Question about Epson Office Equipment & Supplies
I have a epson stylus cx7400, mod c351b, ser k47y234996 I think we had a printer jam, I made sure there was no paper jamed in machine, opened top and turned off machine, turned it back on a still have a e flashing and the on and stop lights are flashing. How do I clear the machine and is it still in warranty.
  • radkfloyd Sep 03, 2008
    I have an Epson CX 7400 and it will not load the paper. You put the paper in and it acts as if it wont feed straight. It tries to load ,but the paper will not load. I have tried one sheet and several sheets. It acts like it is jammed but does not say it is. It takes and tries to load but will not shot the paper on down. Can anyone help?
  • 48 Answers
Contact epson to get a replacement... its an internal, probably a logic board issue
Posted on Jul 18, 2008
Paper jam
Epson stylus paper feeder keeps jamming
Feb 16, 2014 | Epson Stylus Sx535wd
My Epson R230x printer get paper james and not feed paper, how can I solve or repair this problem
i want to know. printer back side some gape i see. but i don't know which work do in this back side.
Nov 04, 2012 | Epson STYLUS R230 InkJet Photo Printer
Jamed paperc86 paper is jamed
Epson Stylus InkJet Clear a paper jam in printer
Jan 05, 2012 | Epson Stylus C86 InkJet Printer
Paper jam light keeps flashing, but no paper jam can be seen. Won't print .`
Open your printer paper feeder. Then look inside it. There is plastic roll inside it. That is the curlprite. Try to open it. at the last stage you may see a spring that usually is in the plustic rollar's holle. Remove it and re assemble carefully. That's ok.
I think you will be relive from your printer problem.
Thank you.
Jun 15, 2011 | Epson Stylus CX7400 AllinOne InkJet...
I HAVE A EPSON STYLUS SX218 IT IS ALWAYS SAYING PAPER JAM EVERY TIME I WANT TO PRINT AND THERE IS NO PAPER JAMED IN IT . IT IS ONLY 1 MONTHS OLD.
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Apr 12, 2011 | Office Equipment & Supplies
Keeps jaming on the right every time
Follow this step to clear the jam
press the diamond shape button start button to eject the jammed paper. If the jammed paper is not ejected, go to the next step.
if the paper is stuck near the sheet feeder or output tray, gently pull it out.
If the paper is stuck inside Epson Stylus CX7800, press the power on button to turn it off. Open the scanner and remove any pepr inside including any torn pieces. Do not pu;; it backward beacuse this can damage the sheet feeder. Close the scanner, then turn the epson stylus CX78oo back on.
Nov 17, 2010 | Epson Stylus CX7800 All-In-One InkJet...
I need to restore the software for my Epson Stylus CX7000f PRINTER in my new computer. I can not find the original disk, from where can download the software
The Epson Stylus CX7400 Color All-in-One printer prints up to 28 pages per minute of black ... Stylus CX7400 ink jet all-in-one, 69 black ink cartridge (T069120), ... Best of all, you don't need to wait for an available computer to get started. .... Also, given my experience, one paper jam can cause your printer to ...
www.amazon.com/Epson-Stylus-CX7400-Printer.../B000SDXZX8
Jul 16, 2010 | Epson Stylus CX7400 AllinOne InkJet...
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Whats going on with my printer
Replace paper feeder. Or find at aicaxz solutions about fixing paper jam without replacing.
Sep 17, 2009 | Epson Stylus Multifunction Inkjet Printer/...
177 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
