Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
No power my craftsmen electric mower is not getting power when it is plugged in. worked just fine for 2 years.
    Problem Solver:
  • 5 Answers
I was having the same problem. I took the whole thing apart. It was the motor brushes and the handle switch. Check out www.ToolPartsDirect.com and type in your mower model number. You can see the diagram and order the parts you need. Mine were less than $20. It's really easy to take this mower apart.
Posted on Jul 24, 2008
  • 4 Answers
I also had this problem with the B
Posted on Jul 11, 2010
My 2 year old corded electric Task Force mower whch has had very light use suddenly stopped in middle of mowing and won't restart. Didn't trip any breakers and the cord is fine. Felt cool, not clogged
Sounds like electric motor has gone bad. If you can get past the switch and put a tester on and see if there is any power there that would tell whether your switch has gone bad. I had a new electric motor go bad after ten minutes use. I ended up replacing it.
Sep 28, 2014 | Garden
Craftsmen 917289233 won't start
How is the quality of the fuel? Was the spark plug replaced? If so, was the gap set correctly? (0.30)
May 20, 2012 | Craftsman Garden
I have a Toro 20" self propelled, electric start
I am strictly Briggs&Stratton. They are hard to start when the fuel tank is half empty. Clean the plug and air filter.
Jun 15, 2011 | Toro Power Lawn Mower
Engine turns over strong but will not start.
I'd pull the carb bowl off first and see if it has water or other crud in it. there should be an oil drain on the bottom, sometimes they are an allen socket plug which sits fairly flush
Sep 26, 2009 | Garden
Craftsmen LT 3000 will not crank
That Briggs engine is not a good engine it has a weak governor gear that is known to come apart for no reason what so ever it may have done so and some of the parts stopped the cam gear from turning. Good luck!
Aug 24, 2009 | Garden
Our craftsmen electric pressure washer stopped working while in use. We have power - red light on gfci and we tested the master switch - has power too. So what can be the problem? One post mentioned a...
The pump switch they spoke of is an internal switch. It is activated by a valve so that when you let go of the trigger, the machine shuts off. This valve is stuck or the switch is bad. Usually the valve is the problem. I would go to Sears and get it looked at
Cant start model # 917.377590 a 6.75 hp eager 1 craftsmen mower
I want you to empty the fuel tank. ues a dowel rod to push a t-shirt type cloth in the gas tank and **** out all the gas and water from the tank. It worked for me hope it helps you also.
Aug 03, 2009 | Garden
Blades don't engage
Check the drive belt for the blades
Jul 22, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need diagram for drive belt on a craftsmen ys
Get your model # from under the seat (should start with 917) and go to this site.. http://www.searspartsdirect.com/partsdirect/index.action Then, enter your model #, click on search, scroll down to Subcomponent list to Mower Deck and there ya are. You'll probably have to click on 'zoom in' in the top left corner. Hope that's what you were looking for
May 17, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
114 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
