Sanyo picture in picture TV
Hello, My name is Debbie petri. I just inheirted a 27-30in TV from my deceased X husband. I am trying to hook up a Xbox 360, but it won't convert to TV Video, how can I fix this problem? thank you
Debbie Petri
trucker_1945@yahoo.com
premtech
  • 934 Answers
SOURCE: YPbPr inputs not working
Tacz, What video input# on the back of the TV is your component video?? Are you sure the TV is set to look at that video input#??? You may be looking at one of the composite video inputs as far as the TV is concerned and with nothing plugged in to that input the TV would naturally give the error message you indicated. Let me know.. Bill
Posted on Jun 11, 2007
SOURCE: xbox 360 stretched screen out and cannot fix it now
Have you checked the aspect ratio?? May be that when the kids had the X-Box hooked up they simply changed the aspect to zoom.
Posted on May 22, 2007
Benimur
  • 6966 Answers
SOURCE: Sanyo TV
If I understand your posting/description right, you have:
1, a Sanyo TV with only 1 video input;
2. you have a DVD player with only video output; and
3. you have a VCR (which I will assume to be with both video input and output).
Your query, if I may clarify, is how to hook them up so that you need not connect/disconnect any video cable when you want to switch video source from either DVD or VCR.
If that is what you want, then connect:
a. audio/video OUT of your DVD to audio/video IN of the VCR;
b. audio/video OUT of your VCR to audio/video IN of the TV.
The above described connection would allow you to:
i. watch DVD movies on your TV (your VCR must be powered ON and set to Video INput, your TV must be powered ON & set to Video INput);
ii. watch tape movies from your VCR without disconnecting/connecting cables.
Additionally, this arrangement would allow you to record DVD movies in your VCR. Further, connecting your cable/aerial to the RF INput of your VCR would allow you to do the same with a TV/Cable program.
Incidentally, if one of your units (TV, VCR, DVD) would only have a single audio input, it is still possible since some models uses the white audio RCA connector as either left or mono, the red is right. You can also use a 2 female RCA to 1 RCA male adapter as shown below to joint the red/white audio.
Hope this be of some idea/help. Pls post back how things turned out or should you require additional information.
Good luck and kind regards.
Posted on Nov 19, 2007
  • 4102 Answers
SOURCE: Hooking up XBOX 360
Hi have you tried going into the menu option using the telly controll and switching the hd mode on this should then allow you to use the xbox through hdmi cable
Posted on Feb 29, 2008
SOURCE: XBOX 360 no video after playing HALO 3
Yeah, mine did the same thing.
I looked around and it turns out that this problem is pretty close to same thing as the red ring of death, so in theory, to fix this problem you can do the samething as you would do for any RROD.
Last night I did the towel trick and fortunatley it worked for about an hour, than the tv screen went fuzzy and then black. I tried towel trick again for the ful 20 minutes and it seems to be working.
Hope this helps anyone, and wish me luck that my xbox holds out untill I get enough money to buy a new one or a PS3.
Posted on Dec 04, 2008
How to cancel my deceased husbands account. Deceased's name is Thomas J Miller.
Publishing both your name and your husband's, and the fact that he is deceased, is not a good idea - can lead to identity theft or other problems. As for your question, contact the organization or site with which he has an account. They will have a procedure.
May 09, 2016 | Computers & Internet
How do I hook up Xbox 360 to this TV? I have no clue where all the plugs go in the back
component leads from xbox to component in on tv
Xbox 360 Component HD AV Cable
http://support.xbox.com/en-AU/xbox-360/system/connect-xbox-360-console-tv
https://www.youtube.com/watch?v=JlE2zHSoQmE
Nov 20, 2015 | Sanyo DS31590 31" TV
Sanyo 50in HDTV turns on fine, no picture or sound
How is your xbox connected to the tv? If its connected with hdmi cable. Unhook it from xbox and plug it into the back of the cable box. If nothing happens then try switching the tv input with the tv remote. Should have several different inputs. Hdmi,video,component,etc...
Feb 25, 2013 | Sanyo Televison & Video
Xbox elite connected to TV thru HDMI works fine, but connected via bcs-fs500 receiver = no audio or video Cable tv through receiver works fine Have tried cable tv through receiver inputs HDMI 1 and 2...
Hook your Xbox to tv via HDMI, then hook TV to reciever through digital optical or composite cables. If you try to get your picture through receiver first, you may get picture and sound but, sound may be delayed and picture might not be the best. Bettter to run through tv first then provide sound to receiver.
Mar 31, 2011 | Pioneer Audio Players & Recorders
My screen is not showing whole picture even when zoom not on
Hello; You need to select the best " aspect ratio or other name on the Sanyo remote" Read your Sanyo owner's manual or download it for more Info. John
Dec 19, 2010 | Sanyo 42 in. LCD TV
Hello, i am trying to hook up my xbox 360 to my
Make sure the tv is set to A/V 1 if it has multiple A/V hookups make sure the tv is on and set to the A/V channel you are trying to use. And make sure your cable is set to tv if you have a composite cable. If that does not work try buying a composite cable (thats the yellow red red blue green white cable). If that does not work. There might be something wrong with the xbox or tv.
Jun 26, 2010 | Video Game Consoles & Games
I have a 20 inch sanyo hd digital hooked up as a second tv on dish network receiver. I had to unhook it temp and when I hooked it back up, no picture. I tried channel scan and nothing. How can I get the tv...
bring the tv out to the main tv and hook it up to that connection to determine if it's the TV or the connection. Or try hooking up a VCR to the tv while the TV is set to CH 3. Do you get a blank picture or a snowy Picture?
Sep 20, 2009 | Sanyo Televison & Video
Sanyo mts stereo tv purchase in 1998
Must have original remote with Sanyo. Go online for search to Sanyo customer support
Dec 24, 2007 | Sanyo DS32920 32" TV
Lightning storm knocked out this tv and one other
hi there, there is a problem with your power supply section, not just a fuse but some electronic parts to be replace. ty
Dec 08, 2007 | Sanyo DS31520 31" TV
Xbox 360 stretched screen out and cannot fix it now
May 22, 2007 | Sanyo DS20425 20" TV
Televison & Video Logo
348 people viewed this question
Top Televison & Video Experts
