Question about Whirlpool GH6177XP Microwave Oven
Whirlpool(GH7145XF2-0) does not work occasionally
Our microwave will heat just fine then in the middle of heat cycle the microwave will stop heating for a while then start working again. You can only tell when the microwave stops heating by a change in the sound the microwave makes.
Is there a circuit break that could be tripping and resetting inside the microwave?
Thanks,
  • Whirlpool Master
  • 8,872 Answers
That's how it would sound if you were cooking on a power level less than full power.
If you enter the cooking time and hit Start, it should cook at full power by default and not cycle like you describe.
If you are using some sensor cook setting or automatic type cooking setting, it may cycle like that normally.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
If you don't have your manual, you can download it free here. Check the lower right area to enter your model. number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 18, 2008
After approx a minute a regular squeak begins, occasionally missing a beat.Heating is fine.
If the "frequency" of the squeaking is a low frequency, the I would suspect the turntable motor or stirrer motor (if so equipped).
If it is a higher frequency, I would suspect the cooling fan or hood fan motor.
Dec 11, 2012 | Neff H7871 Convection/Microwave Oven
We have GE JVM1650 spacemaker microwave. At first it would run for 3-5 seconds and turn off. More recently it stopped heating in the middle of the alotted time. Everything works fine, no keypad...
It's a bad magnetron.
See
this FixYa solution even if your full model number is different.
Oct 02, 2010 | GE JVM1650 1000 Watts Microwave Oven
My sharp 1214 won't heat anything. power is good - timer and clock are fine. stopped working in the middle of heating something. we use often. carousel is not rotating anymore either.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Aug 10, 2010 | Sharp R-1214 Microwave Oven
Unit operates does not heat anything
A defective diode or magnetron can cause the oven to sound differently and not to cook.
Jun 19, 2010 | Whirlpool MH6130XEB/Q Microwave Oven
Microwave stop working
my microwave oven just stopped heating giving me a f9 error .lights are on clock is working and the panel is ok.
Jun 15, 2010 | GE Profile Spacemaker Over-the-Range...
Maytag MMV4205BAS stopped dead in the middle of a heating cycle. Unplugged and plugged back in. Oven is on the same fuse and it's fine. Any ideas?
There are several possible causes for a dead oven. Since yours quit in the middle of heating, I'd say it's most likely failure of the magnetron tube which supplies the microwaves. There's a safety thermostat on the tube which opens up and shuts off power if the tube overheats. Overheating is one sign of a tube that's gone bad.
There's really nothing user-serviceable in a microwave oven. Because of hazardous voltages inside and the possibility of microwave leakage, service should be left to professionals. Take the oven to a service shop for an estimate.
Jun 03, 2009 | Sharp R-930AK Convection/Microwave Oven
No power on microwave
Buy a new one. Microwaves have enough stored voltage/amperage to boil your blood. You should not be taking off the cover.
Mar 07, 2009 | Whirlpool MH7140XF Microwave Oven
Sharp Microwave stopped heating
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Jul 24, 2008 | Sharp R-630D Microwave Oven
Whirlpool GH6177XP Microwave Oven Logo
228 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
sonic boom...
sonic boom...
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
