Question about Dell Latitude C610 Notebook
Bios yes i can get in the setup. but what do i do next???
  • 781 Answers
Your question was about the bios sometimes you need to access it if you have problems now you know how to access it. check on the internet about it before trying to change anything.
Posted on Jul 17, 2008
Computer showing missing boot manager
1-Insert the Windows installation disc into the disc drive, and then start the computer.
2-Press a key when the message Press any key to boot from CD or DVD appears.
a-If your PC does not detect the media automatically
b-During the restart process, read the screen for any instructions that explain how to interrupt normal startup and enter the basic input/output system (BIOS) setup utility. Most PCs use the F2, F10, ESC, or DEL key to begin the BIOS Setup.
c-Look for a tab in the BIOS Setup Utility that is labeled Boot Order, Boot Options, or Boot. Following the directions on the screen, use the arrow keys to go to the Boot Order, then press Enter.
d-Locate the CD, DVD, or USB flash drive (this might be called Removable Device) in the Boot list. Following the directions on the screen, use the arrow keys to move the drive up so that it appears first in the Boot list. Press Enter. The boot order sequence is now changed to boot from the CD, DVD, or USB flash drive.
e-Press F10 to save your changes and to exit the BIOS Setup Utility. Select Yes in the confirmation window. The PC will restart.
3-Select a language, a time and a currency, a keyboard or input method, and then select Next.
4-Select Repair your computer.
5-In the System Recovery Options dialog box, select the drive of your Windows installation, and then select Next.
6-At the System Recovery Options dialog box, select Repair your computer.
7-Select the operating system that you want to repair, and then select Next.
8-In the System Recovery Options dialog box, select Startup Repair.
http://bit.ly/2ykOBno
Oct 13, 2017 | Computers & Internet
My hp pavilliona6400f tunrs on but thats all
a desk top, why not lead off with that lil' fact.
the screen never glows that it, not once messsagge of any kind.
called dead black screen.
no battery to pull. like laptop has
so DT, 101, BScreen.
1: fans in the PC run ok? yes, /no
mine has 5 but yours maybe 2, 1 for PSU, one on CPU.
do that?
yes, good
no ! , PSU is bad, or not turned on, the PSU some have hidden rear switch, 0/1 mine does. used for lightening protection, (off)
yes, fans run, then hope is possible but not assured
ok fans keep running? not die in 1second? yes/no.
yes, the BIOS works next the BIOS screens work even with the HDD not present, that should tell you a lot.
hit the BIOS hot key. im not reading your hp manual to you but it told you every day what to push with prompts from day one.
Ill stop here, most give up at, what's a PSU.
mine says, hit ESC to enter setup (BIOS)
every day. same message, never ending.... unless PSU takes a dump. (or worse there is always that due to the 1,303,000,000 transistors inside. can MALF.)
bad ram.
bad PSU
power switch front case fell off.
mobo bad.
and more. I can list many more, but stop here.
get a A+ certification?
Jun 14, 2017 | HP Computers & Internet
0280:Previous boot incomplete - Default configuration used
Error Code: 0280 Previous boot incomplete - Default configuration used
Message Meanings : Previous POST did not complete successfully. POST loads default values and offers to run Setup. If the failure was caused by incorrect values and they are not corrected, the next boot will likely fail. On system with control of wait states, improper Setup settings can also terminate POST and cause this error on the next boot. Run Setup and verify that wait-state configuration is correct. This error is cleared the next time the system is booted.
What does the above mean ??? If the BIOS does not see a particular device loading ( like Hard Drive ) Try bringing up the Bios setting F-2 and reset to default. Hope this helps
BBBB
If one of the BIOS settings is incorrect or if the system is looking for a particular ggggg
Mar 17, 2014 | Acer Aspire 3100-1405 Notebook
Bat bios checksum problems solve
Step 1:
Update ASUS BIOS b> Insert bootable floppy disk or USB drive. Copy the updated BIOS file to floppy disk or USB drive.
