Question about Vacuums
Beam Central Vac Breaker Pops
The breaker on our beam model 167 central vac popped while in use. every time i try and restart it, it immediately pops again. What's the problem? Circuit board? Motor? overheating?
  • Anonymous Mar 23, 2014
    green light is on , and the motor will not turn on ?
    New Friend:
How to install a new circuit board?
Posted on Apr 06, 2015
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=797869
Generic problem for all Vacuums
Posted by tinateggart1 on Jul 17, 2008
The breaker on our beam model 167 central vac popped while in use. Every time I try and restart it, it immediately pops again. What's the problem? Circuit board? Motor? Overheating?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Chances are it is the relay switch on the inside of the Beam Central Vac, if it was a motor, it would not turn on @ all. If it was a circuit board, it may or may not be turned on, but if it will turn on and then pop your circuit breaker than it probably is the relay switch. Please, check with your local Beam vacuum cleaner dealer in your area or contact the Beam website or cust serv @ the phone number listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.beamvac.com/usa/ Owner Support
Customer Service 1-800-369-2326 Phone #
Email: beam.dir-support@beamvac.com
Technical Support: beam.tech-info@beasmvac.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 18, 2008
I have a 4 yr old vx6000c central vac that constantly blows house breaker
This unit requires a 15AMP 120 VOLT dedicated circuit. If there are other appliances or items on this central vacuum circuit, this could overload the circuit causing it to pop. The other issue that could be occurring is that the central vacuum is on a GFI circuit or ARC fault circuit. Central Vacuum Units are not designed to run on these types of electrical circuits.
Please visit our website if you need a replacement part or if you have more questions. Or give us a call at 1-800-533-3249
Don't forget to like and visit our Facebook page.
https://www.facebook.com/QualityHomeSystems/
Jun 06, 2014 | Broan-NuTone Vacuums
Trips
The switch could be bad. Make sure there are no clogs anywhere that could be causing it to overheat. Try to bypass the switch and run it just long enough to see if you can go longer than the normal 5 min. you're getting. If you can then replace the trip switch. Do not continue to use the machine without the trip switch operating properly or it could catch on fire.
Jul 20, 2010 | Beam Industries 2900 Serenity Plus Central...
I have to reset my Beam Central vac quite often!!!
Check to see if there is a clog in the system. Something is causing stress on your motor causing it to switch off. Or it could be the motor itself failing.
First check for a clog, if you can't find anything wrong, call Beam for assistance
Aug 21, 2009 | Vacuums
Problems with Beam central vac
My Beam central vac has started turning off after about 10 minutes of use. I thought it was the hose, but the hose in the garage does the same thing, and I've also tried the other outlets, and the same. The canister was just emptied about two weeks ago. I have also reset the breaker, and unplugged and replugged in the system. Could this be a bad motor?
Feb 22, 2009 | Beam Industries 2775 Serenity Plus Central...
Central vacuum power head no work
Looks like a Beam central vacuum www.beamvac.com, and a Kenmore vacuum head.
Reply what problems you are experiencing and I will try to help.
Jan 23, 2009 | Vacuums
I need a new hose for my Electrolux central vac
Do you need a new powerhead too or only the hose? If you need a new powerhead than I would recommend looking at the Imperium Pro Elite Attachment set. It is an excellent quality powerhead and hose. If you only need a new hose than you will need to contact the Aerus because they will be probably be the only company who can sell you a hose that wil be compatible with your powerhead. Their website is http://www.aerusonline.com/products/
Jan 21, 2009 | Electrolux Central Vacuum
Do you know what a filter bag looks like in a central air vac system?
The unit displayed is a Beam Electrolux central vacuum power unit. It has a 15litre dust bucket which does not need any dust bags.
If you take the bucket off you will notice a white shiny weighted bag hanging down. This is the filter. The good news is, it is a self cleaning filter.
Dec 03, 2008 | Beam Industries 2775 Serenity Plus Central...
Kenmore central Vac - where to connect low voltage wires?
Mosy central vacs have 2 spades close together that stick out on the side, usually where the circuit breaker and auto/manual switch is. This is where you plug the low voltage wires into.
May 13, 2008 | Vacuums
Wireing up central vac too braker box.
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=579196
Wiring up central vac too
Posted by brneault on May 08, 2008
Wiring up central vac too breaker box.
A central vac not knowing the brand name or model # uses regular household current and plugs into a regular household inlet and I have never heard of wiring the central vac to the breaker box. The central vac is usually out in the garage or down the basement and will be in the regular household current. You may want to ask the manufacturer or the vac dealer you purchased the central vac from and they might have more information for your and if your central vac needs to be wired to the breaker box they will give you instructions, but I don’t believe that you need to do so. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
May 08, 2008 | Vacuums
I have a one year old Beam central vac. It has supervalves. The handle (connected to the hose stopped turning on the unit. The handle still powers the brush but no longer turns on the suction?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=566201
I have a one year
posted by jon89 on May 02, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Beam Central Vac may have more than a one year factory warranty and it sounds to me that you may have a bad relay switch the Central Vac, if you do it should be covered under the factory warranty. Otherwise, you may have a bad supervalves or a wire came loose, if the hose switch turns on the power nozzle then it may be a bad supervalve or a bad relay and to contact the installer or the manufacturer of Beam. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Vacuums Logo
561 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
