Everytime the phone rings I get kicked off line from my dsl
  • 981 Answers
Put those filters on the line with your phones and answering machines and stuff; if you know they're already on correctly, tell your telco they have something configured wrong and to please look into it (though it's possible the filter in your DSL modem is going wacky on you or that the filters got wet; you can tell them the signal strength (e.g. -11dB) info from your DSL router's connection info page.)
Posted on Jul 17, 2008
Cannot receive phone calls on a dsl setup
There must be DSL Spliter inbetween telephone line & Wi-fi modem. Please check whether you have connected telephone instrument line with that Spliter or not. According to me, Telephone instrument should connect to telephone line option on DSL Splitter to use same telephone line as internet as well Telephone.
Mar 03, 2010 | Computers & Internet
When my phone rings the kids get booted off xbox live and i have wireless internet and wireless adapter for xbox360
Hi Jeannie,
Based on your problem I assume that you have DSL. When you get hooked up for DSL they send filters that you are supposed to put between EVERY phone and the jack. (Don't forget phone lines for satellite and alarm systems).
If your dsl drops every time the phone rings, there are usually 2 things that cause this.
1) A bad filter in your house. If a filter is bad or missing it can cause the dsl to drop either when the phone rings or if someone picks up the phone with the bad filter.
2) The other reason could be on your ISP's side. It's called a POTS splitter. You have one of these if you have BOTH phone and DSL. It's what sort of combines the 2 together. There are a number of problems that can occur with a bad pots splitter. i.e. DSL works - phone totally dead, Phone works-dsl - totally dead, disconnects, etc...
I suggest that you hook up the dsl modem by itself. DISCONNECT ALL PHONES IN THE HOUSE. Do NOT have anything connected at all except the dsl modem. No filters, phones, directv, digital cable, or anything else in a phone jack. Then when you are up and surfing, take your cell phone and call your house. Technically it should just ring and ring. Unless you have voice mail in which case it will go to voice mail after so many rings. Anyway, see if when the line is ringing in your cell phone if it is dropping you off. If it DOESN'T, then it's probably one of the filters, jacks, or wiring. If it still disconnects, it's probably the POTS splitter with your ISP.
Good luck and if this helped please help me out and leave feedback!
Thanks!
Feb 08, 2010 | Computers & Internet
Ok i have a netgear wireless router and everytime my phone rings or somone gets on the phone it kicks me of my online session with my ps3
Assuming you have a DSL connection, you probably need to put DSL noise filters on your phone lines. Call your DSL provider, they should provide you with these.
Dec 19, 2009 | NetGear WGR614 Wireless Router
Fax rings but machine doesn't answer
First check the setup/configuration and make sure the Fax is set to answer on 1 or 5 rings. If the line is dedicated to fax then it can be set to answer after the first ring. Fax machine works off a modem that listens for the ring and handshake tones. If the machine has been hit with a lightening spike then the hearing portion may be dead.
Translation: Your fax machine is Deaf and can not hear the ring.
It will never answer and do the fax handshake required.
If it is a new machine and still under warranty. Take it back as soon as you can.
If this is a fax machine installed at work.
Be careful, some phone systems used in the corporate buildings have too high a voltage and will fry the modem/fax card.
If this is a home machine with DSL.
Make sure the DSL line filter is applied correctly.
It will be clearly marked Phone or DSL line. Do NOT connect the phone/fax line into the DSL line connection.
Hope this helps!
Nov 08, 2009 | Lexmark X6170 All-In-One InkJet Printer
MY INTERNET GOES DOWN EVERY TIME THE FAX MX310 RINGS
There are some good suggestions here. Check out the solution and follow the steps. The reason dsl seems to be being dropped is the noise in teh line, and as far as I can tell this is a very common problem. Try these suggestions out but you may want to just purchase a better fax machine.
http://www.fixya.com/support/t374109-canon_mx310_fax_noise
Apr 27, 2009 | Canon PIXMA MX310 All-In-One Printer
Can't send anything!! Only telephone rings!
Do you a DSL or any other kind of digital phone line?
Unplug the power cord for 10 seconds.
Oct 10, 2008 | Brother IntelliFAX 885MC Plain Paper...
Cant connect thru DSL(LAN)
hey there i am having a problem with my Vista home premium. = false
I cant connect or get my broadband connected to DSL. = true
but everytime i use my fone as a modem i can surf the net. = true
how come i cant do this with the DSL Line?
1. Your DSL line requires a special kind of modem a DSL modem not a phone modem.
Thank you for choosing FixYa!
Az. Wizard Division.
Sep 23, 2008 | Microsoft Windows Vista Home Premium with...
Fax one phone/fax line but always answered by fax
You can change the number of rings before the fax machine can pick up. Three is usually a good number. You would have to pickup the phone on the first two rings.
They make devices that do that but everytime I have used them I would end up getting the fax tone when I'm trying to make a voice. The boxes are great at dealing with incomming phone calls from pstn or land line based calls, but if you are getting cell phone calls or voice calls comming in from digital, DSL, or VOIP lines, it has a hard time sensing voice from fax when people are using phones like that. There designed for analog phone line installation but if you're on a DSL they won't work.
Sep 15, 2008 | Samsung CLX 3160fn All-In-One Printer
Get disconnected everytime the phone rings
Should not happen, unless you have the Modem card in the PC connected to the line.
Aug 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wiring a phone jack
1. Do you have the wireless internet and connect to your phones?
2.Do you have a AT&T DSL with a router for your computers and phones?
Jun 22, 2008 | Lands Phones
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