(Note: BIOS file and boot files should fit on a floppy disk. If the BIOS file is too large to fit with boot files, consider using the EZ Flash method described below.) Insert the motherboard support CD into optical drive. Copy AFUDOS.EXE from CD to a floppy disk or USB drive. Reboot. When the DOS prompt appears, type the following: afudos /i[name of BIOS file]For example, "p4c800b.rom" might be the name of the new BIOS file. "afudos
/ip4c800b.rom" is the command that will install it. Wait. Your monitor will display the update's progress with a series of messages: "Reading file," then "Erasing flash," then "Writing flash." The "writing flash" message will be followed with a percentage counter that tells you how far the write has proceeded. The final message will be
"Verifying flash." DO NOT switch off or reboot at any point in this process or you will ruin your motherboard. After the update is complete, the utility will return to the DOS prompt. Remove your floppy disk and reboot. Enter the BIOS Menu and load "Setup Default." Save and reboot. You're finished. b> Update Using EZ Flash Copy your new BIOS files to a floppy disk or USB drive. Reboot. When the system is at POST, press "Alt" + "F2" to enter EZ-Flash. Alternatively, on late model motherboards you may press "Delete" to enter BIOS setup, then access EZ-Flash from the "Tools" option on the navigation bar. (Select Tools > ASUS EZ Flash 2 > YES) Wait for your system to check current BIOS information. Insert your floppy or USB with the new BIOS file. Select the drive letter with the BIOS update file, then select the file. Wait for your system to check the update file. After the file check is finished, click "Yes" to update your BIOS. Wait. Let the update procedure run until it finishes. Do not switch off or reboot or you will ruin your motherboard. When the update is finished, remove the floppy or USB drive and reboot. Enter the BIOS Menu and load "Setup Default." Reboot. You're finished. b> Update Through the Internet If it isn't installed already, install the ASUS Update utility. You can either download it or use the copy on your motherboard's support CD. Close all Windows applications if any are running. Launch the ASUS Update utility from the Windows desktop by clicking "Start>Programs>ASUS>ASUSUpdate>ASUSUpdate." The "ASUS Update" main window will then appear. Select "Update BIOS" from the "Internet option" drop-down menu. Click "Next." Select the ASUS FTP site nearest you, or choose "Auto Select." Click "Next." From the FTP site, select the BIOS version that you wish to download. Click "Next." Start the update. Wait for it to complete.
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Feb 05, 2013 | ASUS Eee PC 900 Notebook
My computer screen went completely white. I have a Dell flatscreen monitor
This issue occurs due to various reasons. However, in this case it might be due to corrupt BIOS settings. To resolve this issue I recommend you to visit the following website to download and install the BIOS Update:
===Installation Instructions ===
1. Download the BIOS update. (from Dell website)
2. Double-click the BIOS update icon, and then click NEXT.
3. Accept the license terms, and then click NEXT.
4. If an Overwrite Protection message appears, click YES TO ALL.
5. Click OK at the Windows Based BIOS Update window.
6. Click YES at the next Windows Based BIOS Update window, and then wait for the update to complete.
7. At the Windows Based BIOS Update window, click YES to restart your PC.
8. If you see the following message during the restart of your PC, continue with the remaining steps; otherwise you are done with the update.
Default BIOS settings have been loaded due to BIOS update or checksum issue.
Press to enter Setup. Otherwise, allow the PC to continue.
9. Press and hold F1 for a few seconds to open the BIOS Setup.
10. Press F5 for a few seconds, choose YES, and then press Enter to load the BIOS defaults. (Use the arrow keys to choose YES, if necessary.)
11. Press F10 for a few seconds, choose YES, and then press Enter to exit the BIOS Setup and save your changes. (Use the arrow keys to choose YES, if necessary.)
12. Press Enter to confirm the save.
13. If you see a System Settings Change message prompting you to restart your PC, click YES to restart the PC again.
Also use a sytem utility software RegInOut -- a System Utilities program that includes several features which allows the PC users to speedup their computer performance. It improves system performance by removing junk files and fixing registry errors. Its additional feature of
Internet Optimizer enhance users web browsing experience.
