Question about Polaroid I533P Digital Camera
I533 digital camera
This camera was only used to a few months. It was dropped and the lense is stuck out. Can it be fixed?
The exact same thing happened to me!!!!
Posted on Aug 07, 2008
Canon powershot zoom lense is stuck how can i get it to
There are a few things you can try. Here is an excellent blog about lens errors and stuck lenses, and it covers what can be tried to free it up:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
They say about 50% of lens problems can be fixed trying their suggestions. Hope you're one of the lucky ones! Also, if nothing works, get an estimate before having it repaired. Often, it's just better to get another camera.
Jul 09, 2010 | Canon PowerShot A540 Digital Camera
Stuck lense on olympus FE-350
If the lens is stuck out then you will find it is usually one of a few reasons.
1. Check the batteries
(obvious I know).
2. The
camera has been dropped or knocked.
3. The camera has grit or dirt in the lens mechanism.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average
home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
May 31, 2010 | Olympus FE-360 Digital Camera
Lense stuck out camera shuts downwith lense out
1. Check the batteries. (obvious I know).
2. The camera has been dropped or knocked.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
Apr 21, 2010 | Kodak EASYSHARE M1063 Digital Camera
I dropped my camera and now the lense wont open camera will power up but only lense error
the motor that dirves the lens must be stuck , just take it to the service center to get it fixed
Apr 16, 2010 | Kodak Easyshare C813 Digital Camera
CAMERA DROPPED AND LENSE IS STUCK OUT AND CAMERA
your len's mechanism is damaged or jammed. It would be too expensive to repair!!Hopefully this helps
Jul 24, 2009 | Polaroid i631 Digital Camera
Lensis not coming out
If you turn it on in photo review mode the lense will not open so turn it on in photo capture mode or if dirt gets caught in the lense it would jamm it shut so try to clean it, or if the lense is dented it would jamm, or if at one time the lense tried to open indide a case or in a position where the lense was blocked the motor mioght have burned out or the gear that pushes the lense out might have broken, in the case of the last three answers then a specialist might be able to fix it , or you might need a new camera, (i reccomend a fujifilm)
Jul 23, 2009 | Kodak Easyshare C813 Digital Camera
Lens are stuck out. screen says "lens error"
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can not take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard for a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal. Make sure to clean the outside of the lense when fully open and keep it clean always. If this did not help, read 2.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inspect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on the camera and your camera would be back to normal.
Good luck!!!!!!
Jun 11, 2009 | Olympus FE-270 Digital Camera
Kodak camera dropped lens cockeyed stuck open
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Apr 08, 2009 | Kodak EasyShare V1003 Digital Camera
The lcd screen on my polaroid i533 digital camera went out
your screen is broken, some one must have accidentally put pressure on just the screen. The smae thing happened to my screen now i am looking to buy a new screen
Oct 27, 2007 | Polaroid I533P Digital Camera
Polaroid I533P Digital Camera Logo
71 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
