Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Lamp Light flashing Yellow
Hello all!
I found this forum searching around online and I have not found 1 person with my problem!!
I have a Mitsubishi DLP WD-62525.
I turned on the TV the other day and it said that the lamp needed to be replaced. Ok no big deal. I ordered a bulb online. It was NOT the assembly. I simply pulled the old bulb out of its "assembly" and put the new one in. I put it into the TV and then plugged it in.
I hear a click which sounds like something is trying to power on or something like that. I hear a click (the power light comes on for about 1 second tops) then nothing. the only thing you can see is a flashing yellow light (the one that says lamp). I've tried to hit the reset button but that didn't work. I tried calling around to several people in town and no one seems to either want to help or has any idea of what the problem is!
ANY help is appreciated!!
Thanks!
Matt
  • 103 Answers
Double check the lamp.make shure the 2 wires were installed correctly.Also check the plug inside the tv where the lamp plugs in.They have a nasty habbit of coming loose.
Posted on Jul 17, 2008
rylee_smith
  • 8619 Answers
SOURCE: MIT WD-62525 DLP TV blinking green light on front won't stop
Hi!
It means your TV needs to reset. Although you have reset it previously, now again reset the TV as per procedure given below:
Please press the SYSTEM RESET button on the front panel with a pointed item such as the point of a ball point pen or end tip of a paperclip.
The TV will turn off and the green LED will flash quickly for about one minute. After the green LED stops flashing, turn on the TV again. The changes you made while the TV was most recently on, before you used the SYSTEM RESET button, may be lost; the changes you made previously, however, are not lost. Only those changes since the last power on may be lost when the system reset button is pressed. All other settings are retained.
TV Reset Menu
Read on-screen warnings before proceeding, as some user data or settings may be erased.
1. Press TV MENU and then 1, 2, 3 to see the RESET SERVICE MENU to reset the TV.
2. Select Reset System Defaults (CAUTION: All settings, except V-Chip, will be reset to the original factory defaults.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 20, 2009
Slinteriors
  • 8617 Answers
SOURCE: getting error code 12 on mitsu wd 62525 dlp tv.
12 means no error detected. What are the symptoms of the set? If its the blinking led thats the DM caps which have failed.
Posted on Jun 16, 2009
SOURCE: Mitsubishi WD-62525 DLP has no picture
the lamp went out in our wd-62525. I replaced it and cleaned the filter, now it makes a strange noise every few minutes and the picture gets distorted, then it's fine.We have had this set for only 16 months and have had to replace the mother board. What do you think the problem may be?
Posted on Feb 18, 2008
rulds2008
  • 3866 Answers
SOURCE: cannot turn tv on
Check power supplly make sure its not the fault in wht this will not turn on.
Unplug tv from wall wait 30 secounds and plug back in.
If that does not work you will need to have someone look at the powersupply.
Posted on Jul 01, 2009
  • 60 Answers
SOURCE: MItsubishi DLP HDMI HDTV WD-62525 Steady RED
  1. Call Mits. and see if they will cover the main chassis rebuild then call an authorized service center to pull the chassis will take 4-8 weeks for it to be rebuilt but you will be resposible for labor
Posted on Aug 25, 2009
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Wd-60737 mitsubishi blinking yellow status light ?
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Oct 25, 2012 | Mitsubishi WD-60737 TV
Misubishi wd-52631 DLP TV, it shuts off suddeny. when turn it on again, the green power light is flashing, then steady green, then shut off again. the lamp light is NOT falshing or red. the status light...
Hi, have you replaced the lamp after 2-3 yrs of usage? The lamps used by mitsubishi tend to last around 4000 hrs 1-3 yrs.It is common for the green light to light up.Other common failures are the ballast which is the board that powers the lamp.Also check if its not overheatin, dust out the fans.Heres where u can get the lamp or ballast http://www.discount-merchant.com/SearchResults.asp?Search=wd-52631
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
Lamp light is yellow. Replaced bulb still not working1
CHECK AND MAKE SURE THAT THE LAMP DOOR IS SECURE ON THE BACK OF THE TV.
Dec 16, 2010 | Mitsubishi WD-57733 57" HDTV
I installed a new lamp, but my tv doesn't come on. The lamp light keeps flashing yellow.
Could be Bad Ballast,or defective cooling Fan, Lamp fan.
Encompass Parts Distribution 1-800-638-3328
If Lamp Fan is not running when lamp trys to come on TV will turn off in order to protect the Lamp
The Ballast Board is what turns the Lamp ON.
Sep 24, 2010 | Mitsubishi WD-65732 65" Projection HDTV
Just replaced the lamp. no picture yellow light flashing?
There may be a capacitor issue with that unit. Here is a link to a thread on help to repair that if it is an issue.
http://www.techlore.com/forum/thread/20256/Mitsubishi-WD-52525-has-a-continuious-blinking-light/
Apr 26, 2010 | Mitsubishi WD-52525 52" Rear Projection...
TV will not turn on
the tv sucks and is a total ripoff . i have the same one.
Jan 07, 2009 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
413 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
