Samsung CXN2085TP 20 in. TV/VCR/DVD Combo Logo
Anonymous Posted on Jul 17, 2008
Record to vhs with converter box
I hooked up my new converter box in addition to my rabbit ears antenna, and now I get a nice digital picture on my TV but the VHS records w/o the converter.
Can I get someone to rewire this TV, or do I need to give up on recording?
  • lakeit Feb 10, 2009
    I have a Daewood vcr/dvd player with an RCA tv and converter box. Can I record one show while watching another?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 18, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
328
Points
I need to leave my TV on channel 3 and set the converter to the channel I want to record. When programming for future recording, it's always from channel 3, not the channel I want the converter displaying.
HOW TO HOOK UP A ANTENNAE
Well you can follow the below steps -
1. Inspect the antenna for any signs of damage. Identify and examine the power adapter cord and the coaxial antenna cable for any rips tears or other defects.
2. Plug the adapter into the antenna's power adapter socket. It will be labeled "12V DC/Adapter". If you are using an antenna that does not require power, such as rabbit ears, you may skip this step.
3. Next connect the antenna cable to the television using the TV's "Antenna In/75 Ohm" input jack. Make sure the antenna connector is twisted tightly into place. Place the antenna on a sturdy surface such as the top of an entertainment center. If you have an older analog TV that is a non high definition ready/capable display and are using a digital to analog converter box, generally, the antenna will plug into the input of the converter and the output of the converter will plug into the antenna input of your TV.
4. Plug the antenna's power supply into a 120V AC wall outlet. This will turn the antenna on. If you are using the "rabbit ears" style antenna, make sure that the each section of the antenna is fully extended. This will give you the best reception.
5. Turn on the TV and check for digital reception. You will know that you are receiving digital signals because the picture will be clear and free of any analog "snow" or other artifacts. Digital TV channels have DVD quality picture and sound.
Follow the below link for more help -
http://www.wonderhowto.com/how-to-hook-tv-antenna-094240/
Good Luck!!
2answers
Finds no channels
It is meant for Rabbit Ears or Outside Antenna Only.....
I have a Magnovox video cassette & dvd player combo, model # DV200MW8. I have an RCA analog TV with 1 cable port in the back and 3 RCA jacks ports. Previously, my Maganavox VCR/DVD player was connected...
omg , haven't heard the word VCR in decade.
are you kidding? seems not.,
what's next 8track tapes? and Beatles? LOL ! "hard days night?"
omg 2, rabbit ears,, im blowing out a gasket laughing...
vhf/uhf analog tv is gone. now. (FCC rules ,dead) HDTV sure.
please say what you are up to the job.?
are you trying to burn VHS tape to DVD? nah.... that be me 16 years ago.... then gave all my VHS away at work. hated VHS, ugly mess.
i see, says the blind man!
you need a switch box.
yes, they still sell them like on ebay but not walfart.
2helpful
Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
We have a new HDLCDVD220 Sansui television. The rabbit ears antennae we were using on our old tv worked ok, but on this one. its awful. There is almost no color and terrible reception. We were told to get...
You mentioned rabbit ears for old tv, how old are the rabbit ears? Time and humidity will make rabbit ears lose connections internally. Also, if your old rabbit ears have the flat cable going to the tv you probably had to add a converter to go to the new tv. The flat cable will lose signal strength were ever the cable touches metal. Also the adapter will cause signal lose. The best bet is to buy an amplified indoor antenna. You also may try a paper clip and about 3to4' of small gauge wire put the paper clip (bend out to fit) into the center of the antenna in on the tv have the wire connected and let it hang or lift it to see how the picture improves. The problem with rabbit ears is that you have to use war time tactics. Crawl on your stomach and adjust to best picture, if you stand and adjust the signal is usually reflected off your body and will be nice until you walk away.
2answers
Need to hook up dvd/vcr combo with converter box
Connect your rabbit ears to the Insignia. Connect the Insignia to the antenna input on the "cvd/vcr combo". Now turn on the television to show the "cvd/vcr combo".
The Insignia simply goes between your antenna and your television. In your case you also have a vcr so if you want the VCR to be able to play and record digital stations you will need the Insignia between the vcr and the antenna.
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
3helpful
Rabbit ears to digital conversion box
Your TV is old enough to have not only screw terminals for the antenna, but it sounds like it has separate UHF and VHF terminals as well. Pick up a 75-ohm to 300-ohm adapter (available at Radio Shack and probably most other places that sell TV's and antennas). This is a small cylinder-shaped part with a threaded antenna connector on one end, and a flat wire with two terminals on the other end. Connect the cable from the converter box to the round connector, hook the two terminals to the VHF antenna screws on your TV, put the TV on channel 3 and you'll be set.
You should also pick up a new antenna designed to work with digital broadcasting. If you use the old rabbit ears you were using before, you will probably not pick up all the channels available in your area.
6helpful
3answers
Hook up old tv antenna to converter box
how do you hook up a tv with just screws to a converter?
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
