Apple iPad 32 GB WiFi Tablet PC Logo
Posted on Jan 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Ipad is charging very slowly and is not rocognized on Itunes when I plug it in to my computer. Could the "charging port" be damaged?
Anonymous
Level 2:
Guru:
  • Expert 160 Answers
  • Posted on Feb 17, 2011
Anonymous
Expert
Level 2:
Guru:
Answers
160
Questions
0
Helped
50194
Points
304
No.That is an issue all Ipads have not showing the charge because of low voltage from usb.Download asus aicharger by search on web and install then restart computer.Plug in usb from Ipad and will show charging..
Ipad air plug in will not charge. turn off the ipad and plug in ipad turns on but doesn't charge?
Apple support suggests several possibilities. The iPad may not be receiving sufficient power to charge it; some lower powered charging devices are lacking. The charger may not be Apple certified (as being adequate). Test an alternative charger. Or, the port may be dirty or damaged. Remove debris. Try another USB cable. Restart the device. Also, determine whether or not you have the latest ios operating system. If it still does not charge, contact Apple support for service.
For more detailed instructions: https://appletoolbox.com/ipad-air-charging-very-slowly-or-not-charging-fix/
My iPad is disabled and wants me to connect to ITunes but shows no way to do so; what do I do
You use the charging/sync cable and plug the other end into a usb port on your computer that has itunes downloaded on it.
2answers
How can I delete my data from an iPad 2 whose display is black & unreadable?
Hi David,
I think this will help you please refer to below steps:
  1. Make sure the iPad battery is charged above 20% ( we would recommend at least 40 - 50 %). If you are not sure charge you tablet for at least 30 -40 minutes.
  2. Make sure iTunes is not running on your computer but is ready to be run.
  3. Temporally disable firewalls and other security software to prevent interference with iTunes.
  4. Make sure your tablet is disconnected from the dock or USB data cable that equips the gadget . Nevertheless USB cable must be plugged into your PC or MAC.
  5. Make sure your PC or MAC is awake and its screen saver is turned off.
  6. Simultaneously press and hold down the Wake/Sleep button and the Home button and wait until "slide to power off" screen appears. Don't do anything after its appearing, just keep holding Wake/Sleep and Home buttons until Apple tablet will power off.
  7. Release the Wake/Sleep button once Apple tablet is off , but continue to hold the Home button
  8. Holding the home button, connect the USB data cable to iPad. When you reconnect the USB cable, tablet should power on and you should see a message on your PC/MAC display saying that iTunes has detected an iPad in Recovery Mode
  9. After you detected this message, release the home button and press OK on iTunes pop-up to confirm the restore option.
  10. Do not touch iconic tablet and you computer while iTunes downloads and installs the fresh copy of firmware on your iPad. You will be notified by iTunes when iPad is successfully restored, but... in a while, you will get an message saying that the iPad isn't recognized. Don't panic. This is because all user content on iPad including activation status was erased during restoration.
  11. Disconnect iPad from iTunes ,unplug from computer and turn off.
  12. Turn iPad on and using iTunes activate it on any computer you have. Apple currently allows up to 5 computers to be authorized for each iPad.
My apple ipad is not reponding when iam charging it how do i reset it
If you charge your iPad on a power adapter, the iPad should respond while charging, except if your iPad battery is so low the apps need more power to run.
If you charge your iPad on the USB port of your computer, it is normal you cannot use your apps as the iPad is not only in battery charging mode but also in synchronizing mode with iTunes in the computer. You should lose the habit to charge the iPad on the PC and use a dedicated power adapter instead, as dedicated power adapters charge the iPad battery 2 to 4 times faster than the USB port of most computers.
USB port power: 2.5 Watts in general (5 volt x 0.5 A = 2.5 Watts)
iPhone charger: 5 watts
iPad charger: 10 or 12 watts
1helpful
My i pad will not turn on
First steps: Make sure you're up to date
  1. Verify you have installed the latest version of iTunes.
  2. Verify that you are connecting iPad to your computer using a USB 2.0 port.
  3. Make sure your iPad software is up to date: With your iPad connected to your computer, click "Check for Update" in the Summary section of iTunes.
  4. Charge your battery: Using the USB power adapter that came with iPad, charge iPad for at least 20 minutes before further troubleshooting. If necessary, refer to "Charging the Battery"
Why is my ipad stuck on the itunes symbol?
It may think it's plugged into the computer. Check for lint or pieces of metal caught in the charging port. If there's nothing there, take it to the apple store, I have had an iPhone and iPad lose and twist connector pins inside the port and Apple needed to fix it in the store.
Badrul001
1. Turn off iPad
2. Turn on computer and launch iTunes (make sure you have the latest version of iTune)
3. Plug USB cable into computer's USB port
4. Hold Home button down and plug the other end of cable into docking port.
DO NOT RELEASE BUTTON until you see picture of iTunes and plug
5. Release Home button.
ON COMPUTER
6. iTunes has detected iPad in recovery mode. You must restore this iPad before it can be used with iTunes.
7. Select "Restore iPad"...
Note:
1. Data will be lost if you do not have backup
2. You must follow step 1 to step 4 VERY CLOSELY.
4helpful
5answers
Adding music to iPad
You can add music to the iPad by directly downloading from the iTunes app or by importing your music into iTunes on a computer. Once your music is imported/downloaded into iTunes on a computer, you then just need to sync the music by connecting your iPad to a computer.
1helpful
2answers
How do I charge the iPad battery.
USB hubs typically don't generate the 10 watts necessary to charge an iPad when it's connected to your computer. This basically means you can't use your laptop to recharge your iPad.
Apple recommends finding an AC outlet and using 10-watt power adapter that came with your iPad.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
