HOW TO PUT MEMORY CARDS INTO DELL DIMENSION 4400
  • STOREYENT Jul 17, 2008
    I AM INCREASING MY MEMORY AND ORDERED THE NEW CARDS JUST CHECKING TO SEE HOW TO INSTALL
  • Steve Nordquist
    Steve Nordquist May 11, 2010
    You want to know how to put DIMMs (DDR) in, or you want to know how to add a flash memory card adapter in the floppy slot?  The answer to the first one's on the Dell website in gory detail, though the details at the motherboard level relate to the BIOS and motherboard version (varying little in general, though.)
    Write about specific things in your way if you don't understand something.
  • 981 Answers
The other thing that will vary from system to system is the type or types which it can accept; hence referral also to the particular Dell PDF manuals and BIOS update notes.
Posted on Jul 19, 2008
    President:
  • 1,314 Answers
This video will tell you the basics of how to install memory into your computer. The only thing that might be different is how to get in your case.....If it's not the standard two screws and the side slides out case, yours may have two buttons, one on the top and one on the bottom that you push and open the case like a door to give you access. Either way, this video tells you how to install the memory once you are inside.
Watch the video here.
Thanks and please take a moment to rate as fixya.
Posted on Jul 17, 2008
Need to add more memory ram
I see that it has two slots and can hold a maximum of 1GB which is 512MB in each slot.
I got that info from 4 all memory at:
http://www.4allmemory.com/memory/dell-dimension-4400-ddr/
May 10, 2012 | Dell Dimension 4400 PC Desktop
I have adell dimension 4400,its beeping and the indicator lights on the motherboard are blinking
check RAM and graphics card if additionaly installed.., try to remove and reinstall. make sure power connection is disconnected while doing this!
Nov 13, 2011 | Dell Dimension 4400 PC Desktop
Dell Dimension 4400 PC Desktop my dell dimension 4400 is beeping and its not displaying why?
Your issue sounds like the system did not get past power on self test. POST. The next step is to investigate the beeps http://www.computerhope.com/beep.htm.
Dimension 4400 Power Supply ** FREE ** (DE4400300WB) Power Supply: My Dell Dimension 4400 is dead with none of the 4 ...
It seems like it that you have a faulty power supply. Also the motherboard may be damged aswell, But most probably you can fix your PC by changing the power supply.
May 16, 2010 | Dell Dimension 4400 Power Supply ** FREE...
How do I replace a dell dinension 4400 sound card in the desk top
You can't replace onboard audio, if it's PCI then all you do
is locate which slot it's in, unscrew the small mounting
screw, then carefully pull it out of it's slot, Replace with
new card in reverse order, make sure you have the
software drivers for your new card, and install them prior
to changing the card or follow the manufacturers directions
for installing the drivers...
Oct 15, 2009 | Dell Dimension 4400 PC Desktop
Dell Dimensions 4400 boot failed: system halted
reload the windows, it missing the loading operating files.
Jul 06, 2009 | Dell Dimension 4400 PC Desktop
D4 Post code using tech aid diagnostic card
check power supply in back to see if you have on and off switch but you would'nt be the first with this problem from dell about the power supply going out meaning:
if you don't have nothing happening when your trying to boot the computer then it's the power supply, plug in computer power up and feel in back to see if the fan is blowing if nothing power supply is gone call dell.
Apr 05, 2009 | Dell Dimension 4400 PC Desktop
Dell 4400 desk top beeps 3 times on boot up 2-AMBER 2GREEN LIGHTS
If the problem is not resolved after reseating the memory modules the problem more or less seems like a motherboard failure. Use the following troubleshooting steps to pin point the problem
http://tinyurl.com/bhl7xx
Thanks
Proton
Jan 24, 2009 | Dell Dimension 4400 PC Desktop
Replaced 128mb with 512mb in Dell Dimension 4400. Plugged everything back in & turned on. Or at least think it is turned on; there is a green light for both the power button and hard drive lights. ...
If you have replaced the memory on a computer and it does not turn on normally that means that either the memory is defective or it is not compatible. Do you hear beeps when you turn on the computer?
Nov 26, 2008 | Computers & Internet
No sound
Dell dimension 4400 drivers can be found here.
Apr 28, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