Dec 19, 2011 | Dell Computers & Internet
Installed new bios for windows 7, not working,on start up, computer locks up, able to unlock- but didn't happen with original bios. Looking for old bios to re install sholder012001@yahoo.com
o open the BIOS Setup screen: Reloading the BIOS default settings To reload the factory BIOS settings to the setup default:
  1. Press the F5 function key.
  2. Select Yes or OK.
  3. Press the Enter key.
  4. Press the F10 function key.
  5. Select Yes or OK to save the defaults.
You can also complete the following steps to reload the factory BIOS settings using the menu:
  1. In the BIOS Setup utility, select the Exit tab.
  2. Select Load Setup Defaults.
  3. The system prompts you to load the optimized setup defaults. Select Yes or OK and press the Enter key.
  4. Select Exit Saving Changes.
  5. Press Esc and then press Enter to exit Setup.
Please don't forget to rate this if it fixed your problem. Four thumbs up is basically what means your problem was solved. Anything less means your problem was not solved. Not sure people here understand that as far as how we get rated.
Jan 15, 2011 | HP DT PAVILION ELITE E9120f DESKTOP PC
Wont boot puts screen up with phoenix award winning bios setup press f1 or del to enter setup done that next window gives multiple options, standard cmos features etc. at the bottom of the page option...
this is a bios screen.
when your computer has no operating system to boot to, it hangs at the Bios screen.
either your hard drive is dead, your boot sector of your hard drive is corrupt or you need to reinstall your Operating System
Nov 26, 2009 | Medion Computers & Internet
Desktop hp Product Number P6402A
Step 1: Find the current BIOS version number
  1. Turn ON your pc. When the first screen appears, press F1 to enter the BIOS Setup. On certain Compaq Presario PCs (prior to 2002) press the F10 key at the logo screen to enter setup.
  2. The BIOS revision number is listed on the Main menu. Write down the current BIOS version that is listed.
  3. To exit the BIOS setup screen, press F10 , select Yes , and then press the Enter key.
Step 2: Check the Drivers and Downloads page for BIOS or ROM updates
  1. Go to http://h10025.www1.hp.com/ewfrf/wc/softwareRedirector?lc=en&dlc=en&cc=us&product=67009&docname=c00007682 enter the model of the PC (for example, Presario 5002US or Pavilion a518d), and click the download button.
  2. Click the link for the PC Operating System (like Windows XP).
  3. Try to find the BIOS update listed under the heading, BIOS , BIOS- System , or RomPaq.
    NOTE: The term "Rompaq" refers to BIOS updates for Compaq Presario PCs prior to 2002.
  • If a BIOS update is not listed, HP does not have a BIOS update posted for your PC at this time.
  • If there are several BIOS updates available for different motherboard names, you need to find out what motherboard is installed in your PC. This can be done by turning off the power to the PC, removing the side panel, and reading the name that is printed on the motherboard. The name of your motherboard should match or be similar to the name of the download link.
  • If a BIOS update is listed, proceed to the next step to download and install the BIOS update.
Step 3: Download and install the BIOS update
  1. Click the download link. The instructions for downloading and installing BIOS updates vary.
  • For most PCs with Windows XP, download the file, open it and follow the on-screen instructions.
  • For many PCs before Windows XP, save the downloaded file to the hard drive, insert a formatted disk, open the downloaded file to copy the BIOS files to the disk, and then restart the computer with the disk still in the drive.
  • The instructions on the download page may be different so carefully read and follow the instructions on the download page and in the installation setup screens.
  1. If a 251 or CMOS Checksum error occurs after installing the BIOS update, perform the following steps:
  2. Restart the PC and enter the BIOS screen by pressing the F1 or F10 key at the first screen.
  3. Press the F5 key to load the default BIOS configuration.
  4. Select YES by using the arrow keys, and then press Enter .
  5. Press the F10 key to save the settings and exit.
  6. Select YES by using the arrow keys, and then press Enter .
    When the BIOS update is complete, the new BIOS revision number is updated on the Main BIOS screen.
Please rate this solution. Thank you.
Feb 01, 2009 | Computers & Internet
The graphic card is install but no picture on the monitor when it is turn on
u must first set it ont the bios or reset the bios config, then pluge your external graphic card
Dec 09, 2008 | HP Computers & Internet
Dell Latitude C610 Notebook Logo
42 people viewed this question
Alun Cox
