Question about Toshiba Satellite 1415-S105 Notebook
IDE Error - CD/RW not functioning
Hi Experts,
I like to know how to fix the above mentioned problem. I've read somewhere that I need to re-attached the cd-rw wire but I need a manual guide to take me through the process.
Any help would be greatly appreciated. Thanks.
Josey
    Genius:
  • 2,028 Answers
Does the drive still read CD's? Is it just the burner end that is not recognized?
Posted on Jul 17, 2008
Need to connect samsung dvd to tv
Hi Elizabeth,
You cant do this. That burner you mentioned specially designed for Desktop PCs.
Thanks
Mar 13, 2012 | Samsung SH-S222A/BSBF DVDRW Drive - DVD+R...
Error E24 when trying to record on symphonic vhs/dvd recorder have tried multiple brands of disc using dvd-r like directions say....arg
My BBK DW9937S dead too. But I changed its DVDWriter to NEC5170 (and now I've got an DW9938 because I can burn even DVD-R/RW disks too).
As I mentioned above almost any combo VHS/DVDwriter has the IDE DVDRW inside (I hope you guess how to fix it)
Jun 06, 2011 | Symphonic SR90VE
I bought 2nd hand NEC ND-3540A DVD-RW CD-RW DUAL LAYER REWRITER IDE for the replacement of Philips DVD R/RW Drive (DVD8631/96). However this ND-3540A will cause the ploblem of not only unworkable, but...
since you have been inside your computer and moving leads about some of these may be old and deteriotaed then any movement might
(crack break the circuit even if its slight)
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 10, 2011 | NEC ND-3540A DVD RW Dual Layer Burner
Teac Dw 224E-R WONT BURN ON A DVD - Is it a DVD Writer?
hi no its only a CD RW, and not a CD/DVD-RW its just a CD writer and a dvd( rom )..read only memory which means it only reads dvd's but does not write them...hope this helps
Jun 14, 2010 | Teac Dw 224E-R Disk Drive CD-RW / DVD-ROM...
HP dvd740b does not detect blank CDs and DVDs
i think you,ve hit the nail-on-the-head.
The laser has to power up highrer to write a DVD, or ocassionally have a dual laser. 1 for read/write CD. And 1 For Read/Write DVD.
Certain cd roms, only use CD- media. it,s probably worth checking which media is supported by the drive.
Also check the drives aren,t conflicting, on the same ide channel, sometimes swapping channels, ide primary/secondary can help, or swiitching Master/Slave/cable select jumpers on the drives Themselves.
Mike @ Compurepair.
Sep 04, 2009 | HP dvd740i DVD±RW Dual Layer Burner
Acer aspire l100 dvd problem
your DVD ROM's lens has became weak.
and it cannot be repaired.
But if you manage to open the DVD ROM clean the dust in it & it will start working agaain but be careful remember that no power should be attached to ROM.
pls rate me
thankyou
Feb 14, 2009 | Acer Aspire L100 PC Desktop
CD/DVD-RW Drive
Any DVD Read writer will work
Jan 01, 2009 | Dell Dimension 3000 PC Desktop
Looking for.....
You will need a low profile dvd. Do you want a part and vendor?
Worldvet
Jun 21, 2008 | HP Compaq Business d530 Ultra-Slim PC...
Won't read dvd or cd
Hi , visit www.compuvest.com you can find dvd-rw driver on sale.
May 14, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
Sony DVD RW AW-Q170A Burning Problem Plzzz.....Help me out: i have two drives, 1) Sony DVD RW AW-Q170A 1.70 Ver 2) Sony DVD/CD-RW Combo RYK4 Ver My "Sony DVD RW...
Check that the writable DVDs you are using are compatible (+/-) with your Sony DVD-RAM.
Go to Windows Explorer and check to see if the Sony drive is visible. It may not be connected or the Jumper switch may be set incorrectly.
Check you have drivers installed, take a look in Hardware manager.
Sometimes, it's a little difficult to copy CDs and DVDs when you have more than one burning suite installed - for some reason, they 'just don't get along'. Try uninstalling any suites other than Nero.
Or it may just be that your Sony CD-RW drive is just that, and your DVD-RW drive is just that. So it wouldn't be possible to write DVDs on the CD-RW and CDs on the DVD-RW? Though I would assume Nero would detect that and use your hard-drive as temporary storage.
In Nero SmartStart, have you selected the CD or DVD tab to correspond to the project you're burning?
Jan 07, 2008 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
Toshiba Satellite 1415-S105 Notebook Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
