When not in use, it changes colours,flashing red, green
    Scholar:
  • 52 Answers
...that's a lot like my wife -- when not it use, she changes color, too. Often to a pale green with flashing red eyes!
Posted on Jul 18, 2008
I have seen a problem in my tv is that there is no green colour display in crt. only two colour ( i.e. Red and Blue) or combination may be display. Pl. look into this matter , replay soon
Your problem may related to the green output or driver stage in your tv. Usually green calour is not tranmitted, only blue and red colour informatein are comming from transmitters. Green colour information is regenerated inside the tv by matrix network. If the matrix get damaged no green colour will be displayed. To check first; whether the TV colour picture tube's green gun is right or not. For that you must connect a resistor of value more than 470k 2W, to the green cathode of the picture tube base to earth. The connection should be done causiously, not for a long time. It is advised to do in intermittantly with just touches. When you touch the green cathode with the resistor with one side of it earthed, a green flash must come on the crt. You can do this test for red and blue too. If there is no green flash, or light picture tube may be faulty. It is a very rare case. You must check the volltages of the other two cathodes [red and blue]. The voltage at green cathode must be almost the same as other two.
Just check the green output transistor for open. If it is open, voltage at green cathode will be high. Also check the base voltge of the green output transistor. It should be around 2.5vDC. You can compare the base voltages of the other two transistors with green drive base voltage. If there is no base voltage, the fault should be in the matrix section. It is inside an Ic. Philips usually uses TDA series Ics in chroma section. Check the Ic pin voltages according to service manual and try to rectify the fault. It needs a technical knowledge and skill.
Oct 14, 2010 | Philips Magnavox 27MS343S 27" TV
When i try to turn it on, it starts off with a green light changes to a yellow colour then flashes red.
If you are getting the red yellow light you will need to stop the heat build up you can use a good guide to do this or send it in to be fixed.
Jul 12, 2010 | Sony Playstation 3 (PS3) Console
Red and green lights are flashing alternatively and colour ink cartridge has run out. How do i change the cartridge?
Flashing alternately mean waste pad full. Reset using SSC utility or Adjusment program/resetter. But, you must replace cartridge before. Turn off printer, unlock carriage lock (left side of carriage at parking position). Move carriage by hand to replacement position. Replace ink tank. Reset using the resetter.
May 21, 2010 | Epson Stylus C46 InkJet Printer
How to print when one color is empty
you will change the colour of the text you want to print to the colour of the remaining colour then it will print with the remaining colour.........if it is red you will change the colour of your text to red and if it is green you do the same.....!
Jan 21, 2010 | Brother MFC 210C All-In-One InkJet Printer
Plasma tv stopped working
hi i have a pioneer plasma tv pdpro4e all it doses is flash green red green red and on the mediar reciver as well tv dont come on help please
Dec 31, 2009 | Televison & Video
Screen gone yellow and green
I have a 21'' NEC TV Screen and it about 3 year old. the colour has gone to yellow and green color and the red etc
May 10, 2009 | Samsung PPM42S3 42 in. Plasma Television
Car stereo illumination colour
there are two versions of that radio. your version does not have a color change option. here is the manual for it. https://esupport.sony.com/US/p/model-home.pl?mdl=CDXGT310&template_id=1®ion_id=1&tab=manuals#
Jun 06, 2017 | Car Audio & Video
Screen all blue
Try looking into the blue CRT lens while its on and see if the coolant has congealed. You will be able to tell if it has bacteria growing as this can cause the blue to be unresposive and make your screen have a blue haze. The coolant will need changing if this is congealed with bacteria. This is a common problem in all projection tvs blue and green are more prone to this sympton red is not.
Mar 30, 2008 | Televison & Video
Picture problems
CRT green gun is not working properly , maybe dry soldered or no green drive signal. Pink and red colour is due to missing of green colour.
Sep 09, 2007 | Sanyo DS27820 27" TV
Flashing Green
I would guess that your problem is similiar to mine but mine is with the color red. The CRT went out which is a 400 dollar part and who knows how hard to fix.
Nov 21, 2006 | Pioneer SD-533HD5 53" Rear Projection HDTV
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
