathode. 4 blue signal coming from processor to blue video. 5 processor it self. 6 at last if tv is very old than check crt also.(possibility is rear) hope this will help.
ull have to remove the back of the tv cover and try solidering it back
SOURCE: screen goes white
you may have a solder joint or an electronic part that is beginning to fail. have an electronic expert look at it.
SOURCE: I have a 13-15 year old sharp tv that will worksome times
well if you really love this set,then i suggest you change all or most of the fast switching diodes,usually 1n4148 Nte519 mainly around the micro,video and abl circuitry.Also alot of capacitors especially the ones around heat sources,eg heat sinks and wirewound and flame proof resistorsI.If you want the service manual for the set,i have over 1000 sharp schematics,i am sure i have that one.Please request it at [email protected]
