Can not tune in my LCD tv Bush 15" HD Ready LCD TV. IDLCD15W008HD a rectangle box moving slowly on screen with the words DTV no input it is the same on TV mode HDMI mode or scart mode even though the aeril is plugged in please give me assistance thank you.
  • 1 more comment
  • david strong Jul 18, 2008
    can not tune in my LCD tv Bush 15" HD Ready LCD TV. IDLCD15W008HD a rectangle box moving slowly on screen with the words DTV no input it is the same on TV mode HDMI mode or scart mode even though the aeril is plugged in please give me assistance thank you.
    can not tune in my LCD tv Bush 15" HD Ready LCD TV. IDLCD15W008HD a rectangle box moving slowly on screen with the words DTV no input it is the same on TV mode HDMI mode or scart mode even though the aeril is plugged in please give me assistance thank you. I know the tv aerial is in good working order please help.
    can not tune in my LCD tv Bush 15" HD Ready LCD TV. IDLCD15W008HD a rectangle box moving slowly on screen with the words DTV (no input) it is the same on TV mode HDMI mode or scart mode even though the aeril is plugged in please give me assistance thank you. I know the tv aerial is in good working order please help.
  • 818 Answers
Look for a Elect. capacitor somewhere close by and check it. Check for component that could be shorted.The reason why the resistor burn and decrease in value is because the wattage value was larger than the value of the resistor value
Posted on Jul 18, 2008
  • 2,071 Answers
To disable the Demo mode, perform the following:
  1. Turn on the TV.
  2. Simultaneously hold down the Vol+ and Vol- buttons on the front of the TV. Do not use the remote control.
  3. Hold for about 6 seconds
  4. Certain model TVs may turn off, others will not. But in either case, the Demo mode should be disabled.
  • 6,487 Answers
This can be a problem with your antenna, that may not be receiving a good signal try adjusting yoru antenna...
Hope that helps.........
Posted on Jul 17, 2008
    Scholar:
  • 101 Answers
If you are trying to view TV channels, you might have to run a channel scan, check your user manual to see how to do a channel scan. Or just go into the menu and I'm sure it is there under channel setup or some name like that. I hope this helps you.
Why does my bush 32 inch tv screen lines
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 01, 2014 | Bush Industries IDLCD15W008HD LCD TV
Tuning in skyview box to bush television
hi, how is it set up, are you using a scart lead or a hdmi lead if your using a scart lead you need to select av 1 or ext1 if your using hdmi lead you need to select hdmi 1, come back to me if your still having problems thanks.
regards
shaun
Apr 06, 2014 | Bush Industries IDLCD15W008HD LCD TV
When I switched on my Bush Television this morning there was no sound, what do I need to do to get it back. This has never happened before. Thank You
Switch off power remove plug and keep aside for an hour. Now after reconnecting if there is no sound you need to test the audio input and audio output to confirm if the fault is relative of the preamp or the power output amp. connect an input source to TV and another from TV output to Amplifier.
Once confirmed then the section can be checked , for power supply failure or the processing section IC.
Sep 15, 2011 | Bush Industries IDLCD15W008HD LCD TV
My TV signal source is a cable/satellite digital box. The setup screen correctly takes me as far as "Select correct input source for set top box." At this point - instead of leaving the...
I would suggest using dedicated input button on remote, not the menu on the tv. If you can skip setup screen that would be best. I have just looked at the manual for that tv, it tells you all you need to know, depending upon which input you used for your box. As I stated use the direct input button on the remote if you have it.
Oct 12, 2017 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
I have a samsung tv and dvd player and it has just started coming up on screen when i load a dvd to play a region error messagesayinh no good.It has been working ok before this.i just recently upgraded my...
make sure your tv is set in right language and location because after the big re-tune you might of entered wrong ones
the best way to do this is reset back to plug & play put tv in analog mode press TV/DTV on remote and then MENU ( NOT DTV MENU ) move down until you see plug & play in one of the menues press enter and follow on screen instructions
Nov 07, 2009 | Samsung LE32R72BX 32 in. HD-Ready LCD TV
Bush TV and Setting Default Inputs
Not an expert on this model but generally if you switch the TV on by pressing the remote's power button it will come back using the input you previously used. If you press a channel button it will come back to DTV.
Jul 19, 2009 | Televison & Video
Dose my tv (Hisense TL3000) is hd-tv ready
Not all units were fitted with the DTV tuner before the switch over occurred. you set should have an insignia that sates that it is DTV ready. if this insignia is not on the box or actual set, you will need a converter box to receive this DTV signal.
Jun 21, 2009 | Hisense TL3000 30 in. HD-Ready LCD...
Have a vizio lcd tv . can not get any channels today with the switch over to digital. i use an antenna
Your TV probably does not have a digital tuner connected to the DTV/ANT input. Mine didn't. I had to connect the digital antenna to a digital converter box THEN go to the DTV/ANT input. Only then would it activate the DTV menu and allow me to scan for channels. If your TV worked fine with Cable TV connected to the input, it was because your signal was coming from the digital tuner in your DVR, or your cable provider was sending you an unscrambled digital signal (not likely).
I used a digital converter box I had purchased with the government $40 coupon back in 2009 but the resolution is only 480 and looks like a Monet or Renoir. Now I am shopping for a high quality tuner.
Jun 13, 2009 | Vizio L32 32 in. LCD HDTV
How to tune my digital chanels in my bush lcd tv
i just saw a post which I believe will solve my problem (I connected to the wrong coax antenna plug). I haven't tried, but I'm pretty sure that is the problem.
Here's the post from akai_owner from 2007:
Look at the back of your TV. Make sure your cable is hooked up to connector on far right, NOT the far left. (For analog cable TV.)
Push "source" button on remote or side of TV to cycle through TV inputs. Wait one second between pushes. You want to stop just before the source that displays "AV" on TV screen. It should show a number, for the current channel number.
If you are using an analog cable box, try setting the TV channel to 3 or 4. If you use no cable box, try changing channels on TV to find an active one. If no luck, make sure your cable service is active (subscription active). Cable companies disconnect it between residents of an apartment/house.
Dec 19, 2008 | Televison & Video
Need use New HD PC Monitor with DVI/VGA inputs like HD Ready TV
you need to get a lcd tv device such as from dany or xpod.  it will connect your cable, and its output can be fed into the lcd monitor.
Nov 14, 2008 | Samsung SIR-T451 DirecTV DTV Receiver
Televison & Video Logo
Top Televison & Video Experts
