Speakers i have speakers hooked in my computer but it says it can't find no audio device on here. help??
  • 781 Answers
Check to see if audio drivers installed
Start/Control Panel/system/Device manager/ when device manager come up check for any items with yellow mark on them
Right click Properties/update driver you should go onto internet to update
Posted on Jul 17, 2008
My speakers are plugged in and they don't work. if i hook them up to my son's mp3 player they do, but as soon as i hook them up to the computer they dont
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 20, 2011 | Labtec AMX 2000 Computer Speakers
My speakers won't play any sounds when hooked up to the computer. I hooked it up to my ipod and it played
im not sure i understand what won't means????????
if you are having problems with your sound
also
hope this helps
Apr 18, 2011 | MidiLand MLi 691PA Computer Speakers
I have speakers hooked to my computer put there is no sound. it said no divice found what should i do ?
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Nov 02, 2010 | Altec Lansing Multimedia Computer Speakers
My speakers are hooked up to the computer but I'm not getting any sound. It use to work until I got a virus on my computer and when I got my computer back I hooked the speakers back up but no sound.
the virus might have corrupted your drivers
hope this helps
Oct 27, 2010 | Koss Audio Players & Recorders
MY COMPUTER HAS NO AUDIO DEVICE I SEARCHED ON THE INTERNET BUT NOTHING WORK OUT PLS HELP ME TO SOLVE THIS PROBLEM
mcdevito75 here, Most Computers (Desktop) have built in Audio devices but you"ll need outside speakers, and you have to mke sure the audio is on in your computer. ----- Try this, in your computer click on start, then Control Panel, then on audio speakers devices, then un--check the MUTE box and Check the Place icon in the task bar box. Then hook up speakers to your computer, speakers available at Staples, Radipo shack etc.
Jul 02, 2010 | ASUS P5P800-MX Motherboard
2.1 SPEAKERS NO SOUND. CONTROL PANEL DOESN'T RECOGNIZE ANY AUDIO DEVICE & CANNOT ADJUST SPEAKER VOLUME.HAVE NEVER HAD SPEAKERS HOOKED UP BEFORE.
That's your problem. It could be:
* the audio-device integrated on your computer's motherboard is "disabled" -- Windows cannot use it
* there is *NO* audio-device integrated on your computer's motherboard -- Windows cannot use non-existent hardware.
* Windows has not installed the correct device-drivers for the integrated audio-device.
* you have an add-in PCI audio-device, and Windows has not installed the correct device-drivers for this hardware.
Do the speakers work if the output from an iPod is connected to the input-jack on the speakers?
Do the speakers work if connected to some other computer (laptop or desktop) ?
Nov 11, 2009 | Insignia 2.1 Speaker System (3-Piece)
I just hooked up my Labtec LCS-2420 speakers to my new computer and can't get any sound out of them. I can get the cheap ones that came with the computer to work, but not the Labtec. I hooked them up to...
if its a 6 channel connection its a little tricky try reconnecting your speakers that has a green connections. try playing a music while troubleshooting the connection...hope this helps..ITTech7574
Aug 29, 2009 | Labtec LCS 2420 Computer Speakers
Speakers wont work
Can you tell me what brand they are?
I can try to help without the brand name:
Go to start and hit control panel. Next click Sounds, Speech, and Audio devices. Click 'change speaker settings'. Click audio in the tabs. Click the droplist and select the speaker brand you have.
If that doesn't work, make sure the speakers are connected to the correct computer jacks. Green is the common speaker color, so hook the speaker wire into the green computer input.
Pink is microphone, so that could be the problem.
Hope I helped!
Jan 23, 2009 | Dell A215 Computer Speakers
Reconnecting speakers
speakers won't show up in the device manager, go to the rear of your machine and plug it into the green connector, it should be either lite green or pink, try green first, just keep the volume down till u figure out which on it is
Dec 26, 2008 | Gateway (G-MAX2000) Computer Speakers
Computer stopped recognizing speakers
This is due to your Drivers for your sound device are unavailable plz make sure that you have installed all your audio devices driver! try to reinstall it! it will help you
Dec 07, 2007 | Polk Audio AMR50 Computer Speakers
55 people viewed this question
 Grubhead
Grubhead
