Question about HP PSC 1210 All-In-One InkJet Printer
Paper will not feed into printer
Hello
My problem is my printer will not feed the paper into the machine for printing.
The first time this started happening was right after I was trying to print something and heard a rather noticeable snap, as the paper went through. It sounded as though something had broken inside the printer, relative to the paper feed mechanism.
I don't know anything about taking this printer apart. But it looks as though this is probably what I will have to do. I am going to check online to see if I can find information on how to disassemble it.
If I can save this printer, it would be great. I have been really satisfied with it.
Appreciate any help you can send my way.
Thanks
  • uratia
    uratia Nov 04, 2008
    Hi, I have a psc 1210 with the same problem. It wont feed the paper. So does anyone know if the sensor can be fixed?
    Novelist:
  • 180 Answers
Open the door at the back of the printer and clean the rollers.
Unplug the power cord at the back of the printer while it is still on and then after 30 seconds plug it back in.
If it will still have the same problem then there is a problem with its sensor.
Posted on Aug 04, 2008
Error paper jam
Hello Cassandra,
It sounds like you are having phantom paper jams. When the printer starts a print job and tries to pull a piece of paper but can't grab it the printer thinks there is a jam but there really is not. If the paper pickup rollers are worn down they are not able to grab the paper correctly to feed it into the printer which causes this type of error. The rollers are considered user installable and come in a kit with the rollers and the paper separation pad which keeps more than one paper from being pickup up at the same time. Installing the paper feed kit should clear up your paper feed problems. The paper feed kit is available here: http://www.ccl-la.com/catalog/product_info.php?products_id=342
I hope this helps.
BuddyMc
Aug 06, 2013 | HP CP3525N Color LaserJet Printer
Hello, i have a HP Officejet Pro L7480 which did not cause trouble for 3 years, but now: PROBLEM WITH PAPER FEEDING - when trying to print something, the printer normally "tries" to grasp a...
Hi
If it attempts to feed and expecially when you hear a cricking sound. It means that the paper guide it too tighten that it holds the paper. Try to loose up the paper tray guide. Are you using a paper tray. If not, put small paper or change the correct setting of the paper size setting to auto detect if any.
The try to print again.
Mar 31, 2011 | HP Officejet Pro L7480 All-in-One...
I am trying to print my guest receipts and it is only printing out a quarter of the sheet with no ink.
hello, lets see if we can seperate problem with computer and printer, try running printers self test, i am curios if the machine will print properly, turn printer off, then hold paper feed button and turn machine on, paper will feed and print, once the first test pass, if you want to print the rest, press paper feed button, and machine will print and cut paper, this test is rather a little long, but it will give you info regarding paper feed, and cutting as well as impressions. if paper is dragging, check to see if the paper in machine is in correctly, you might want to check this out first, if the paper is in correctly, then problem is feeding, this is a little hard to clean, but you might want to try some isoproply alcohol and put some on the lead in paper, just enough to get paper wet, and try to allow machine to feed in, or maybe, if paper is already feeding in wet some area before going into machine with alcohol, and press feed button, and allow the paper to feed thru. tear off paper and try the printer test again. if still fails then machine has a problem and will need service.
Oct 08, 2010 | Epson TM-U220 Matrix Printer
Printer is saying manual feed insert paper. Will not print
To load paper or other media in the Manual Feed Slot (directly above the Paper Tray)
You can load envelopes and special print media one at a time into this slot. Use the manual feed slot to print or copy on labels, envelopes or thicker paper.
1. Slide the paper guides to fit the paper size.
2. Using both hands put one sheet of paper in the manual feed slot until you feel the front edge of the paper touch the paper feed roller. Let go of the paper when you feel the machine feed the paper in a short distance.
Note: When you put paper in the manual feed slot, please remember the following:
■ The side to be printed on must be face up.
■ Put the leading edge (top of the paper) in first and push it gently into the slot.
■ Make sure that the paper is straight and in the proper position on the manual feed slot. If it is not, the paper may not be fed properly, resulting in a skewed printout or a paper jam.
■ Do not put more than one sheet or envelope in the manual feed slot at a time or you may cause the machine to jam.
■ You can remove smaller sizes of printed paper from the output paper tray more easily if you lift the scanner cover using both hands as shown in the illustration.
You can still use the machine when the scanner cover is raised. You can return the scanner cover to its home position by pushing it down with both hands.
If you would like to disable Manual Feed Mode, check that the manual feed mode is not selected in the printer driver.
Here is a copy of the User's Manual for the Brother MFC-7820N.
Jul 07, 2010 | Brother MFC-7820N Laser Printer
Paper won't feed
Inside of the machine is dirty.
