Question about Intel Motherboard
LCD Backlight on my Acer Travelmate 2480-2513
It seems that the Lcd backlight on ny Acer laptop in not working,I need to know if it can be repaired and at what cost?
    Genius:
  • 2,028 Answers
This will be a problem with either the screen inverter or the screen. If it's the inverter you're looking at $30 to $50 for the inverter plus labor. If it's the screen $150 to $200 for the screen plus labor.I would calculate the labor in as well, but labor rates vary from area to area. The labor rates at my shop are $45/hr. If you were to bring it to my shop I would only charge 1 hour labor for this. Other shops may charge more, but I wouldn't let them charge more than 2 hours labor, this is a fairly simple job and shouldn't take more than an hour.
Posted on Jul 17, 2008
Fade display problem
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 10, 2010 | Acer TravelMate 2300 Notebook
Acer Aspire 5610 LCD backlight problem
my laptop is acer extensa 4620 problem is web cam is not working what will do
Nov 05, 2009 | Acer Aspire 5610-4648 Notebook
If it is less than 1 year old, go to http://www.acerwarranty.co.uk for UK or http://support.acer.com/ for US.
I did this last year for my girlfriends laptop backlight problem and it was a free courier both ways and was repaired within 2 weeks (new part required). No cost to you.
Otherwise, sorry I dont know how to fix it.
Nov 05, 2009 | Acer Aspire 3680 Laptop
Black screen on acer 242lc lights come on power up
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 18, 2009 | Acer TravelMate 242LC Notebook
Acer 5515 backlight not working also bootmanager missing
You need to fix the boot manager problem first by connecting an external monitor to the laptop so you can see and do a system repair.
As for the backlight problem :-
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info
Aug 14, 2009 | Acer Aspire 5610-4648 Notebook
A three inch verticl faded portion of screen
You most likely have a faulty CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 06, 2009 | Acer TravelMate 2300 Notebook
My acer aspire 4320 have no light in the display
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 26, 2009 | Acer TravelMate 4320 Notebook
ACER 4100 TRAVELMATE
If this happened suddenly, the backlight power supply (inverter)  has probably failed. It could be the backlight itself but they normally will dim or flicker before they die.
Try shining a light at an angle on the display with the computer turned on and look at it from an angle too. You may be able to see video very faintly; if you do, then it is as described above; a backlight problem, not the LCD display itself.
Jan 22, 2009 | Acer TravelMate 4100 Notebook
Backlight faliure
Its a florescent backlight and is an integral part of the LCD screen.
You need to replace the entore screen, not just the backlight.
I hate to tell you this, but unless you can find a screen on E-bay or similar site it is going to cost you almost as much as a new computer.
You can buy a used travelmate 240 for around $200 and drop yyour hard drive into it and be up and running as before in a matter of minutes. Then you may be able to sell the old one as a working base with a bad screen to recoup some of what you paid out.
Good luck.
Jan 01, 2008 | Acer TravelMate 240 Notebook
Intel Motherboard Logo
202 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
