I find it weird also. Check this out.
Limited range of your remote controls could
be related to radio frequency interference that comes from something
in your home or in the surrounding environment. Certain electrical
devices can radiate interference; this could be almost anything that
is plugged into an electrical outlet.
Please keep in mind that
the device can be brand new, or can be an item that has been in use
for quite a while. Also, the item may continue to function properly
as far as you are able to tell. The only problem with the item may be
that it has started to broadcast the interference, with no other
symptoms noted.
Some devices are more likely to generate
interference than others. This includes TV cable, cable amplifiers,
surge protectors, fluorescent lights, battery charging devices (power
tools, golf carts, etc.), anything that utilizes a timer (sprinkler
systems, lights, alarm systems, etc.), and a myriad of others. If the
problem seems sporadic, we can safely assume that the device
responsible for the interference is only being operated during these
times. Again, please keep in mind that the age of the device does not
determine if it is capable of broadcasting unwanted interference. Any
electrical device can be the source of the problem.
To isolate
potential sources of interference, turn the circuit breaker off to
the garage and plug the garage door opener into an extension cord
from another room. If the range improves, then the interference is
coming from a device in the garage. If no improvement is seen follow
the same procedure, this time turning off the circuit breakers to
your home, with the exception of the garage and test the remote
controls. If improvement is noted, turn the circuit breakers back on,
one by one, until the range problem resurfaces. This will allow you
to narrow down what room the problem device is in. You will have to
go from there to isolate it further, by unplugging and re-plugging
the items in that room.
If you are unable to determine any
source of interference, then the receiver logic board in the overhead
unit will need to be replaced.
The instructions in the owner's manual are correct, but after following them, my garage door installer and I discovered a few quirks and fixes for them.
It is important to park the Touareg in front of the garage door. Be careful not to park underneath it.
If your remote garage door transmitters are already programmed to your door opener, you need to do the following steps:
1. On the garage door opener itself, there is a learn button. Press and hold down the learn button until the learn indicator light goes out (approx. 6 seconds). (The learn button is near the antenna on your door opener.) By doing this, you have just reset the codes. At this point your remote door transmitters will most likely not work. This is o.k.
2. In the Touareg, press and hold whichever homelink button you want to program until the light above the homelink buttons slowly blinks. Continue to hold the button in and at the same time, hold your remote transmitter underneath the map lights and press the button. Continue to press both buttons until the homelink light rapidly flashes. Let go of both buttons.
3. You now have 30 seconds to press the learn button on your garage door opener. Press it once. The light will start to blink.
4. Go back to the Touareg, press and hold the homelink button you just programmed for 3 seconds until you get a blinking light. Repeat again. This time, it should open or close the door. The homelink button is now programmed.
5. Now that the homelink button is programmed, you now have to re-program your remote transmitters. Take the transmitters with you.
6. On the garage door opener, press the learn button, the light will blink. Now press the button on the remote transmitter. The light should stop blinking. Repeat the step if you have more than one transmitter. You should be all set. The homelink button should work in the Touareg and your remote transmitter(s) should also work.
In summary, the rolling codes in the door opener receiver have to be reset. For some reason, the Touareg has to be programmed FIRST. Then the remote transmitter units. If the remote transmitter units are already programmed, you will most likely not be able to program the homelink in the Touareg for a rolling code door opener.
