My Tascam DP-02CF keeps saying invalid card when i put the compact flash in that they gave me or it freezes when i put it in while its turned on...is it broke????
  • joechicken Aug 09, 2008
    I have a similar problem, when I put the card in it says CF detects NG, what does this mean???
SOURCE: compact flash cards
what is the solution for this problem posted by tiller on Sep 26 2006
Posted on Apr 15, 2007
  • 189 Answers
SOURCE: how to record with a
You need to first plug a mic (or guitar) into an input. Then you have to assign that input (A or B) to a track. You do this by selecting the input (pressing the input's assign button) and then selecting the track (pushing the tracks select/rec button) above the track. The track select button will light green when you press the input assign button of the input assigned to it to show where the input is assigned. (To unassign the input simply press the lit track select button again while the input assign button is pressed).
Then you have to select the track for recording. Simply press the rec button above the track alone and it will light red and stay lit. Now press the play and record buttons and you'll be recording.
Hope this helps.
bd.
Posted on Jul 21, 2008
  • 189 Answers
SOURCE: Tascam DP-02cf
You've got two inputs on the DP-02 so you can record two sources at once.
Depending on how you want the electric guitar recorded (mic the amp, or direct line in) you can in the first case plug your guitar mic into one of the mic inputs on DP02 and plug your vocal mic into the other mic input. You also have the option of plugging the guitar directly into the DP02 (using the hi-z input - I believe it is labelled 'guitar' or something on the DP02. I any event I believe it's the one on the left). This way you only need one mic for use recording the vocal part.
To avoid any 'bleed' between channels you can use the headphones while recording this way and you'll avoid having the unamplified guitar sound coming through over the vocal mic.
Once you have the mics or guitar and mic plugged into two inputs, you need to assign the inputs to a channel (track) to record on. You do this by pressing the select button for the input and then pressing the select button for the track where you want to record the input. Do this for both inputs so that they are recording on different tracks. Then arm the tracks for recording by pressing the record button for each track and the lighted buttons will flash above each armed track. Then just press play and record and you'll be recording. You can go back and redo it as many times as you like and record over what is there, or preserve a take and assign a new track (or tracks) for another take. You've got 8 to play with.
Hope this helps.
bd.
Posted on Sep 03, 2008
  • 1138 Answers
SOURCE: how to with tascam dp-02 dp-02cf
You can use headphones or monitor speakers that are hooked to an amp. If you don't have one ,consider downloading a manual:http://www.tascam.com/i-3582-232-128-1-4A000F90.pdf Pay attention to the caution on page 9 and the hookup diagrams are on pages 12 and 13. Hope this helps.
Posted on Jan 25, 2010
SOURCE: From iTunes, I have converted the m4a track to WAV
Your wave file is probably in stereo and you need to change it to mono. I use the free Audacity program to do this.
Once you have uploaded your wave file into audacity on the left side click on the down arrow which will bring up several options, click on the 'split stereo track' option. Then delete one of the tracks. You can then export the file as a wav file, you might want to rename with mono in your name so you don't write it over your previous stereo file. You can then import the file into your DP-02
Posted on May 31, 2010
Tascam DP02CF not responding to anything what should i do nest please?
That's an 8-track recorder that records to a compact flash card. It is not a minidisc recorder.
Oct 01, 2012 | Tascam Dp-02cf Digital 8-track Recorder
DP-02CF Exports files to PC, but reads no file found when importing wav.
The answer is in the troubleshooting section of the manual:
http://tascam.com/content/downloads/products/241/E_DP-02&02CF_web.pdf
Page 53:
"Why can't my computer "see" the unit files"
Mar 01, 2011 | Tascam Dp-02cf Digital 8-track Recorder
My tascam dp-02cf wont turn on at alll.. the power plug is pluged in some 1 help asap
make sure that the main power source is OK which is AC line......
check the power cord,,
Aug 26, 2010 | Tascam Dp-02cf Digital 8-track Recorder
How do i fix the mount error, please power off.... on a tascam dp-02 when i turn it on?
The only solution I know of is: turning off the unit, then simultaneously pressing Track Edit, Cursor up, and power button until the unit asks "are you sure?" This will unfortunately erase the hard drive.
Jun 29, 2010 | Tascam Dp-02cf Digital 8-track Recorder
Im looking for a manuel for my DP-02CF
http://www.tascam.com/products/dp-02;9,16,3580,19.html
Go here and under the picture of the unit is a free download of the manual. Good luck
Feb 08, 2010 | Tascam Dp-02cf Digital 8-track Recorder
Tascam dp-02cf Problem Play Button Flashing
I just had the same problem with my Tascam recorder. Did you ever find a solution? I really don't want to lose all the work I've done
Aug 27, 2009 | Tascam 2488 Portastudio Multitrack...
135 people viewed this question
 Grubhead
Grubhead
