42PF7321D/37 LED Light Blinking RED
I have the Philips 42" model and the LED Light is blinking RED 1 Long Blink followed by 1 Short Blink. Can someone tell me what this means and how difficult is it to correct the problem.
  • kmkj4him Aug 11, 2008
    My 42PF7321D/37 is about 18 months old - picture went out, first the top half, then the bottom half - the LED on the lower left hand side just blinks red. Philips no help - repair man says he's not sure may be a bad logic board or panel - logic board is about $300 plus labor, panel is about $1000. Anyone have any ideas - I can change boards if I knew which one.
  • invjchatman Oct 14, 2008
    I also have the same problem. First I would push the power button and the green LED would come on, but no picture. Shortly after the green led will turn a blinking red. Maybe after a couple hours the tv will decide to pop on. However, every time we turned it off we would know if it would come back on. So we left it on without turning off the power for about 3 days and the tv just shut off. This was two weeks ago and it has not come back on. Just a blinking red led.
My dad had this happen too. after some research, we found out that there are two capacitors on the power supply board right next to the connector for the main logic board that went bad. you can just pull those out and solder in new ones, and it works like new again! i found a repair kit on ebay for $35 including shipping, and that's all it took!
Posted on Feb 16, 2010
Philips Flat Panel model 32PF7320/98 error code.
4 blinks is according to the manual... POR bit / +8 V protection
In other words the 8 volt DC power circuit is going into shut down, so you would need to troubleshoot that part of the power supply
Dec 01, 2017 | Philips 32PFL3403D/27 32 in. LCD TV
Philips 42 plasma flashing blinking 4 red lights 42PF7321D/37 screen does not come on need help thanks
philips2_bing.gif 42 plasma flashing blinking 4 red lights 42PF7321D/37 screen does not come on need help
Apr 26, 2010 | Philips Televison & Video
I have a 42" philips plasma with 8 red blinks
90% of the time this is capacitor related in the power supply, Remove the back and check for capacitors that are domed shaped on top, Replace these and all should be ok.
Mar 05, 2010 | Dell W2600 26 in. LCD Television
No power to my Phillips 42 inch Plasma 42pf7321d/37, just a red blinking light
Most likely it going to be a power supply related problem. The red blinking light is a code for a TV tech to diagnose the problem on the power supply board itself or the board that regulates the power for the screen. Some manufactures call it a Backlight Inverter Board. A TV repair shop should be able to look at it for you and tell you which board is bad.
Replacement boards can be found at a good price at Shopjimmy.com
Sep 05, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
TV does not turn on, blinking red LED
Problem is a bad audio IC esp if your are reciving 11 blink code
if it is a 5 blink code replace Crystal 1h00 On Ssb new part number is 24225430 1397
Jan 12, 2009 | Philips 42PF7321 42 in. Plasma HDTV
Philips 42pf7321d/37 blinking power board question
The probleis with one of the maina boards and trouble shooting would have to be done to see which board is bad.
Aug 17, 2008 | Philips 42PF9630A 42 in. Plasma Television
Power problem for phillips 42 plasma 42pf7321d/37
That blink don't mean nothing. Measurements need to be made. Don't just buy the board troble shooting would need to be done to see witch board is bad. Also look on the fron of the set and see how many time the led flashes. That wher your error code comes from..
Philips 42PF5321D/37 Error Codes
replacing ssb for 4 blink error was correct as error is communication failure specific to micro processor on ssb. getting an alternate error after replacing ssb would suggest either wrong ssb or defective ssb. verify vendor number on ssb tuner on original and new ssb and if same reorder that board and if not order per original board
Jun 30, 2008 | Philips 42PF9630A 42 in. Plasma Television
Televison & Video Logo
804 people viewed this question
Top Televison & Video Experts