If the inside of the machine is dirty, the printed paper may be smudged.
Follow the steps described below to clean the inside of the machine.
1. Ensure that the machine is turned on and there is no paper loaded in the Auto Sheet Feeder.
2. Place A4/Letter-sized plain paper in landscape orientation, horizontally fold it in half.
3. Unfold the paper, and load the paper in the Auto Sheet Feeder with the inverted-V edge down.
4. Select <Bottom plate cleaning> from <Maintenance>.
5. Select <Yes> on the Bottom plate cleaning confirmation screen and then press [OK].
Paper will be ejected.
If protrusions inside the machine are stained, wipe ink off the protrusions using a swab or such like.
* Important
Before cleaning, be sure to turn OFF the machine.
Paper feed roller is dirty.
Follow the steps described below to clean the paper feed rollers.
1. Ensure that the machine is turned ON and there is no paper loaded in the machine.
2. Select <Roller cleaning> from <Maintenance>.
3. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
The paper feed roller will rotate as it cleans.
4. Repeat this operation twice.
5. Load three or more sheets of A4/Letter-sized plain paper lengthways in the Auto Sheet Feeder.
6. Select <Roller cleaning> from <Maintenance>.
7. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
The paper that is loaded in the machine will feed through the machine and be ejected.
8. Repeat Steps 5 to 7 three times.
Inappropriate paper type is used.
Check to see if the paper you are printing on is too thick. See Paper Types You Cannot Use.
Note that smudging may occur at the top and bottom edges of the paper when using Borderless Printing. Ensure that the paper you are using is compatible with Borderless Printing.
Thick paper is used.
When printing on thick paper, set the Paper Thickness Lever to the right.
This widens the gap between the FINE Cartridge and the paper. Try this maneuver if the printed surface is scratched.
Media is curled.
If all four corners or the printing surface of the paper is curled, the paper may become dirty or may not feed properly. Use the paper after correcting paper curl as follows.
1. Place the printing surface face up (A), and cover it with a sheet of non-printing regular paper to avoid damaging the surface.
2. Roll up the paper in the direction opposite to the paper curl as per the figure below.
3. Check the printing paper to confirm if the paper curl is eliminated to within approximately 2 to 5mm / 0.08 to 0.2 in (B).
It is recommended to print on curl-corrected paper one sheet at a time.
The media type is not selected correctly in the printer driver.
On the [Main] tab of the printer driver, ensure that the [Media Type] selected matches the paper loaded.
In the [Print] dialog box of the printer driver, select [Quality & Media] from the pop-up menu, and then ensure that the [Media Type] selected matches the paper loaded.
Paper is loaded incorrectly.
Load in the portrait orientation regardless of the print direction of the Auto Sheet Feeder.
Ensure that paper is loaded correctly. Slide the paper guides against the paper stack.
Oct 18, 2009 | Canon Pixma MP500 All-In-One InkJet...
HP Deskjet 1200c will not feed paper. Fails to pick up paper from tray. If force pickup by hand can get it to start printing but moves paper in wrong direction as as positions for printing. Does not...
This sounds like a problem with the paper pick up rollers. I would suggest cleaning the rollers with a little isopropyl alcohol. Please make sure the machine is turned off when doing the cleaning. Let the rollers dry for a few minutes. If this does not work, The rollers would probably have to be replaced.
Aug 28, 2009 | HP DeskJet 1200c InkJet Printer
Paper jam in print area
Hello sir; Just tupn the power off for 30 second then turn back on machine will automatically feed the jam paper out.
Aug 02, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Paper doesn't feed
It could be a few things, but the times I've had similar problems it was either caused by the feed/gripper rollers in the paper trays being worn out, thus not feeding any paper or feeding half a sheet and then jamming.
Or, it could be that the elevator in your paper tray isn't lifting, but if it's taking paper it's probably the rollers.
Jan 12, 2009 | Canon Office Equipment & Supplies
Paper jam followed by printing pics
just check to see if there is any obstructions were the paper is going through, unplug printer cables, press power button for 20 seconds without any cables connected, it will refresh printer memory, connect cables back,try photocopy, if nogo, printer fualty
Nov 04, 2008 | Dell 948 All-In-One InkJet Printer
Epson Photo RX600 error messages
Hi.
Check for a paper jam inside the paper feeder... There's something blocking the path that is why the 3-beep is activated. Also put lubricant to the head's round-bar, gears and levers.
Goodluck... Fixya me...
Feb 10, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
HP PSC 1210 All-In-One InkJet Printer Logo
990 people viewed this question
Ben Johnson
