Question about Casio EXILIM ZOOM EX-Z600 Digital Camera
Menu constantly displays
When I start my camera, it goes through the entire new set-up options (time, date, location etc) even though I've filled them in previously. I complete them again and it's fine until I switch it off and on again, and the problem starts all over again...thus meaning all my photo's are listed as being taken on the same day etc. It has only recently started happening.
  • Thom Garcia Dec 12, 2008
    I even took the covers off to try and see if there is an internal watch type battery that can be replaced. Turns out the user's manual says there is no separate battery for the date/time function. The date/time will go off after 30 hours with no power from the battery or charger.
  • 374 Answers
SOURCE: Have to go through settings at each camera start
If you take ur batteries out for more than 15 minutes your going to have to do those settings each time. If it does it while you still have batteries in I would first take the mem card out and then format the internal memory. Then I would reset the camera before finally putting the mem card back in.
Posted on Jul 08, 2007
SOURCE: Camera keeps resetting the settings when turned off
Possible solution?
PROCEDURE
1. Initialize the system.
a) Enter the TEST mode.
b) Select "3:ROM UPDATE" and press SET button.
c) Next, select "5:SYSTEM INITIAL" and press SET button.
d) The following message appears.
SYSTEM INITIALIZE
START ...
PUSH OK KEY?
e) Press SET button and System is initialized.
"SUCCESS !" appears on the monitor.
2. Write firmware.
Update the firmware version"
Write the firmware.
If the TEST mode boots automatically, change "USB TCC ON" to "USB TCC OFF".
Posted on Dec 15, 2007
SOURCE: starts at menu
with the Casio Z45 they seemed to have a similar problem and suggested that you format the internal flash memory.
Remove Card
Turn on camera
Set Date etc
Format Memory and turn off.
It didnt work for me, but you may have more success!
Posted on Apr 21, 2008
SOURCE: Black LCD Screen
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Posted on May 22, 2008
SOURCE: Horizontal lines have recently started appearing in all photos
Camera worked fine for several months. Now the pictures are blurry. Any advice? Thanks.
Posted on Aug 15, 2008
My Camera keeps asking me for the date and time every time I turn it on How do i stop this?
Press the m button during shooting or playback to display the setup menu. The setup menu provides access to a variety of camera settings, including options not listed in the function menu, display options, and the time and date. Once you have the date and time set it should stop asking.
Aug 26, 2013 | DMCOM Olympus Vr-320 14 Mp Digital Camera...
My camera shows that the date and time are set up but date does not print on picture when developed. it's a new camera and I just developed my first set of prints and there is no date on any of them. ...
On digital cameras, the data is stored with the filename. Check the back of your prints to see if the dates were not printed there. Most companies do put at least the date information on the back of the prints as well as any other metadata stored with the file produced by the digital camera. Unlike film cameras, which could only record the date by actually putting it on the picture, digital pictures contain metadata that can include things such as people tags, location tags (geotagging), etc. depending upon the capabilities of your camera. The date and time is always stored along with the filename on all digital cameras. If the company that printed your pictures did not include the date on the back of the picture, ask them if they can do it or find another source to print your pictures that can.
If this did not address your issue, please reply with any amplifying information so that I may more accurately address your issue.
I hope this helped!
Apr 10, 2011 | Kodak C195 Digital Camera
Fuji finepix z display date time
Start the MENU and navigate to the DATE option. Select thestyle of date and maybe the location. Be sure to save before exiting the menus. The date should display all the time now and in your chosen location.
Jun 11, 2009 | Fuji FinePix A345 Digital Camera
Date display in photos in IXUS40
here is the solution:
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
To set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
your date and time are set now
congratulations!
Rate this answer if it is working with you
thank you
with all my best regards
huetrichard@gmail.com
May 09, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Time and date display
I have the same camera and the only way to do this is to first, Make sure you have set the date and time correctly on your camera. Take a picture or View picture you want date & time stamped. Press the circular 'Menu/Set' button Press down arrow to playback mode Press right arrow on 'text stamp' Choose whether to apply stamp to single or multiple photos Press 'Menu/set' to select photo to stamp. Choose which stamps to add. Date, time, age etc.. Press 'Menu/set' again and select 'Yes' in box. The only problem with this is that it will resize your photos to 3m, which can make them grainier if you took them at a higher res. Gillian
Feb 20, 2009 | Panasonic Lumix DMC-TZ50 Digital Camera
Setting time and date
From the manual:
1. Press the MENU button to open the menu.
2. Turn the SET dial to select [SYSTEM] and press the
SET dial.
3. Turn the SET dial to select [T.ZONE/DST] and press
the SET dial.
4. Turn the SET dial to select the setting option that represents your time zone and press the SET dial. To adjust for daylight saving time, select the time zone with the * next to the area.
5. Turn the SET dial to select [D/TIME SET] and press
the SET dial. The year display starts to flash.
6. Turn the SET dial to select the year, and press the
SET dial.
• The next part of the display starts flashing.
• Set the month, day, hours and minutes in the same way.
7. Press the MENU button to close the menu and to
start the clock.
Jan 15, 2009 | Canon Video Cameras
The date is displaying on my pictures for our business we do not want this to happen, it just started displaying recently, we have a DC50 zoom camera, top of the line but very outdated
Press Menu, autourg00778004id1973498.jpg to highlight Setup, then OK to access settings Options Return to previous menu.
Camera Sounds
Choose sound effects.
All On (default)
Shutter Only
All Off
Auto Power Off
Choose inactivity time until camera turns off.
10 minutes
5 minutes
3 minutes (default)
1 minute
Date & Time
See Setting the language, date/time.
Date Stamp
Imprint the date on pictures.
Choose a date option, or turn off the feature. (Default is off.)
Video Date Display
Display Date/Time at the start of video playback.
On (default)choose from date formats.
Off
Blur Warning
See Understanding blur warning icons.
On Off
Language
Format
caution.gif CAUTION:
Formatting deletes all pictures/videos, including those that are protected. Removing a card during formatting may damage the card.
spacer.gif Memory Card - deletes everything on the card; formats the card.
Cancel - exits this setting.
Internal Memory - deletes everything in internal memory including email addresses, album names, and favorites; formats the internal memory.
About
View camera information.
Jan 05, 2009 | Kodak Digital Science DC50 Zoom Digital...
Date and Time
Do you have the Camera User Guide~~~It tells you how to set it on p37
or
I found this on the Camera User Guide
steps
1.press the function/setting button
2.on the left side,there's a column displaying various features, and then you go to select the very last one, and then it will displays more options for you to choose(L,M1,M2,M3,S, postcard,etc), and then "postcard" is the one you should choose.
3.After that, go to "menu", go down to the very bottom on the option list, you will see that the "Date Stamp" is being set "off", go there and choose other options (date/date and time). This is how you can display time on the pictures.
Jul 09, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Cant get onto the menu screen
I finally figured it out!!! There is a button on the right-hand side of the camera, which switches it from normal mode to simple mode. Just press the button and everything goes back to the way it was...
Feb 24, 2008 | Olympus Stylus 730 Digital Camera
Starts at menu
Remove Card
Turn on camera
Set Date etc
Sep 05, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Casio EXILIM ZOOM EX-Z600 Digital Camera Logo
32 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
