Question about Toshiba Computers & Internet
Toshiba tecra 8100 , says memory is incompatiable type?
    Scholar:
  • 51 Answers
The Toshiba Tecra 8100 only supports 144-Pin PC100 SODIMM RAM chips. It has 2 total RAM slots and can support up to a maximum of 512MB of RAM.
If you have attempted to upgrade the RAM on the unit, ensure that both modules are seated (plugged in) firmly. Also ensure that they are of the correct type (144-Pin PC100 SODIMM), and size (not bigger than 256MB each). Anything other than those types of chips will yield you that message.
If you (or someone else) have not attempted a memory upgrade on the unit, then it's entirely possible that your unit's RAM is failing and I would reccommend bringing it in to a repair shop to have it troubleshot / fixxed.
Hope that helps you, and please do not forget to rate my solution.
Posted on Jul 17, 2008
,toshiba tecra 8100
Oh..that one is hard to do specially to novice. I would suggest not to do it. It would be hard for you to dismantle your laptop bit by bit and it is very risky. You might it end up damaging your laptop. Take it to a qualified technician to get it done. okay..:-)
Dec 15, 2009 | Toshiba Tecra 8100 Pentium III, 850 MHz...
Toshiba tekra 8100 on off knapp var finns den ?
> on off button where finds it?
The ON/OFF could a switch that "slides" about 50 mm,
or it could be a button with an 'I" inside a "circle".
The pictures at:
http://www.irisvista.com/tech/laptops/Toshiba-Tecra-8100/Tecra-8100-FL-inverter-big/remove-replace-FL-inverter-00.jpg
and:
http://www.pcarena.hu/pricelist/oriaskep/toshiba-tecra-8100-570.jpg
do not show any "button" on/near the keyboard.
The picture:
http://www.recycledgoods.com/images/s_p_12957_5.jpg
does not show any button on the back.
So, look for a "slider" or a "button" on the side(s) of the case.
Nov 25, 2009 | Toshiba Tecra 8100 (p000279550) Keyboard
Meu Tecra 8100 simplesmente nao liga , funcionava , inseri um hd externo , e desliguei pelo memu iniciar , antes eu so desligava pelo power botton.
Há alguns arquivos que faltam às suas necessidades Tecra 8100 para executar, ele trava no botão de menu porque ele está procurando por arquivos de menu e software que está no seu arranque do programa.
Por favor, desligue o 8100, ligar o HD externo e reiniciar novamente.
Ela vai funcionar bem
Nov 02, 2009 | Toshiba Tecra 8100 Notebook
User manuals
|Here you go:
Tecra 8100 Series User's Guide
And also as an extra:
Tecra 8100 Disassembly
With compliments.
G.
Nov 09, 2008 | Computers & Internet
Drivers for Toshiba Tecra 8100
Arifin,
  • You should goto toshiba make registration of your product and download drviers which you want.
  • Or click here, select your model number and make download.
Gud Luck
Iqbal
Apr 17, 2008 | Toshiba Tecra 8100 Notebook
Toshiba Tecra 8100 PIII laptop not booting
It could be a hard ware isuse. Try this.
If you have extra memory or removable Ram ( usually located on the bottom under a panel) Try removing it and starting it, with the ram removed. Then try putting it back in and starting it. If it works, it may be bad memory or it just needed to be reseated. Do this also with the cd drive and wireless card if it is removeable.
also try this with the battery, plug it in and remove the battery and see if it starts.
alot of laptops, like computers will not boot if there is a hardware issue.
The Beeping is a code. The number of beeps and how it beeps usually indicates an issue.
you could look the beep codes up on the toshiba website is the support center.
Good luck.
Apr 15, 2008 | Toshiba Tecra 8100 Pentium III, 850 MHz...
Dead machine
you need to replace the memory stick it has given up on you !
Mar 22, 2008 | Toshiba Tecra 8100 Notebook
Toshiba 8100
Memory slots are getting loose. Try to keep pressure on the memory door. Also, might try new memory.
Good luck
Nov 21, 2007 | Toshiba Tecra 8100 Notebook
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
